Single Turbo Kit by Eternal Motorsports for the G35 coupe
Originally Posted by theking
On the Z/G these are the only places that make sense. So I wouldn't call it copying. I just wish that the single turbo kits would put the maf pre-turbo cause this would help with proper metering. I guess their just isn't a place for it although you could make a harness extension and put it down by the filter.
I can max it out below 4000rpms. It reads 5.115v at max.
So the ecu goes into limp mode, when the maf is maxed?
D-
Originally Posted by Cronic
What size is the housing the maf sits in? I have to go look at my car as i am not even sure which style maf thse cars run.
D-
D-
The maf is a hotwire type. It's either 75 or 90mm. I can't remember which. You could run a lightning or cobra MAF(JWT website has the specific model you need). This would help but those will be pretty easy to max out as well once you get over 500whp if you use a blow through method. If the ECU sees higher than 4.84 volts before ~4700 rpms it will go into limp mode.
D-
D-
Originally Posted by MIAPLAYA
I think its 3+" ID...I would have to check to be sure. Yes if the MAF craps itself above the max input voltage the ECU freaks and wont let you rev above like 2500 RPMs. Remember that peak input voltage for the MAF N/A is somewhere in the 3 range on volts so you are talking about the ECU seeing 2 volts above the typical max.
I think once the utec is out if full force, it will be a great tuning option for alot of us.
Good to know. Thanks! I may start playing with some different things. I wish there were some locals with ST set-ups.
The more people that mess with these motors and ecu the better. Support from the "big" tuners has been minimal to date.(Not including SGP, CP, Sharif, etc.)
Really how much is a GT35R. I know the 60-1 with T4 turbine side is over $1700 just for the turbo. Do you have any flow data on that Tial 44 mm gate that I could compare to the Evolution BTW?
well i'll be heading up to east harford, conn. either tonight or tomorrow morning. the Uni-chip will be installed and tuned at XXTuning. i'm hoping for 400hp. i really don't need much more than that. i think they are going to tune for two maps 6psi and 10psi. of boost. i know that they are going to tune on a dynapak but, they have a mustang dyno also. wish me luck guys.
Hey Damen...Good luck with the uni-chip install/tuning. The kit looks great man..It'll be interesting to follow the progress of this kit over the next year or so...Is the intent to bring this kit to market as a commercially available item? If so, I hope that they are able to work on the pricing to make it competitive with the existing offerings. If not, they'll need to come up with some unique selling points to set their product apart....
Can't wait to see your dyno graphs!!! You gonna have your beast at the last mega-meet of the year?
the intent is to sell the kit as a commercial item. i don't control the pricing but, i feel confident that it will be competitive with the unique points. and yes i do plan on being at the last mega meet.
