Turbo Size
Old Oct 10, 2005 | 07:53 AM
350ZLO's Avatar
350ZLO
Default Turbo Size
Ive been looking all over and i cant find what size APS uses for theri turbo and twin turbo set ups....does any one know...they look like 16 or 20g's but im not positive. i am thinking about going turbo but cant decide between singel or twin...plead your case so i can make my decision easier...thanks
Old Oct 10, 2005 | 09:12 AM
002-M-P's Avatar
002-M-P
I don't remember the exact size of the APS turbos used in their TT kit, but it is not a mitsubishi turbo (meaning it is not and "g" size as in 16g or 18g). Their turbo is a Garrett turbo that is custom spec'd for APS, but I will let someone else tell you what turbo it is sized close too, i just can't remember. But they are smaller than 18g's which are what are used on the Greddy TT kit.
Old Oct 10, 2005 | 09:22 AM
g356gear's Avatar
g356gear
The APS turbo is a GT35 series, water cooled, ball bearing unit. Very nice piece.
Old Oct 10, 2005 | 09:26 AM
002-M-P's Avatar
002-M-P
Thats for the single turbo though right? What were the sizes of the twins again?
Old Oct 10, 2005 | 09:44 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
The APS TT uses two GT35/28R turbos, custom made for this kit by Garrett.
I am not sure what the APS single uses, i'd have to check.
Old Oct 10, 2005 | 03:22 PM
mchapman's Avatar
mchapman
I believe APS use twin GT25/35R turbos with their out of the box TT kit.
GT25 turbine with a GT35 compressor not the other way around.
Dont know the exact specs with regards to A/R etc.
Old Oct 10, 2005 | 03:38 PM
Brandon@Forged
Originally Posted by mchapman
I believe APS use twin GT25/35R turbos on their out of the box TT kit.
GT25 turbine with a GT35 compressor, not the other way around.
Nah, I researched every turbocharger kit and have most of the specs, here's APS TT's..
Air Power Systems (APS) Twin Turbocharger Kit
Price: $7,450
Installation Time: 20 – 30 Hours
Power (at the wheels): 420HP @ 9 PSI
PSI: 8 PSI
Turbocharger(s): Garrett GT3528R Dual-Ball-Bearing Water-Cooled Turbocharger (custom made for APS) with Air Power Systems (APS) Internal Wastegates
Intercooler: Air Power Systems (APS) DR Series Bar & Plate Air-Air Front-Mount Intercooler
Fuel: Air Power Systems (APS) Return Fuel System (Rubber fuel lines, Walbro 255lph in-tank fuel pump, (6) 500cc fuel injectors, Air Power Systems (APS) fuel pressure regulator)
Engine Management: Unichip Piggyback Engine Management
Exhaust Manifold: Air Power Systems (APS) Iron Cast Log-Style Exhaust Manifold
Piping: Polished Stainless-Steel and TIG welded intake and turbocharger discharge
Air Intake: Air Power Systems (APS) Air Filters
Blow-Off Valve: Air Power Systems (APS) Twin-Vent Blow-Off Valve
Oil Pan: Air Power Systems (APS) Oil Pan
All necessary parts are included.
Peter mentioned the turbo size in one of his old threads when people had asked about it, i'd have to find it again.
Old Oct 10, 2005 | 03:50 PM
mchapman's Avatar
mchapman
It has been mentioned by Peter before and I believe its been GT25/35, if it is GT28/35R now then it has changed.
Here are two articles off the APS website which mention the turbo sizes.
http://www.XXX.com/350z/motor_hot_tuner/evilzed2.htm
http://www.XXX.com/350z/fastforus/exclusive_cargo2.htm
Replace XXX with air power systems.
Old Oct 10, 2005 | 04:36 PM
Brandon@Forged
Well, apparently I am wrong. I thought I had seen Peter say that somewhere, maybe I was mixed up.
Old Oct 10, 2005 | 04:42 PM
D350Z10's Avatar
D350Z10
The aps turbo are not mitsubshi turbos so they are not measured by "G", I would guess the aps turbo is around small t4. Its a garret custom turbo. Greddy uses all mitsubshi turbos. Did you know that the srt-4 turbo is a mitsubshi turbo, the srt-4 engine is very similar to the 95 eclpise!!! Quick fact!!! lol
Old Oct 10, 2005 | 07:18 PM
350ZLO's Avatar
350ZLO
i knew they werent G's but i just compared it to those for the simple fact that i know abut those cars and those turbos more than any other just b/c all my friends have EVO's and thats all we talk about, i was just thinking of something comparable
sales@czp
Sep 23, 2019 03:30 PM
