turbo vs. supercharger revisited
Old Dec 23, 2002 | 05:33 PM
  #61
Wicked4u2c's Avatar
Wicked4u2c
Originally posted by Maddogy
anyone who intersted i reading professional info on sc's vs turbo do a search on the web and see, i did, and a sc requires maximum rpm to make maximum boost, this info is on any website that has any info on sc's, i did not fabricate this info this is real stuff no matter what one Honda guys boost gauge read, the hard fact are there written even by SC manufacturers themselves, i can go and find 10 more direct quates about sc's and they will state the same thing over and over, the sc is completely dependent on rpm, a turbo is not. THE TRUTH IS OUT THERE, please someone else track down this info to clear up this argument.
What's your point? this doesn't justify that a supercharger is better..? I have a couple of datalogs here on my computer that I was reviewing. This was the result, when floored I reached 8psi of boost at 2,800 RPM. But immidieatly dropped to 4 psi around 3,500. So its like a boost spike. Than as the RPM keept increasing it would slowly go up im talking fractions. Again.. my conclusion is TURBO all the way, their is enough facts that prove turbo is better, I have had both on my car and know which one I personally like.. I think their is enough information now to justify what is better other than personal preferance. I am done here in this thread unless an intelligent remark is made, I have made everything clear and like he said if you want to learn more go visit other webisites.. TURBO ALL THE WAY!
Old Dec 23, 2002 | 05:55 PM
  #62
Maddogy's Avatar
Maddogy
dude i also think a turbo is the way to go, where have i said a super is better ???? all i said is a super needs more rpm to make boost, a turbo doesn't, you said the sc made max boost at 2500 rpm and i disagree with that as its not really how a sc works, which is why i am not a fan of sc's, unless you are running a low rpm v-8 as then they seem to work decent(not as good as a turbo)
Old Dec 23, 2002 | 09:20 PM
  #63
roberto350z's Avatar
roberto350z
well, I dont know what the f*ck you guys were just talking about, but at least now I know Im goin with a standalone turbo. Whatever that is
Old Dec 23, 2002 | 11:45 PM
  #64
Wicked1's Avatar
Wicked1
I have 2 agree with Wicked4u2c and Maddogy just get a turbo+standalone with tuning = .
Old Dec 24, 2002 | 12:03 AM
  #65
GY-Z's Avatar
GY-Z
I suggest a supercharged car.....
a supercharged Z can gives us somthing around 80 HP gain....
and a twin turbo charged Z can gives us something around 50~90 Hp gain...depends on how heavy u adjust da boost....
for a supercharged car...u can have da HP gain from ur engine starts....to da engine burnes out....not matter how high da rpm is....u still can enjoy ur gain in HP...
For a turbocharged car...u just having da HP gain in certain RPM area...usually high RPM................which results in "turbo lag".....
even a twin turbo car will have Turbo lag.......but just less then a single turbo......
Old Dec 24, 2002 | 11:31 AM
  #66
Maddogy's Avatar
Maddogy
dude you dont know much about turbos and sc's, a turbo make maximum power way way before a sc does, and a turbo that only puts down an additional 50 whp, at what 4 psi, and always always a turbo will put down way way more power per psi than a supercharger. Can the Z currently spin its tires ??? yes it can so you still have lots of power till the turbo spools(about 2000-2500) rpm on a tein turbo 3.5 litre, remember the bigger the engine the less lag per target hp. As in a 2 litre turbo engine making 500whp is going to have alot of lag, a 3.5 litre v-6 twin turbo making 500 hp will have next to no noticeable lag, and since the z has good compression it will still have tons of power before boost, in fact you probadly will need to have an electronic boost controller to keep boost lower in first gear to prevent tire roasting, believe me when the twins spool hang on real tight as at 12 psi you will nearly double your hp(14.8 psi will approximately double your hp) so at a modest 8 psi expect 400 plus whp
Old Dec 24, 2002 | 12:28 PM
  #67
TJZ's Avatar
TJZ
[B]
RS-X can run 10psi doesn't mean you can do that too. A 500hp engine is a lot hotter than those in RSX. I still say you need to lower comp.
I can see your knowledge is poor about tunning. Any engine builder/tuner will tell you that lowering compression will just allow you to boost more but doesn't mean you can't achieve your target. I challenge you and anyone.
