5AT to 6MT
Old Sep 21, 2005 | 06:49 PM
CESAROTORRES's Avatar
CESAROTORRES
Default 5AT to 6MT
Hello!
Does any one on this forum convert a 5AT to 6MT?
What will be the parts need it and cost?
Cesar
Power by APSTT
5AT (
Old Sep 22, 2005 | 06:02 AM
neffster's Avatar
neffster
Check with Gurgen. I believe he was looking into this at one point and he's a very knowledgable source of information.
Old Sep 22, 2005 | 06:04 AM
sq40's Avatar
sq40
Tag.. Probably 5 Grand to do it.. But Tag..
Old Sep 22, 2005 | 06:24 AM
zeith's Avatar
zeith
you can get a racing auto trans the will be be faster than a 6mt at sgp racing for 3 grand
Old Sep 22, 2005 | 09:05 AM
Z33Concept's Avatar
Z33Concept
Don't do it keep it 5AT
Old Sep 22, 2005 | 12:46 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I have done a lot of research into this. It'd not as hard as it sounds, on paper (and then some) at least.
The large ($$) pieces are the tranny, clutch, front drive shaft, rear diff (kind of optional i guess), and the engine control harness (EGI harness), ECU. New retail prices (approx): ~$2000, xxx, $600, $600, $550, $650. I can get about 30-35% off these prices at the dealer. If you ask junk yards, they will say that they will provide everything that you need for $2800.
The probelm is that no one is actually nuts enough to do it... I am defintiely looking into it, but i'ts becoem more of a long term goal...
Old Sep 22, 2005 | 12:51 PM
sq40's Avatar
sq40
Long term goal indeed. Possibly in 2-3 Years when we can get junk Z's for $4K..
Old Sep 22, 2005 | 12:54 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
no mostly because i won't have the time/money. I almost did this this summer.
Old Sep 23, 2005 | 08:29 AM
AznIceRckt's Avatar
AznIceRckt
I'm really starting to look into this more too.
Every time I look at the underside on a lift, it appears SO EASY.
The shift linkage already pops into the interior through a large 4" X 2" hole..
I don't care where I mount the master cylinder and other accessories... do they need to go somewhere specific? i have no interior... and i was eventually going to add a fuel cell (even though the g35 sedan has its fuel tank in-between axles, and most race-leagues do not dictate changing to a fuel cell), and even dry sump one day if i win the lottery.
While SGP racing's auto build-up is great from what I've heard, it is still an auto. Even with paddle or button up/down shifts (it has to be possible).. it would still be boring.
I however would like to install the conversion with a tilton or ap racing pedal box. Its not the parts that are a lot... but the conversion/labor...
Old Sep 23, 2005 | 02:41 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
well.... it's not he mechanical part of the project that's hard, it's the electronics in my opinion. I guarantee you can make the mechanics fit, but the electronics are a bit harder., but i a POSITIIVE it's veyr doable.
Just no time....
Old Sep 23, 2005 | 02:53 PM
overZealous1's Avatar
overZealous1
hell, i am looking at going the opposite direction. i am hoping to hit 600-650 rwhp very soon and am having trouble finding a clutch that will hold the power and not be a pita to drive. sounds to me like the auto might be a better choice for those power levels and beyond. i havn't completely decided on the swap, but the only clutches i am finding that will hold that power and more are $2500 for just the clutch. maybe a swap could happen with someone. lol.
Old Sep 23, 2005 | 05:26 PM
tinman's Avatar
tinman
may i ask 1 question? WHY 5AT to 6MT?
Old Sep 23, 2005 | 05:38 PM
CESAROTORRES
Sure,
Because I am sick of hitting the rev limiter. and also nobody has a solution yet for the 5AT
Cesar
Old Sep 23, 2005 | 07:02 PM
GXCLUSIV's Avatar
GXCLUSIV
Gymrats G35 TT
Did you raise your rev limiter with the TS L-spec flash? If and when SGP starts the VB upgrades, that should help also. $1200 seems little high though, not including install.
Old Oct 2, 2005 | 07:01 AM
CESAROTORRES
I AGREE 1,200 is too high! I think it should be on the 900.00 range not 1,200.
Cesar
350ZR 5AT APS TT
Florida USA
Old Oct 2, 2005 | 07:19 AM
KTaylor's Avatar
KTaylor
i looked into doing this to but found out that it would be cheaper just to trade the Z in and get a 6mt.
Old Oct 2, 2005 | 07:31 AM
CESAROTORRES
I agree, I will continue to wait for a good VB upgrade.
Cesar
Old Oct 2, 2005 | 01:34 PM
ak_350's Avatar
ak_350
TS L-spec flash?
what exactly is this? how would i go about getting my car flashed? sorry i am new and just got my first AT car and would like to build it up some! thanks in advance
Old Oct 2, 2005 | 02:49 PM
amolaver's Avatar
amolaver
how about converting to a T-56 or TKO? I actually emailed Tremec about converting my existing 6MT to a T-56, and they referred me to www.keislerauto.com. I didn't pursue it, but given the fragility that the Z's tranny has shown, I will continue to consider it. I've already had one trans replaced (under warranty), and if I ever complete my APS ST install, the next one won't be a warranty item. I'll definately pursue it further. Ideally, I'd be able to get a paddle shift Xtrax, but that's probably $20K for the unit - never mind the labor to make it work... But how cool would that be
Old Oct 2, 2005 | 03:03 PM
GMADD's Avatar
GMADD
Wouldn't it be cheaper and less complicated to get a built tranny from SGP ?
that's what I'll be doing later on.
