Dynoed today...tuned myself!!!
Old Oct 5, 2005 | 08:23 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Talking Dynoed today...tuned myself!!!
i finally got my car on the dyno today, wanted to see what kind of power i was putting down and wanted to dial in the timing...(keep in mind, i was running off of a street tune since i installed the EU)
so, I did all the tuning myself with the EU software...unfortunately, something happened this morning (go figure ) where i couldn't log the A/F...so that kinda made things more difficult than they needed to be, even with that hurdle, got the A/F dialed in pretty close and made 100 more hp and 100 more ft lbs of torque from 4500-5500rpm!!!!!
Final product:
552 rwhp
548 tq
@ 15.5 psi (stock heads/stock cams)
also noticed, the coolant temps never got over 205-210...then after a pull would QUICKLY drop to 195!!! impressive new 3" exhaust really helped solve the coolant temp issue, as before, on the dyno, my car was reaching 220-225 and it would take a minute or two to drop below 200!!!
check out the dyno sheets:
kind of faint lines, look really carefully, the lines are there
comparison... the red line is the first pull this morning, prior to any tuning, the blue line is the final product:
not too bad for an beginner tuner
Old Oct 5, 2005 | 09:12 PM
fernandito7's Avatar
fernandito7
congrats those are awesome numbers.
Old Oct 6, 2005 | 04:05 AM
gringott's Avatar
gringott
Very nice.
Old Oct 6, 2005 | 04:35 AM
Mike Wazowski's Avatar
Mike Wazowski
nice job
Old Oct 6, 2005 | 04:41 AM
southern_info's Avatar
southern_info
Very Impressive numbers. I envy those over 500+ because I only could imagine what it feels like to have that pushing you into the seat. Good Job!
Old Oct 6, 2005 | 04:43 AM
Gman2004's Avatar
Gman2004
Very nice Todd! Congrats! Do you think your old exhaust contributed to blowing your 1st built motor?
Old Oct 6, 2005 | 04:56 AM
mcderns's Avatar
mcderns
Nice job!
Old Oct 6, 2005 | 06:08 AM
Cronic's Avatar
Cronic
Congrats man, that is some great power!
Do you happen to have any logs handy of these dyno pulls? I am curious to see a few things.
Old Oct 6, 2005 | 07:05 AM
g356gear's Avatar
g356gear
Nice A/F curve.....smooooooth What did you end up with for a timing curve???
Old Oct 6, 2005 | 07:57 AM
Barzten1's Avatar
Barzten1
Thats good power!
Old Oct 6, 2005 | 07:58 AM
theking's Avatar
theking
Great numbers. Any plans on heads and cams? These graphs are a perfect example of how the stock heads and cams run out of steam past 5500rpm's. All that torque has got to be addicting.
Old Oct 6, 2005 | 08:28 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 - nice tuning...do you dial in the a/f across the board or did you use that target a/f feature on the emu?
Old Oct 6, 2005 | 08:33 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
dilaed it in...the ol fashion way
lane myers's Avatar
lane myers
good ****. very impressive.
Old Oct 6, 2005 | 08:42 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
ummm, i think that the original design arias pistons fractured the middle ringlands because they were substandard, poorly designed turbo pistons...
i do think they WILL work on a F/I setup, just not for the type of power or abuse that i love to inflict...
I'm sure the engine temps (coolant) didn't help the situation, now things are much cooler, and the pistons are MUCH stronger...
watch out in the future for my next motor...darton sleeved, same forged internals, cams, and headwork...700-800rwhp..here i come (gimme a couple of months)
Old Oct 6, 2005 | 08:43 AM
D350Z10's Avatar
D350Z10
Great job .. are you planning on opening up your own shop or somthing?
Old Oct 6, 2005 | 08:44 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
that will be on my next motor..then while this current motor is out, i'll sleeve this one as well and beef up the heads/cams...and have a back-up
Old Oct 6, 2005 | 08:47 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
hahaha, got my own shop in my garage..coming soon, thread: tour of my home garage!
Old Oct 6, 2005 | 09:04 AM
g356gear's Avatar
g356gear
Crackin peoples backs by day.......crackin your own knuckles by night.
Old Oct 6, 2005 | 10:26 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Good work Todd. The power is leveling off a little too soon...but granted...you have stock cams and heads. That is probably as much timing as you can run, without using higher octane fuel.
Oh, and easy on those Arias pistons. I am using the same "sub standard" design as you put it. I think the first piston broke, clearly due to detonation. Yes, the extreme duty Arias pistons can hold up to more abuse. But I dont exactly drive like Miss Daisy, and I am using the older design at 600whp+....no problems whatsoever. In the vast majority of cases, engines break due to poor tuning, or failure or weakness in a sub system...such as oil, cooling, injectors, fuel pump, boost controller etc.
That said, our next motor will have Darton sleeves, and the Arias Extreme Duty pistons.