If we build the same car. You use 9:1 compression I use 10:1 compression. I will have higher horsepower at a lower Boost level than that of the 9:1. it all comes down to the strenght of the internals.. How is 9:1 any better than 10:1 using same manufacture of pistons.... Tell that to any manufacuture and they will think your a MORON. So your telling me that 10:1 pistons are weak? Is that why you can't boost..? NO! Again, if we build the same car and say I boost 10Psi and make 300WHP you would have to boost about 15PSI to make the same power as mine.. But if I start going any further than I could be looking for trouble just like if you start going further than 15psi you will also be looking for trouble. get my point? Just wait till an actual TURBO charger from a respectable company comes out and I will prove you wrong... I am so waiting for AEM to come out with their standalone unit becasue that is the best investment in my opinion someone can have. After that I will boost over 10PSI on this Z with no problem.. Nissan motors are excellent and you will soon see....
If he just wouldn't have disagreed with me you wouldn't have had to type all that.
Old Dec 24, 2002 | 12:29 PM
  #68
TJZ's Avatar
TJZ
what you have said will depend on if it's a roots or centrifugal type SC. Both behave differently.
Old Dec 24, 2002 | 12:33 PM
  #69
TJZ's Avatar
TJZ
For the love of god man, USE punctuation. Just glancing at your post gives me a headache. Also, like what has been said for many times, turbo lag will be negligable with the proper set up. We will only be boosting up to probably no more than 10psi. Therefore we don't have to have a huge turbo with it's inherent turbo lag.
Old Dec 24, 2002 | 01:13 PM
  #70
tim_n/a's Avatar
tim_n/a
[/B]
If we build the same car. You use 9:1 compression I use 10:1 compression. I will have higher horsepower at a lower Boost level than that of the 9:1. it all comes down to the strenght of the internals.. How is 9:1 any better than 10:1 using same manufacture of pistons.... Tell that to any manufacuture and they will think your a MORON. So your telling me that 10:1 pistons are weak? Is that why you can't boost..? NO! Again, if we build the same car and say I boost 10Psi and make 300WHP you would have to boost about 15PSI to make the same power as mine.. But if I start going any further than I could be looking for trouble just like if you start going further than 15psi you will also be looking for trouble. get my point? Just wait till an actual TURBO charger from a respectable company comes out and I will prove you wrong... I am so waiting for AEM to come out with their standalone unit becasue that is the best investment in my opinion someone can have. After that I will boost over 10PSI on this Z with no problem.. Nissan motors are excellent and you will soon see.... [/B]
The fact I didn't check this thread doesn't mean I agree with you. Just tell me which engine may have higher ouput.
9:1 and run 16psi and 10:1 run at 10psi
When both run at 0psi boost, 10:1 engine will have about 10% edge over 9:1 engine. But giving the 9:1 engine boost 24% higher than 10:1 engine. The 9:1 engine will have about 14% edge over the 10:1 one. In fact, 9:1 with 12.5psi is about the same as 10:1 with 10psi boost. Clear?
Again. I still say you can't reach 500hp target with stock internal without lower comp. With 9:1 comp, you probably need 16psi to get 500hp at crank. 19psi to get 500hp at wheel. Without lower comp, you still need 13psi to get 500hp crank or 16psi to put 500hp at wheel.
Now tell me, which one do you have in mind? The 500hp we were talking about was at wheel? or at crank? I say can can't achieve either.
Old Dec 24, 2002 | 01:41 PM
  #71
TJZ's Avatar
TJZ
Originally posted by tim_n/a
Again. I still say you can't reach 500hp target with stock internal without lower comp. With 9:1 comp, you probably need 16psi to get 500hp at crank. 19psi to get 500hp at wheel. Without lower comp, you still need 13psi to get 500hp crank or 16psi to put 500hp at wheel. r.
Nice job spurting out numbers off the top of your head.
Old Dec 24, 2002 | 01:52 PM
  #72
tim_n/a's Avatar
tim_n/a
There is one thing call Math. I think you also need to learn another thing call planning.
Old Dec 24, 2002 | 01:55 PM
  #73
TJZ's Avatar
TJZ
I'm not quite sure what you're inferring. However, if you want to be hostile, I think you need to learn something callED (notice the "ed") grammar (you made the same mistake twice in one post).
