Installed 3.12 Pulley!!
Old Sep 11, 2005 | 04:54 PM
Z BOY's Avatar
Z BOY
Originally Posted by zachcrosen
Well, the Z1 tune was with the 3.33 pulley while the CP Racing tune was with the 3.12 pulley. I dont really want to start a lot of **** with Z1.
well, at least you let us know (with some prodding) .
the only way they can know they are **** is if you give them feedback, but then again, maybe they are like 350zforums and don't give a **** that they are ****.
if i were you, i would let the other boards know, too, but that's just me.
i'm glad you're feeling good about your z again.
Old Sep 11, 2005 | 06:23 PM
zachcrosen's Avatar
zachcrosen
I dont frequent the other boards very much. If you or anyone else wants to post a link to my thread on another board, feel free. I think that knowing that I am now hitting 9psi and seeing over 360RWHP, I am feeling a lot better about the Z. I think that if I were to raise my rev limit, I would see about 10-20 more RWHP but thats even less useful than having it all where it is now!! So, I guess its all good. I am still dying to run the "new car" at the drag strip and see if I can find the 12s that I have been searching for since May
Old Sep 12, 2005 | 08:21 AM
mcduck's Avatar
mcduck
Originally Posted by backagain
i had the bolt on the *** belt pulley come completely off while driving, luckily it fell in the engine bay and i found it about 3 months later, bolt was stripped completely off, it was held on by glue, i had boost surges from the bypass valve, my aux fuel pump came disconnected, and they had WAY too much timing pulled. tried FOREVER to contact them to get these issues fixed, they never would return my call (jon) and was told by Lorca to NEVER call his cell number again, and that he only gave me his number for when he brought me my car because they took an extra week to install the vortech, supposed to take 2 days. anyway, i won't go into ALL of it but i was very upset with z1motorsports as well. -1 in my book. not starting a z1bashing thread or anything just thought i'd chime in with my problems with them as well. CPracing all the way.
Not here to support or bash Z1, but the cogged bolt issue you had was not Z1's fault. That is a problem with the kit from Vortech. Mine did the same thing. Point is, installers should double check tightness of all pieces already bolted together by Vortech. Mine, luckily, was not stripped so we just bolted it back on properly.
The rest of your items just sound like a poor install.
Old Sep 12, 2005 | 10:23 AM
CpraceZ's Avatar
CpraceZ
Glad you are happy with your car, sorry I could not be here to meet you. If you every need anything just let us know.
Old Sep 12, 2005 | 01:37 PM
zachcrosen's Avatar
zachcrosen
Matt, your inbox is full so I couldnt send this to you privately. Everything is kool. I think I am finally happy with the Vortech and the power. I am wierd, so I will not know if I am completely satisfied until I take a run at the drag strip. Yeah it was a little hectic there Sat but they were great and got everything done and then some for me. Thanks for everything and tanks to Ralph for the tune and answering my tons of questions!!
Zach
Old Sep 12, 2005 | 04:25 PM
freezeg35's Avatar
freezeg35
Cp, off topic but in a previous thread it was stated that most good r4 tuners(insert your name here) will tune fuel via rpm and timing via psi. What is your opinion on that. Thanks for the semi hijack zac.
Old Sep 13, 2005 | 06:54 AM
CpraceZ's Avatar
CpraceZ
The R4 software has fuel and spark set up in two different maps - both maps (tables) have RPM on the Vetical axis and PSI (Vacuum / Boost) on the Horizontal axis. As for tuning you really need to do it opposite of what you mentioned. Timing can be set via RPM - in other words, you can set up the software to take out 1 degree of timing at 4000 RPM accross the board regardless of the boost, 2 degrees at 4500 RPM, and so on. The fuel is much more sensitive to boost, if you tune fuel by RPM and get more or less boost than expected you vehicle will go either too rich or worse too lean. Therefore, we always tune fuel based on boost and RPM. this way you can account for belt slippage, or a owner that decides to do his own pulley swap
Old Sep 13, 2005 | 10:48 AM
backagain's Avatar
backagain
so by what you just said i could put on a smaller pulley and not require a retune ?
but then again if a smaller pulley was put on i'd probably hit more boost, and my car isn't tuned for anything above 8 psi correct ? (remember we only hit 7.9 psi)
Old Sep 14, 2005 | 08:21 AM
CpraceZ's Avatar
CpraceZ
typicaly we would tune the car to the boost level that it is running
and if you were to make more boost it is set up to run realy rich
Old Sep 14, 2005 | 08:31 AM
backagain's Avatar
backagain
so by that it wouldn't be worth the smaller pulley because if it's that rich it isn't making much more power with all the fuel ?
also does the smaller pulley help with power coming quicker ?
