rc 560 injectors and aps actuators?
ruffly how much power do you guys think i can squeeze out of the aps actuators and would it be safe to take them to the max?
im building my engine now with pauter rods and cp pistons 8.5.1. was wondering what you guys think i can sqeeze out of the engine.. also does anyone know where i can send my heads to get them ported for a good price?
thanks
thanks
I squeezed 470whp with built motor (8.5:1 pistons, cams and aps plenum) and stock aps fuel system with upgraded wastegate acuators.
I am in the process of upgrading the whole fuel system with 1000cc injectors.
If you motor is out you might as well upgrade the actuator and upgrade the injectors to 650's. Changing the actuators while the motor is out will be easier and less expensive.
Who is building your motor? Didn't you go with SGP? SGP can do the port and polish.
no im not going with sgp but wishing i did and i had a typo.. i meant 650 injectors... also being that i have the 300hp rated engine.. i think im the first with a built engine and there is no info about the cams and such so im kinda worried... im heading into uncharted teritory
I would guess that the 650's would be good for around 700whp. Sharif made 622whp with his 550's. I think by the time that you get your motor back APS should be selling that actuators. They will come with the new tuner kit. If they are not available you could always get the custom one that everyone else is getting from torqe freaks.
sweet!. so anyone know about the headwork? also would it be a good idea to do headwork without cams and sleeves? realisticly 700whp is def enough for me.. at least i think it will be.. do you think ill get there with just actuators and injectors?
470 is low - what PSI and are you running stock cats?
I am having my lower end built right now - 8.8:1 pistions and will be shooting for 500-525 at 12 psi. I am putting in 10 lb actuators, have UR crank pulley, plenum, test pipes, and APS exhaust
I believe it was around 11psi and we were running out of fuel. Remember I am running low compression pistons (8.5:1) with metal head gaskets.
There is definetly ALOT more left in this motor, we just need the fuel!
This still seems low. dropping to 8.5:1 shouldn't make that much difference. Did you lower compression through the head gasket or did you dop lower compression pistons in, both? Also, are you running stock cats?
paranormal-
It seems like there are so many more choices available now. If I had it to do over again, I'd buy 9:1 extreme Duty pistons. The Pauter rods are doing the job, but there are lighter rods out. I would also upgrade the actuators and cams/springs while the engine is apart. Good Luck,
Bruce
Bruce
where did you get your actuators? what are all the options for actuators?
im gonna stick with the pauter rods and cp pistons.. cause i already payed for them..haha
thanks
thanks
I got the Garrett actuators from Jason at TorqueFreaks, here in Portland. His number is (503)546-9900. I also just spoke with Kelly at Perfection Motorsports in nearby Hillsboro, and he said they have succesfully fabricated EXTERNAL wastegates for the APS kits. His number is (503)848-2707. Good luck.
Bruce
Bruce