Now if you would like to quit this nonsense and have a civilized conversation, please feel free to tell how you came up with your numbers.
Old Dec 24, 2002 | 02:47 PM
  #74
tim_n/a's Avatar
tim_n/a
comp ratio has a linear relationship with torque or hp under fixed air pressure. Within a range of course.
When we deal with boost psi, just need to remember those number are added to our current 1 BAR environment, which is 14.5psi.
And the sum of air pressure number also has a linear relationship with torgue ot hp with other variables fixed.
put 13psi on stock engine translate to 27.5 total air presssure. For the same operation, your engine is going to suck 27.5/14.5 times air. Now remember, this is not an idea world, so there will be lose. ideally, an 280hp engine should come out 540hp but consider friction and you need power to spool turbo, 500hp at crank should be ball park. 16psi will probably lead to 580hp at crank and that's roughly 500hp at wheel.
Now to put out same amount of power on a 9:1 engine vs 10:1, you will need 10% more air pressure(either engine press it or charger do it before engine). So to come out the same 500hp you would need 10% more pressure than 27.5 psi, and that will be 30.25 psi or 16psi added to 1 bar already exist.
Old Dec 24, 2002 | 03:44 PM
  #75
Wicked4u2c's Avatar
Wicked4u2c
I don't need to say more Just please give me all your contact information E-mail, Name, Address, whatver you want give me time until AEM releases their Engine Management, and we have a respectable turbo company making a kit like Greddy, HKS, Apexi etc... When they release it and I will show you my 500whp graph! on pump gas... We have already messed with a Maxima that has 460whp on 14.0psi of boost daily driver pump gas on turbo. Seeing our engine is a lot better this should be a breeze! Again, I don't feel the need to argue with your nonesense as I have seen it in person and done it myself, and the Z will have no problem making 500whp on stock internals (RELIABLE!) Once these components are out, I will make sure you will be the first to know my son, until than keep believing in what you want I suggest you start hanging out at shops that build motors, talk to "race teams" and ask them questions because you have a lot to learn.
Old Dec 24, 2002 | 04:24 PM
  #76
tim_n/a's Avatar
tim_n/a
Don't try to confous the topic. Your 460whp maxima only prove my calculation is so close, that's about 520 crank hp at 14psi. (Remember what did I say about 13psi?) The same engine on Z will only delivers 420hp to wheel since FWD vs RWD. And I bet it has intercooler thick gasket and lots messing with timing. Don't tell me it's a simple bolt on $7000 kit. Besides, a heavy mod like this. 240hp Maxima engine already catched up all edges Nissan had given Z over Altima/Maxima (mainly ECU parameters). You are already looking into future. That's it. My son. Merry Christmas.
Old Dec 24, 2002 | 05:36 PM
  #77
Wicked1's Avatar
Wicked1
There's a lot of debate, misunderstanding, misinformation and general ignorance when it comes to making this particular comparison. A lot of people seem to make their decision based solely on the fact that many high powered engines, such as those in drag cars and most notably Top Fuelers use superchargers, so naturally this must be the best form of pressurised induction. Others will use turbocharger 'lag' - defined as the time taken from the opening of the throttle until the turbo provides positive pressure to the manifold, as a reason for supercharger's superiority. Whatever the reason given, it's wrong. Turbochargers have proven to be the superior form of pressurised induction over and over again, both in terms of energy used to drive the compressing device, and in some cases - depending on the type of blower - the actual operating efficiency of the device itself. Bottom line; a turbo will produce more power than a supercharger. Here I'm going to outline the reasons, with help from the experts, why this is the case.
Superchargers are belt driven off the crankshaft of the engine, and therein lies the critical difference between the two systems. The supercharger will turn at a speed with a direct relationship to crank speed, while with a turbo does not - many more factors come into play. There are several types of supercharger - roots, screw and centrifugal to name but a few. The roots-type blower is one of the 'positive displacement' type blowers, which compresses air by a series of moving compartments, created by two interlocking lobed rotors. It differs from the centrifugal blower in that its a 'sealed' type design, which provides boost in a 'linear' fashion and actually presents the compressed air to the manifold in a series of pulses. This type of supercharger has a large amount of internal friction due to the edges of the rotors turning inside the casing and meshing with each other. This friction adds heat to the air, aside from the normal heat associated with compression of a medium, and is one of the reasons why a roots-type supercharger (an early design) is inefficient compared to a turbo. This extra heat is energy taken from the crank and wasted. Not only is it wasted but the heat is detrimental to power production.
