APS TT and built motor on 5AT
Old Jul 24, 2005 | 08:43 AM
ronnie0738's Avatar
ronnie0738
boost ownz ju
Talking APS TT and built motor on 5AT
I started my built motor & twin turbo 350Z 5AT project about 2 months ago. I got the car back just yesterday :thumbsup: No dynos b/c I still need to break-in the motor. After break-in, I'll have it dyno tuned and running ~12-13 lbs on pump gas.
So far, the tranny is holding up very well in manual mode. With a massive cooler, the tranny oil temps are nice and cool.
Air Power Systems (APS) Twin Turbo kit
JE Pistons & Corillo Rods (9:1 CR)
Crank balanced and polished
Turbo cams and springs
Stillen valve body upgrade for AT
Transmission cooler
Koyo Radiator
Nismo Thermostat
Custom dual exhaust w/ Helix test pipes
Eibach springs
Koni stuts
Stillen sway bars
19x8.5 & 19x9.5 Volk Racing gunmetal TE37s on 245/275 s03
Defi boost, transmission temp, and oil temp gauges
*Stoptech 14" Brake kit* on order
Stock pics
Uninstall
Open motor
New internals
Installation
Pickup
Gauges at night
Old Jul 24, 2005 | 08:51 AM
tig488's Avatar
tig488
insane, good luck with everything, i think id be driving it all day just to speed up the break in.
Old Jul 24, 2005 | 09:04 AM
xxlbeerZ's Avatar
xxlbeerZ
You're going to need more than just a valve body upgrade and cooler for that kind of power. Also, I think you need to raise the redline via reflash so you don't hit the rev limiter on shifts. Try this:
http://store.yahoo.com/sgpracing-store/sgpraautrup.html
http://www.350zmotoring.com/forums/s...ad.php?t=29732
Also, you don't have an EGT or AFR gauge?! That's pretty dangerous IMO...
GL!
Old Jul 24, 2005 | 09:20 AM
ronnie0738's Avatar
ronnie0738
boost ownz ju
Thanks for the suggestions.
Rev limiter has been raised. I spoke to many different companies about the tranny issue including SGP. Most of them have found that if you drive in manual mode and do your own shifting, you put much less strain on the AT and have held up with a VB upgrade & proper cooling on the street. SGP upgrade involves upgrading the clutch packs (thicker paper) in the tranny which I may do if my tranny fails or do a 6spd swap.
Old Jul 24, 2005 | 09:33 AM
xxlbeerZ's Avatar
xxlbeerZ
Ah, so you're ok in manual mode. Does that affect your times? (does the shift take any longer in DIY?)
Old Jul 24, 2005 | 09:59 AM
zzzya's Avatar
zzzya
Who did the installation work?
Old Jul 24, 2005 | 10:32 AM
G352NV's Avatar
G352NV
looks like z car garage. NICE!
Old Jul 24, 2005 | 11:48 AM
CESAROTORRES's Avatar
CESAROTORRES
Default Subscribing
Subscribing
Old Jul 24, 2005 | 12:01 PM
Nismon's Avatar
Nismon
Awesome pics, Ronnie. Congrats on the new monster!
Just to give credit where due, I saw Ronnie's Z and motor at Scott Performance while mine was being built.
Old Jul 24, 2005 | 02:03 PM
bigbri's Avatar
bigbri
Did you get your car done at scotts performance....? I just dropped mine off on sat for some major work....
Old Jul 24, 2005 | 02:19 PM
SJTrackZ's Avatar
SJTrackZ
Works was done at Scott Performance
Old Jul 24, 2005 | 06:11 PM
Z33Concept's Avatar
Z33Concept
Videos more Pictures lOOK SICK
Old Jul 24, 2005 | 06:25 PM
JoneZZZ's Avatar
JoneZZZ
subscribing...
Old Jul 24, 2005 | 07:51 PM
AmyCroft's Avatar
AmyCroft
Default SubScribe
subscribing...
Cheers Amy -
Old Jul 24, 2005 | 09:41 PM
ronnie0738's Avatar
ronnie0738
boost ownz ju
Thanks guys
Yes, mine just finished up last weekend at SP. What are you having done? APS TT? Motor work?
Old Jul 25, 2005 | 03:03 AM
PumpedVA's Avatar
PumpedVA
Subscribing
Old Jul 25, 2005 | 10:56 AM
fernandito7's Avatar
fernandito7
HOw much did this all cost? Looks sick though!
Old Jul 25, 2005 | 12:04 PM
bigbri's Avatar
bigbri
Yea I'm having aps done and a lot more... ted is promising me 450 to the wheels..... we'll see... how much hp did you have..?
Old Jul 25, 2005 | 12:43 PM
ronnie0738's Avatar
ronnie0738
boost ownz ju
^kool kool. I'll probably see you & your car around then. 450whp is very doable with cams.
I just finished break-in, so once my stoptechs come in he'll be tuning it. He said mine is going to be 500whp.
Old Jul 25, 2005 | 02:08 PM
bigbri's Avatar
bigbri
Ted told me there was nuthing to break in...?? That he could dyno it and tune then give it to me.... ??
