thinking of getting new fuel pump
Old Jul 18, 2005 | 08:08 PM
backagain's Avatar
backagain
Default thinking of getting new fuel pump
thinking of getting the walbo fuel pump. i have a stock fuel pump right now, with vortech sc and stock injectors, i as wondering since the walbro pumps more fuel if the car has to be retuned if i get ust the fuel pump and keep stock injectors. or if there is any point in getting just the walbro fuel pump without getting aftermarket injectors. thanks.
Old Jul 20, 2005 | 04:32 AM
jpc350z's Avatar
jpc350z
Re-tune is probably necessary w/walbro just to be safe and larger injectors would compliment the upgrade since the stock injectors are probably close to max'ing out. Don't want to be on the edge of safety..Additional margin makes you sleep better.. Btw I'm thinking of the same upgrades..
Old Jul 20, 2005 | 08:04 AM
socalsean's Avatar
socalsean
I agree with jpc350z. When upgrading your fuel system with a larger pump and or injectors you're changing a lot of vital components which will necessitate retuning your ecu to take complete advantage of the modifications. You could probably get away without the ecu tune, but you'd be running really rich and maybe even loose some power down low.
sean
kyin
Oct 15, 2015 05:54 AM