A lot of people also seem to think that turbochargers belong on small displacement engines, and that they dont work or are not suited to larger displacements. This could not be further from the truth. A turbo is a method for increasing the amount of air breathed by an engine. They are a fairly efficent device, certainly more so than a rootes blower and with advantages over the latest breed of centrifugal superchargers. Indeed a large turbo is more efficient than a small one for two main reasons; it heats the air less for the same amount of flow, and presents a larger impellor area to the exhaust flow, and hence less restriction than a smaller turbo.
In an effort to improve the poor efficiency of the supercharger, designers have taken the turbo (realising its superior efficiency) and essentially cut it in half, driving it from the crank rather than via an exhaust gas-powered turbine. This is the basis for the centrifugal supercharger, and this design is largely successful in solving the inefficiency problems. However, the centrifugal nature of this blower means it is not a 'sealed' type design, instead it pressurises the air by literally flinging it out of the turbine at very high speed. This generates pressure without the pulses of the roots-type blower. Also in contrast to the 'linear' boost delivery of the roots blower, a centrifugal blower generates boost in an exponential fashion. This is both a curse and a blessing; a curse because it tends to hamper response at low revs, and a blessing because airflow at medium to high revs is greatly enhanced. These are the traditional characteristics of the turbo on which it is based. However, even with the increased efficiency of the centrifugal design over the old roots-style design, a considerable load is still placed on the engine by using a crank driven pulley system to drive the supercharger.
In this form superchargers have become increasingly common in Australia. At least 3 types of kit offering supercharged induction for the Holden V8 have become available in the last 2-3 years. With the efficiency of the centrifugal supercharger (but still limited to engine rpm - more on that later) these kits have become a viable alternative to the standard route to finding more power via a bigger cam, head porting, compression increase, larger intake and extractors, etc. The use of the compact centrifugal design means it can fit under the bonnet with no requirement for holes or bulges in the hood. Both the Australian and American kits available here use centrifugal superchargers to achieve flywheel power of approximately 270-300kW for the otherwise stock Holden 5.0 V8. Indeed Yagoonda Automotive Services in Sydney have made around 400kW (~539bhp) and 700Nm from an HSV 5.7 litre-based engine. These figures would tend to be supported with the performance of 4.7 sec for 0-100kmh and 12.2 over the standing quarter mile. Admittedly this car uses forged pistons in place of the stock components, but I think I am fairly justified in saying this kind of output would be nigh on impossible to extract from a naturally aspirated HSV 5.7ltr engine, particularly the torque figure.
The turbo, in stark contrast to the supercharger, is driven solely by exhaust gas pressure. Where normally the exceedingly hot exhaust gasses would simply be left to exit uninhibited down the exhaust pipe to the atmosphere, a turbo brings a number of finely engineered components into contact with this heat. This creates several headaches for designers, and early turbocharged engines illustrate the problems. Short turbo life, cooked engine oil and the resulting damaged engines - all these were common problems associated with a lack of understanding and preparation for the specific needs of a turbocharged engine. Add to this the problems with turbo lag and response time compared to superchargers and it is easy to see why turbos are misunderstood and commonly disliked. Lag, it is likely, will always be a consideration for a turbocharged engine, but it is possible to minimise this with the manipulation of other factors. Turbocharger sizing is becoming a much more understood art, and together with increases in technology the turbocharger has and is continuing to become more efficient and reliable. Lag is being specifically addressed by reducing the rotating weight, allowing spooling to occur quicker with a given rate and amount of gas flow, as well as new developments such as the VATN turbo. Ceramic bearings allow newer turbos to run cooler and more easily, and impellor and turbine designs are improving.
