TurboXS Announces the Z UTEC Release
Old Oct 20, 2005 | 07:35 AM
  #181
NoObTuNeR's Avatar
NoObTuNeR
Can the rpm and gear based boost control be used with internal wastegates?
Old Oct 20, 2005 | 07:39 AM
  #182
Gman2004's Avatar
Gman2004
Originally Posted by Z1 Performance
As far as datalogging with a wideband, in order to do so, you must purchase a Tuner or Tuner Pro. The UTEC will not integrate with any other wideband on the market aside from the Tuner or Tuner Pro. You can read all about the differences between the Tuner and Tuner Pro on any number of websites, including Turbo XS's. If you do not buy a Tuner, the UTEC still can datalog a host of parameters from timing to knock to boost to TPS - all configurable inside the UTEC "software". However, if you want to datalog wideband 02 as part of the mix, a Tuner or Tuner Pro is required.
Can you provide a link to where I can read about the difference between the UTEC, UTEC tuner, and UTEC Tuner pro. I looked on Turbo XS' website but I couldn't find it. Thanks.
Old Oct 20, 2005 | 07:41 AM
  #183
theking's Avatar
theking
In the middle of the page. http://www.turboxs.com/shop_prod.php?what_category=7
Old Oct 20, 2005 | 07:44 AM
  #184
BlackTuner's Avatar
BlackTuner
Yes, RPM and Gear Based boost control can be used with internal wastegates.
Jermaine@turboxs.com
Old Oct 20, 2005 | 07:55 AM
  #185
Julian@RACEMRC's Avatar
Julian@RACEMRC
Jermaine,
How did your mechanic make out.lol
Old Oct 20, 2005 | 08:25 AM
  #186
BlackTuner's Avatar
BlackTuner
Originally Posted by Julian@RACEMRC
Jermaine,
He's not calling and cussing me out... which means two things... It wasn't that bad or he hasn't touched it yet.
JermainE~
E noted for anyone wondering the correct spelling.
Old Oct 20, 2005 | 08:29 AM
  #187
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
our site has the differences too
Old Oct 25, 2005 | 11:17 AM
  #188
BlackTuner's Avatar
BlackTuner
Can anyone spot what's different about this dyno plot???
Jermaine~
Old Oct 25, 2005 | 11:30 AM
  #189
G3po's Avatar
G3po
So what needs to be added to the basic UTEC to get boost control?
Do you sell and integrated solenoid solution.
Old Oct 25, 2005 | 11:46 AM
  #190
gringott's Avatar
gringott
Jermaine~
Toque is flatter than normal?
Old Oct 25, 2005 | 11:50 AM
  #191
BlackTuner's Avatar
BlackTuner
You will need our 120psi Boost Solenoid. Which will be released at the same time as the Z UTEC.
Thanks,
Jermaine~
Old Oct 25, 2005 | 11:52 AM
  #192
BlackTuner's Avatar
BlackTuner
, yes that is a good thing.
I will give you a hint, this car has not been reflashed and it is a feature that everyone keeps asking about
Jermaine~
Old Oct 25, 2005 | 11:55 AM
  #193
G3po's Avatar
G3po
Jermaine~
If it's a pre-2005 , looks like the rev limiter was raised a bit?
Old Oct 25, 2005 | 12:19 PM
  #194
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks,
Jermaine~
I was planning on buying a boost controller at the same time as the UTEC. Should I wait for info on this?
Old Oct 25, 2005 | 12:25 PM
  #195
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
COOL!!!!! Rev limit increase!!!! WOOOOHOOOOOO!!!!! You guys are the best!
BTW, the trq curve is normal. A little bit steeper drop off, due to the higher rev limit.
FYI...we have the UTEC on pre-order...up on the website : http://www.forgedinternals.com/store/home.php?cat=268
Old Oct 25, 2005 | 01:05 PM
  #196
Z1 Performance
Former Sponsor
if you want the utec to control boost, then get the solenoid...if you want a standalone controller, no need to wait - all about personal preference.
Old Oct 25, 2005 | 04:22 PM
  #197
35ounces's Avatar
35ounces
03 CS Track 6MT
I dont really know anything about the UTEC boost control functions and what the advantages may be to using it versus a standalone. It sounds kind of cool though.
Old Oct 25, 2005 | 06:32 PM
  #198
aalzuhair's Avatar
aalzuhair
Jermaine~
It is the REV limit .... please say yes
Old Oct 25, 2005 | 06:43 PM
  #199
DBZ33's Avatar
DBZ33
Sharif will the price go up after the Pre order? I am waiting for GRD to test it before I get it for my install they are going to do. Aslo will you carry the accessories for the UTEC (Boost control, WideBand O2)? Thanks.
Old Oct 25, 2005 | 06:50 PM
  #200
Z1 Performance
Former Sponsor
yes its the raised rev limit