Old Sep 14, 2005 | 03:41 PM
booger's Avatar
booger
BOOST 6 6.5 7 7.5 8 8.5 9 9.5 10 10.5
r
p
m
3500 9.8 9.8 9.8 10 10 10 10 10 10 10 10 10 10 10 10
4000 8 8 8 8 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10
4500 7.2 7.2 7.2 7.2 7.2 7.2 7.2 10 10 10 10 10 10 10 10
5000 7.2 7.2 7.2 7.2 7.2 7.2 7.2 7.2 10 10 10 10 10 10 10
5500 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 10 10 10 10 10 10
6000 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 10 10 10 10 10
6500 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 10 10 10 10 10
7000 6.8 6.8 6.8 6.8 6.8 6.8 6.8 6.8 6.8 6.8 6.8 6.8 10 10 10 01
This is how I asure if I get more boost I'll have plenty of fuel . I datalog what psi I have at what rpm and then after that I keep the number high . This is not my map..just an example
R
P
M
Old Sep 15, 2005 | 07:34 AM
mcduck's Avatar
mcduck
I think that is the whole point of a smaller pulley for us Vortech users. YOu can get more peak HP, but sooner or later you hit the point where more power is going to mean bottom end upgrades, too.
The best gain for us with a smaller pulley is to hit higher boost levels sooner in the powerband.
Sounds like CPRacing is tuning us to be safe for a pulley upgrade, but IMO you should always plan to retune with a change like that to ensure you're getting the best bang for your buck.
Just so happens I know a great tuning shop you can take it to...
Old Sep 15, 2005 | 08:51 AM
LiNks's Avatar
LiNks
ZachRosen:: I had my vortech and installed and tuned by AAM and i made 384 hp @ 9 psi on the stock pulley,, after they dynoed my car they thought i was running the 3.12 pulley and so did i cause of the high numbers however i talked to the guy i bought the kit from and he assured me that he sold me the stock pulley and belt. Weird but im not complaining at all. my air fuel stayed perfect till about 6600 rpms
CPracez:: if i install the 3.12 pulley when i am getting 9 psi with the stock pulley am i going to be at around 11 psi? is that safe? i definatly want bigger injectors as is, would 440 rc be enough or should i go to 520s? Also if im at 9psi and upgrade my hp levels should be over 400 right?
Old Sep 15, 2005 | 11:48 AM
CpraceZ's Avatar
CpraceZ
You should be in the area of 400hp do you have headers and a Cat-back? They might be needed because with increasing the boost you also are increasing the air flow which with out exhaust you may have to much back pressure. 440ccs should be plenty, going with the 520ccs you might have to check if the Split Second software, or the SAFC which I see you have has the capabilities to tune that big of injector, you might have to step up to a Greddy Emanage.
Old Sep 15, 2005 | 12:01 PM
LiNks's Avatar
LiNks
I have the Injen exhasut and HF cats, thinking about swapping to test pipes, but i dont want that smell thats gonna go along with them.... I am also thinking about headers however that makes the car real loud. The 440s are going to go in within a week or two
Old Sep 15, 2005 | 12:07 PM
Brando's Avatar
Brando
Unhappy
Originally Posted by 2003z
not to knock z1, but when I just installed a vortech on my buddies G35c, we first had to remove the underdrive pulley they installed. We tried a breaker bar, the breaker bar on the floor and turning over the engine and my impact wrench to break the pulley bolt free. I don't know what they used to tighten it, but it finally took a semi-truck tire changing company to come out. He started with his normal impact wrench, then tried an 800lb impact wrench and then finally, after about 5 minutes of banging on it with his 1400ft.lb. impact wrench, we finally got the bolt off!
I've had to fix several things on my friend's cars that they have installed.
That "buddy" would be me!
The reason that they put the crank pulley on for me.....is cause I had a credit.
The reason I had a credit.....is from a previous mess up.
You figure it out for yourselves.......
Me, I'm going to CP Race to get mine tuned as soon as I can get there.
Old Sep 15, 2005 | 01:25 PM
  #38
booger's Avatar
booger
I had the 550's scaled with the R4 . But I ended up having TS flash for them and I tune with the R4 .
Old Sep 16, 2005 | 03:08 AM
  #39
neffster's Avatar
neffster
1. I drove from Oviedo, FL right past z1 straight to CPRacing for my Vortech install and tuning.
2. My set up consists of Crawford headers, h/f cats and plenum and a JIC Y-Pipe. I have the 3.12 pulley and my A/F is hitting anywhere from high 10's to high 11's at WOT. The kit puts out are 388rwhp and 331rwtq 'tuned' at 9psi on 93 octane.
G8tor20 has the 3.12 pulley and only Crawford cats. He is hitting 385rwhp and 314rwtq at 10.5psi on 93 octane and his torque is lower than mine when you overlay the graphs by a good amount from ~3000rpms on.
If you're looking for a 'pick me up' on the low end, check out the Crawford headers (or possibly another brand). They seem to be working really well for me.
3. +1,000,000 on the work that CP Racing does. I'd gladly drive another 8 hours for that kind of service.
Old Sep 16, 2005 | 05:25 AM
  #40
mcduck's Avatar
mcduck
I've been saying this for two years. The Crawford Headers are one of the two best, maybe the best, non-FI mod I made to my Z. Glad to see someone else agrees and can provide some comparitive data. (BTW, the other great non-FI mod I fully endorse is a lightweight flywheel!)