Better cooling systems mean today's turbocharged engines such as Nissan's 200sx are no longer less reliable than their naturally aspirated cousins. And there are a lot of turbocharged engines sold today. Contrary to popular belief, supercharging is not making a comeback. Turbocharging is bigger than supercharging in every way, worldwide. Audi's A4 and A6, Bentley's 'turbo R', BMW's 745i, Ferrari's F40 and GTO, Ford's Cosworth Sierra and Sapphire, Mazda's RX-7, Mitsubishi's GSR, 3000GT and 300ZX, Nissan's GTR, Porsche's 911, 930, and 944, Saab's 900 and 9000 series, Subaru's Liberty RS and WRX, Toyota's Celica GT4, Supra, Soarer, and MR2, are all turbocharged, and that's not even including the racing cars. At the extreme end of performance, BMW's Brabham F1 cars produced over 1300bhp from 1.5 litres using turbos in 1985. That is approximately 15 bhp per cubic inch. In contrast, Top Fuelers running on a supercharged mix of alcohol and nitro methane produce approximately 10bhp per cubic inch from their engines. I quote from Engineer and proprietor of BEGI, Corky Bell ".. that the champion is crowned is obvious even to casual observers".
The fact that turbochargers are exhaust gas driven brings with it advantages as well as disadvantages. Put simply, a turbo can provide an engine with maximum boost earlier in the rev range than a supercharger can. The only exception to this is if the supercharger is overdriven to yeild greater boost pressure at a given rpm, or in the case of a centrifugal supercharger which may provide less boost at low rpm than a positive displacement blower on which the boost model below is based. It should also be noted that overdriving a supercharger increases the supercharger's already significant drag on the engine.
Because of the direct drive nature of a supercharger, flow and pressure generated by the supercharger increases in direct proportion to crank and hence engine revolutions. If an engine redlines at X rpm, the maximum boost (Z) that the engine will tolerate will also be set to coincide with X rpm, so that you are neither losing performance or damaging the engine. This means that at half X rpm, boost pressure from the supercharger will also be half Z of the total available. This is a disadvantage compared to a turbocharger as a modern turbo correctly sized to an engine can reach Z boost pressure by half X at the very latest. What this means is that if an engine redlines at 6000rpm and is supercharged at 6psi (a common figure), the engine is receiving 6psi boost only at 6000rpm. At 3000rpm the engine will receive induction air at only 3psi, and at 3500rpm would have 3.5psi boost. On an engine with a 6000rpm redline, a modern correctly sized turbo on the other hand will be at full 6psi boost by 3500rpm, which translates to greater torque from the increased boost and hence greater power at 3500rpm than the supercharged engine would have at 3500rpm from only 3.5psi, or just above half boost.
Old Dec 24, 2002 | 05:43 PM
  #78
Wicked1's Avatar
Wicked1
As mentioned before, a supercharger is crank-driven while the turbocharger is exhaust gas-driven. The drive method itself provides a further set of advantages and disadvantages. I've already mentioned the lag phenomenon - how at the application of throttle, the engine responds at first only as a normally aspirated engine before the turbo spools, increasing manifold air pressure and engine torque. The advantage to being exhaust gas-driven however, is that the exhaust itself is largely wasted energy. A lot of energy in the form of heat escapes the engine completely unused, and the turbo goes some way towards fixing this. At the same time however, the turbo presents a restriction to the exhaust flow, which results in backpressure. However the loss in power from this backpressure is minimal, especially compared to the direct and substantial power loss caused by a supercharger's load on the crankshaft. The detrimental effects of the turbo on exhaust gas flow can be reduced further by arranging the turbo to reflect pressure waves and assist exhaust port scavenging in the same way that normal tuned-length extractors function.
Old Dec 24, 2002 | 06:37 PM
  #79
robl45's Avatar
robl45
Seems that stillen has been using vortech superchargers, does anyone know if the stillen kit will be roots type supercharger or vortech?
Old Dec 24, 2002 | 06:44 PM
  #80
TJZ's Avatar
TJZ
i was under the impression that stillen and vortech were synonymous (sp?). So I would guess whichever is used in their typical setup is what you will see. I'm sure that site with the 350z artical probably says. But im not as nice as VQracer so i wont look it up for you guys (even though it's christmas eve). However, stillen has earned itself quite the bad reputation. If anyone was to SC (which, for that money, id suggest to go ahead and TC but that's a whole other story), I would recommend getting something from a different manufacturer.
