Gauges for Turbonetics
Old Sep 9, 2005 | 06:16 AM
down_shift's Avatar
down_shift
Default Gauges for Turbonetics
I have the Turbonetics ST. I'm thinking about picking up the Zeitronix with Display..
What else should I be looking at?
Oil Pressure? Boost?
I don't really want any gauges on the pillar etc. So I'm trying to keep it minimal.
Old Sep 9, 2005 | 06:19 AM
g356gear's Avatar
g356gear
Boost, oil pressure, fuel pressure
optional.....egt, oil/water temp
Old Sep 9, 2005 | 06:30 AM
arizzee's Avatar
arizzee
Just curious, isn't the stock oil pressure gauge sufficient?
Old Sep 9, 2005 | 06:37 AM
backagain's Avatar
backagain
i had the zeitronix for a while, like it at first, but then realized that the only place i could put it and make it look good was in the sunglass holder, then realized that i cant see it up there, just be sure that you buy a wideband you can see while driving if you are going to want to see it, the data logging portion of the zeitronix was great, but if you are doing a highway run and want to moniter your afr, it's hard to watch this, small number display and also doesn't change numbers as quick as the innovat or aem widebands. i am using the innovate now and couldn't be happier. goodluck with your choice.
Old Sep 9, 2005 | 06:45 AM
g356gear's Avatar
g356gear
Probably is but most guys are replacing the 3 dash gauges with Defi link gauges or going to a pillar mount system as well. With Defi you usually get a 3 gauge package together at a discounted price....then they all match.
Old Sep 9, 2005 | 07:57 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
A/F & Boost are needed. Fuel Pressure, EGT would be nice (I dont have them). I'd sort of wish I had some temp gauges to monitor also. FWIW.
Old Sep 9, 2005 | 08:03 AM
dirtroad's Avatar
dirtroad
zeitronix has boost, egt, afr and lambda available. i love mine, also wanted the stealth look. i put it in the center console where the nav screen would be. sounds like you would like this setup as well.
Old Sep 9, 2005 | 09:03 AM
taurran's Avatar
taurran
I went with a Wideband AFR and Boost. Perhaps at a later time I will add fuel pressure and water temp if need be.
Old Sep 9, 2005 | 10:49 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
He has a G35.
Old Sep 9, 2005 | 11:55 AM
MIAPLAYA's Avatar
MIAPLAYA
I have boost, fuel pressure, EGT, water temp, and oil temp. I would recommend boost, wideband, and oil temp. Fuel pressure and water temp are optional.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
