Turbonetics ST's weakest link?
Old Jul 27, 2005 | 09:25 PM
VeilsideZ33's Avatar
VeilsideZ33
Default Turbonetics ST's weakest link?
it might sound like a silly question...but what's the weakest link the ST has? i.e. which component of it should I be careful of?
are there any members in Canada that have had problems with the ECU reflash? Apperantly there are... I doubt it for it was told to me by a shop that wanted me to have on custom made by them. the only thing I can think of is the "different" fuel U.S. and Canada have... is that true?
-ilon.
Old Jul 28, 2005 | 04:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Im not speaking from experience as I have not received my kit yet, but from seeing some posts over the past couple of weeks, Id say the reflash isnt working out for everybody....Im a little worried that I may need to add a piggyback to fine tune.
Old Jul 28, 2005 | 06:33 AM
kcobean's Avatar
kcobean
+1. I'm working closely with Turbonetics right now to try and manage the rich condition in my car. Since no two cars are the same, but the flash is the same every time, it'll be interesting to see how it works out as more and more people install this kit. All in all, the rest of the kit is very high quality. My only other concern is under-hood temps. Opening the hood of my car after driving for any length of time is like opening the door to your oven.
Old Jul 28, 2005 | 07:51 AM
VeilsideZ33
hmm I'm in Canada - to what degree should I worry about the reflash?
just spoke to T-Netics... they said ECU reflash might be a problem with Canadian cars...
Old Jul 28, 2005 | 08:26 AM
Z PHAT Z's Avatar
Z PHAT Z
Just got my Turbonetics installed and the car is running great. Idle is good. Dyno yesterday on a Dyno Dynamic with 354 WHP and 358 WTQ. The first pull my A/F was like 10:2 kinda rich. 2nd and 3rd pull were leaner. I will post the graph when the dyno place send them to me.
Like Kcobean said...it's really hot under the hood. I'm planning to buy vented CF hood to see if it will help. If not then have to go with the hood spacer from one of the vendor selling plenum spacer...I forgot which vendor
Old Jul 28, 2005 | 09:20 AM
jpc350z's Avatar
jpc350z
Have the Voretch S/C and underhood also gets very hot.. usually open it when I get home and let out some heat..Other than soft goods, like cables/wires the metallic parts and engine sensors should have no effect due to heat..What is a hood spacer??
Old Jul 28, 2005 | 10:19 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Motordyne Engineering sells a hood spacer. Around $20-40. It mounts onto the hood-to-body mount and lifts it a couple of inches. Cooling is around 20-50 degrees F cooler all around the engine bay.
Old Jul 28, 2005 | 10:21 AM
mojo powered's Avatar
mojo powered
from what I understand, this would involve putting washers in the rear mounting bolts of the hood to have a small gap in the rear of the hood to let some of the heat out
friend of mine does this in his turbo civic, every bit helps when there is that much heat.
Old Jul 28, 2005 | 10:26 AM
palmerwmd's Avatar
palmerwmd
I have a ProCharger under hood heat isnt too bad considering
Old Jul 28, 2005 | 10:39 AM
neffster's Avatar
neffster
Anyone have pics of the hood spacer installed on a Z or a G?
Old Jul 28, 2005 | 10:40 AM
jpc350z's Avatar
jpc350z
Just checked there web site and only thing there was a plenum spacer..?
Old Jul 28, 2005 | 10:49 AM
Brandon@Forged
https://my350z.com/forum/questionable-posts/118670-motordyne-plenum-spacer-group-buy.html
https://my350z.com/forum/showpost.ph...7&postcount=10
https://my350z.com/forum/showpost.ph...0&postcount=13
https://my350z.com/forum/showpost.ph...7&postcount=42
Old Jul 28, 2005 | 10:53 AM
Brandon@Forged
Extremely apologize for temporarily hijacking this thread.
What kind of fuel does Canada use? RON?
Old Jul 28, 2005 | 11:13 AM
jpc350z's Avatar
jpc350z
Would be an aestetic improvement if the hood spacer was designed with a detent pin that allowed the hood to fully close when you want it closed and opened for cooling when running hard..Think a lot of guy's would want it..Motordyne are you listening??
Old Jul 28, 2005 | 11:18 AM
Brandon@Forged
Well, it closes with the hood spacer...you just have to remove the spacer for it to sit flush.
Old Jul 28, 2005 | 11:24 AM
VeilsideZ33
spoke to Turbonetics again... to a more knowledgeable rep I suppose...
they've sold about 3 kits to Canada now and none had any issues with the ECU.
so about two to three weeks will telll
Old Jul 28, 2005 | 11:25 AM
jpc350z's Avatar
jpc350z
Right, I was suggesting it be designed to be closed ( flush) and opened when you want without removing the bracket....
Old Jul 28, 2005 | 11:34 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
sorry, but having a gap like that in the hood looks hideous!
Old Jul 28, 2005 | 12:01 PM
Brandon@Forged
Todd, right...but at the track it wouldn't matter...preventing heat soak from happening as fast (for more runs) would be worth the bad look IMO.
Old Jul 28, 2005 | 12:13 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I would think if you ran a vented hood that would give you the temp decrease without looking so ghetto. Im planning on first running a Varis air duct, then a vented hood with my T-netics kit. <----still havent decided which one.
