weird stuff-eu
Old Sep 8, 2005 | 08:12 PM
overZealous1's Avatar
overZealous1
Default weird stuff-eu
ok, was datalogging tonight, and saw my timing advance is trying to go to like 35-40 degrees advance at light constant throttle around 3000rpm no load. if i hold it there i will get a po300 code within about 3 seconds and can definately hear it misfiring right before i get the code. i am pulling most of my 660cc injectors via the airflow map, but am pulling -40% and it is not showing a true 40% reduction in the datalog. it have finally found a sweet spot for my idle being at 1.9ms.
any ideas why the car is trying to advance so much? if i get it figured my car will truely run great!! thanks
Old Sep 8, 2005 | 08:28 PM
theking's Avatar
theking
Because you are scaling so much via maf it is reading less air and puting you at a place on the map where the timing is more advanced.
Old Sep 8, 2005 | 08:40 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
35 to 40 degrees of timing at cruising throttle is perfectly safe, normal, and clean, as their is minimal load on the motor.
Old Sep 9, 2005 | 11:30 AM
overZealous1
i heard that it was safe to pull that much maf signal and that only scaling down in the injector map that much could possibly effect timing.
Old Sep 9, 2005 | 11:35 AM
overZealous1
i kinda figured as much at just a no load, but it does seem to work some what in unison with the car throwing up a po300 code. if there is no load it will start to misfire if i hold the throttle steady, but with the car driving it will begin to stumble after a few seconds of holding the throttle steady and a/f will go either full rich or full lean at the same time. if i keep letting off and getting back on the throttle all the time it will run great. just sounds like i don't know how to drive and makes me dizzy, hahahha.
Old Sep 9, 2005 | 12:47 PM
IceY2K1Max's Avatar
IceY2K1Max
Are you seeing boost when this occurs?
Old Sep 9, 2005 | 02:33 PM
overZealous1
nope still in vacuum. during accell under boost it is fine. just leaving the throttle in one position for more than a few seconds triggers it
aarrgghh
May 1, 2022 11:04 AM
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
