Defi-BF and BOOST
Old Jul 20, 2005 | 06:07 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Defi-BF and BOOST
Hello!
I finally have a boost gauge installed on my car (Defi-BF), the highest boost that I have seen so far is 0.8 Kpa. What 0.8Kpa will be if is converted to PSI?
Thanks
Cesar
Old Jul 20, 2005 | 07:47 PM
xxlbeerZ's Avatar
xxlbeerZ
http://www.sciencemadesimple.net/pressure.php
Result of your conversion:
.8 kilopascal (kPa) is equal to 0.12 psi
Old Jul 20, 2005 | 08:00 PM
lucidazn's Avatar
lucidazn
How can it be .12 PSI of boost?
Old Jul 20, 2005 | 08:15 PM
g356gear's Avatar
g356gear
Originally Posted by CESAROTORRES
Hello!
Thanks
Cesar
I think they are in BAR not Kpa .8 bar = 11.6 PSI
8 PSI = .55 BAR
Old Jul 20, 2005 | 08:21 PM
xxlbeerZ's Avatar
xxlbeerZ
8 PSI = .55 BAR
Yes, he either meant bar (though that's high for APS on stock motor) or he doesn't have the turbo installed yet, just the gauge. I think you can get a tiny bit of psi normally aspirated.
Old Jul 21, 2005 | 03:47 AM
CESAROTORRES
This is what I seen so far, the gauge has a marking at the botton (X100Kpa). I will asume that I have to multiply 0.8 x 100Kpa=80 Kpa
The car is equiped with the APS TT, APS test pipes and APS exhaust.
Thank you!!!!!!
Cesar
Old Jul 21, 2005 | 05:14 AM
D@ActiveTuning's Avatar
D@ActiveTuning
The easiest way. 1 bar = 14.5PSI so just figure it from there...like .5 bar = 7.25 PSI, etc
Old Jul 21, 2005 | 05:34 AM
CESAROTORRES
D@ActiveTunung
Are you still using TEST pipes on your car? Did you tune it?
Thx
Cesar
Old Jul 21, 2005 | 05:38 AM
D@ActiveTuning
D@ActiveTunung
Thx
Cesar
I'm not, I'm actually selling the test pipes:
https://my350z.com/forum/showthread.php?t=133206
No tune yet, still need to find some free time to head down to Deleware.
Old Jul 21, 2005 | 05:43 AM
CESAROTORRES
Hey do you mine if I give you a call? if not please PM me your phone number.
Thank You
Cesar
Old Jul 21, 2005 | 08:00 AM
lucidazn's Avatar
lucidazn
80 kilopascal (kPa) is equal to 11.60 pound-force per square inch (psi) (lbf/in2)
That's kinda high
Old Jul 21, 2005 | 06:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
wow - on a stock motor, and untuned???......I hope you have another motor waiting in the wings
Old Jul 21, 2005 | 07:06 PM
CESAROTORRES
I am running on the stock APS TT map 91 oct, my car has APS TT, APS TEST PIPES and APS exhaust I always pump 93 OCT (Shell or Mobil). I will dyno the car tomorrow. I really like the APS test pipes, but to be safe I will reinstall my oem CATS on the car until I have the car tune. My biggest problem is that I do not think it is a tuner in Florida for the 350z with APS.
Cesar
PS.
Thanks to every one that has reply!!!!!!!
Old Jul 21, 2005 | 08:32 PM
zero2prove's Avatar
zero2prove
Cesar,
When you turn the ignition on without starting the motor, what does the boost gauge read? It should read zero. I've seen some BF guages that weren't calibrating themselves right. I can't imagine the 91 octane map can create so much boost 11.6psi even with test pipes.
Tuan
Old Jul 22, 2005 | 07:54 PM
CESAROTORRES
Default Defi gauge read (without starting the motor)
Originally Posted by zero2prove
Cesar,
Tuan
Hello Tuan!
First let me THANK YOU for taking the time out of your bussy schedule to HELP US today (I was on the shop with Tom Porter (Nex tLevel Performance)) this is what my BF reads with out turning the motor. It is a (0)
Althought the car is running super RICH , it is making 409.7 whp on a DynoJet. I will scan the chart and post it tomorrow. This is scary since I am running on stock internal and no tunning. What do you think I should do? Should I go ahead and re-install my cats back againg on the car until I can tune the car?
Old Jul 22, 2005 | 07:55 PM
xxlbeerZ's Avatar
xxlbeerZ
Doesn't your screen cover up your gauges there?
Old Jul 23, 2005 | 04:54 AM
captj3's Avatar
captj3
Hi Cesar,
I spoke to roger yesterday. I herd the car was running good.My last dyno was 397hp.What was your torque?The test pipes made a big difference.I picked up .5-1lb of boost with them.It made me leaner from 3k-4.4k then it went off the scale.The car runs great no pinging at all.So how do you like your new ride now? By the time the weather gets cooler roger will have the dyno and tune the car.I'll probably turn the boost down a little to be safe.Tuan can this be done now without sending you back the unichip?They have the equipment for the unichip your help would be appreciated.Cesar Ijust wanted to say Hi and see how your doing.
Jeff
Old Jul 23, 2005 | 08:43 AM
CESAROTORRES
Originally Posted by captj3
Hi Cesar,
Jeff
Hello Brother!
My Max POWER= 409.7
Max TORQUE= 393.4
I love my car AGAIN! Although my car is also going of the scale
Call me 407-963-2824
Cesar
Old Jul 23, 2005 | 09:34 AM
zero2prove's Avatar
zero2prove
Jeff,
If they have the unichip software than you're better off having them tune your setup on the street or dyno. Just make sure they have alot of experience tuning FI cars. The base maps that I send out are just that, something in between where I know the motor will be reliable at the cost of power. With a little tuning 440whp isn't to far off and can still be reliable on the APS kit IMO.
Tuan
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
