e-01 air fuel ratio monitoring help
Old Jul 30, 2005 | 11:26 PM
MADScientist's Avatar
MADScientist
Exclamation e-01 air fuel ratio monitoring help
I am looking for the ecu pin outs for the primary wideband o2 sensors on a 05 350Z. I intend on running the external harness on the e-01 to monitor the factory wideband sensors and monitor the AFR on the display... You can configure the e-01 to accept the 5v signal and to a conversion rate to display the AFR...
Does anyone have the pin outs listed for these sensors listed somewhere? I have done a few searcheds and found people list pin outs but not sure if they were the primiary or secondary (narrow band).
Thanks in advance for anyhelp that is provided.
Old Jul 31, 2005 | 11:10 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
good question, i'd like to know this as well...does that mean A/F can be graphed along with boost, rpm, injector duty cycle?
Old Jul 31, 2005 | 11:51 AM
MADScientist
Sure does! I would like to think that tuning would be a lot nicer to do with all of this data on the same display...
I remember someone on the forum said they were doing this already, just can't remember who... All I need is the pinouts for the wideband signal wire going into the ecu, I can figure out the rest...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
