Vortech = low torque? Riiiiight. 451hp/368tq Dynos inside!
Old Oct 11, 2005 | 07:41 AM
barthelb's Avatar
barthelb
Master
Lets see if this theory holds true then,
Does your car have between 30k - 50k+ miles on it. I noticed once i hit around 40k, everything starting to loosen up a bit and produce more power. I however wasnt boosted til nearly 30k miles.
So, how many miles are on your Z?
Old Oct 11, 2005 | 07:58 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Great numbers, that is one torquey s/c Z! I would love to see a video of your car going through the gears, either from outside or inside....
Old Oct 11, 2005 | 08:32 AM
mcduck's Avatar
mcduck
More comments...
Originally Posted by kzanard
Do you still have the SS box and stock injectors? (I checked your mods and no mention of fuel setup).
Yes, SS box and stock injectors. The next two mods I'm looking at are a fuel system upgrade and an aftermarket LSD.
Your theory is safe! I will turn over 40K this weekend. I've had most of the NA mods since 8K miles and the SC since 16K miles.
I'll see what I can do about that. I'll be at Tail of the Dragon this weekend and hopefully will get some runs in with an external camera mounted.
Old Oct 11, 2005 | 08:45 AM
Nano's Avatar
Nano
you need to correct you sig
awesome numbers... inspirational
Old Oct 11, 2005 | 08:47 AM
zachcrosen's Avatar
zachcrosen
Originally Posted by mcduck
More comments...
Cant wait to see your Z this weekend. I will be there as well. I finally got everything worked out after taking mine to CP Racing. BTW, congrats on your new numbers. Amazing!
Old Oct 11, 2005 | 09:19 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I would be careful with the stock injectors at that power level...they are definitely running at a VERY VERY high duty cycle.
Old Oct 11, 2005 | 10:21 AM
mcduck's Avatar
mcduck
I know... thing I've wondered and which no one has been able to answer is at what point am I hitting a VERY VERY high duty cycle? I mean, if I'm only hitting it, say, from 6200rpm up, I'm not terribly concerned. On the other hand, if I'm hitting high duty cycle from 5000rpm and up, it's a much different story.
I think this is another area where maybe SC has an advantage over TT. Because your peak power is made at the end of our power band instead of somewhere in the middle, you can probably get away with taxing the fuel system this way.
Regardless, I agree with what you're saying and will be exploring some fuel system solutions over the winter.
Nano what's wrong with my sig??? It shows the numbers I'm running now.
Old Oct 11, 2005 | 11:07 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Bastard.
Now I have to go back. So you gutted your cats and added the clutch and flywheel, right?
Bastard.
Old Oct 11, 2005 | 12:17 PM
mcduck's Avatar
mcduck
Gutting the cats was not really by choice. I had one empty and had to make the other one match.
I'll be waiting for you to catch up again, Jeremy!
in the meantime, mcduck has some powder coating to do to his strut bar and hood brace...
Old Oct 11, 2005 | 01:54 PM
prescience's Avatar
prescience
Superb numbers BTW; green and jealous.
Yes I agree, since you run at peak power (hence strain on injectors) proportionately for a very low percentage of the time vs TT.
Old Oct 11, 2005 | 02:44 PM
Nano's Avatar
Nano
I thought you where running 457
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Also keep in mind that to acheive this power, the Vortech system is running well over 100psi of fuel pressure through stock lines and injectors...its close to 120psi at redline. So although the injectors may not be hitting 100% duty cycle until you approach redline, there is extreme stress on the injectors, lines, etc..due to the excessively high fuel pressure. Industry standard is 42.3psi, and anything above about 70psi of fuel pressure is getting into the danger zone.
But wow...great numbers Andy....and nice work by Eric and his team
Old Oct 11, 2005 | 04:44 PM
ThetunerFestNJ's Avatar
ThetunerFestNJ
So what you are saying is the car is running on the brink of disaster?Is that safe running 120psi of fuel pressure?
Old Oct 11, 2005 | 05:07 PM
Sharif@Forged
Forged Performance
Well, safe is a relative term. It is safer to run at 45psi of fuel pressure at 80% duty cycle. A return system is $999 plus the cost of the injectors ($530), so it is a more expensive option, and not everyone wants to spend that kind of money for the better setup.
Since I imagine McDuck isnt running at 100% duty cycle all the time, the kit is safe during normal operation anyways.
Old Oct 12, 2005 | 05:50 AM
mcduck's Avatar
mcduck
Bottom line is I need to upgrade my fuel system. I'm aware of that and have talked to Sharif about this in the past. I just haven't gotten around to it yet. Hopefully it's one of the projects I can work in over the winter. With any luck, I won't have any issues before that happens.
NANO: My car did hit 457/380 numbers, but that was prior to dialing the timing back. The numbers in my sig represent the tune that is actually on the car now.
Old Oct 12, 2005 | 06:04 AM
ThetunerFestNJ
Just be real carefull running the injectors at that level,I would hate to see anything happen to your motor after all the hard work...What size injectors you running?
Old Oct 12, 2005 | 06:37 AM
mcduck's Avatar
mcduck
Stock
Old Oct 12, 2005 | 07:22 PM
  #38
MMC Racing's Avatar
MMC Racing
I am speechless. I'm waiting at CPRacing as they tune my car and am talking to my buddy Bryan (Sloe Truk) about the pending weekend at Tail of the Dragon when mechanic Matt (there are 2 Matts at CPRacing) motions for me to step into the back.
Does Sloe Truk have a Lightning? I think I know him from the Lightning forums..
-Mark
Old Oct 13, 2005 | 11:20 AM
  #39
Nealoc187's Avatar
Nealoc187
120psi of fuel pressure? Yikes that is tempting fate in my book. Awesome number you put down. I'd be leary of boosting with that kind of FP though.
Old Oct 13, 2005 | 02:11 PM
  #40
sentry65's Avatar
sentry65
the burninator
by chance have any 1/4 mile times with the vortech being that strong? With street or drag tires?
