Vortech S-Trim w/dyno
Old Oct 25, 2005 | 02:08 PM
kevinapex's Avatar
kevinapex
Default Vortech S-Trim w/dyno
I got the S-Trim impeler upgrade back from Vortech, and went to Mathews in Longmont Co, for tune, They have a Mustang dyno (only been on Dynojet befor today) After about 25 runs it looked good on paper, A/F good 392 rwhp with tq @ 321. 10 psi.
My last DynoJet before impeler and Crawford headerswas about 398hp so I didn't think too much, but road test made me think otherwise!!! Wow.. I'm happy for now.
Old Oct 25, 2005 | 03:00 PM
prescience's Avatar
prescience
Glad you're happy
Old Oct 25, 2005 | 03:27 PM
D350Z10's Avatar
D350Z10
Congrats on your numbers!!!! Are your headers heat wrapped by any chance?
Old Oct 25, 2005 | 04:03 PM
booger's Avatar
booger
Kevin...good to see more guys upgrading the blower . Im surprised you didnt get more boost from it . Time for the 2.87 pulley , your not even close to its max rpm rating . Are you going back to your Dynojet to compare ? Bet your in the 450whp range
ooops..edit...I miss read your post . Though it was a T-trim . You still ended up with great hp on a Mustang dyno
Old Nov 29, 2005 | 05:47 PM
QuadCam's Avatar
QuadCam
The S-trim is a nice upgrade to the V2. Isn't the Sc-trim a slightly cut down S-trim.
I think they both have the same overall output and flow, but the S-trim can do it at lower impeller speeds. Basically, you'll get more boost using the same pulley that you were using with the sc-trim.
I did the same upgrade on a V1 when I had a blown 96 cobra. It was good for 536 rwhp at only 10.5 psi (6200 rpms)
Old Nov 29, 2005 | 06:03 PM
booger's Avatar
booger
Ive upgraded to the T-trim blower . Working on getting up to 16psi . Was at 13.2psi , but the IC that comes with the kit is way small and to much back preasure betwwen IC and blower is to high and belt slips no matter how tight I got it
Old Nov 29, 2005 | 06:55 PM
sentry65's Avatar
sentry65
the burninator
how does the T-trim or S-trim power curves look?
do they start looking a little exponetial or are they still linear?
Old Nov 30, 2005 | 04:40 AM
kevinapex's Avatar
kevinapex
S-trim is very linear, power comes on smooth and continues through red line.
Old Nov 30, 2005 | 04:43 AM
booger's Avatar
booger
Same with the T-trim . You just get more booost sooner and it builds all the way to redline
Old Nov 30, 2005 | 05:02 AM
Mike Wazowski's Avatar
Mike Wazowski
great numbers
Old Nov 30, 2005 | 08:44 AM
captj3's Avatar
captj3
Great numbers you can add 10 - 12% that will give approximatly what they would be on a dynojet.
Old Nov 30, 2005 | 06:48 PM
ryan350z's Avatar
ryan350z
Awesome Kevin so everything worked out great for you and your s-trim. I have mine on and compared to my friends coupe with the sc vortech I leave him about 3 cars back when we go at it. Major difference my boost comes on so much quicker. I am going to upgrade to the 2.87 and see what I can get right now i am on the 3.13. I need to get on the dyno better than street tuning with the e-manage.
ryan
Old Nov 30, 2005 | 07:02 PM
QuadCam's Avatar
QuadCam
how much was the upgrade to the s-trim impeller?
Old Nov 30, 2005 | 07:40 PM
DBZCat's Avatar
DBZCat
I need some internals first.....
Old Dec 1, 2005 | 05:14 AM
booger's Avatar
booger
Cat...Did you get your car back ? Hows it running , did every thing work out ok with the modifications ?
Old Dec 1, 2005 | 08:20 AM
acg's Avatar
acg
I did not see an answer but how much is the s-trim upgrade.
Old Dec 1, 2005 | 08:30 AM
ryan350z's Avatar
ryan350z
i am not sure of the cost of the upgrade as I had an extra CCW s trim to try out. I still have my SC trim supercharger. I think Kevin once said it cost in the area of 150-250
Ryan
Old Dec 1, 2005 | 09:16 AM
acg's Avatar
acg
Wow that is cheap, I heard that the T-trim was like a 1000 so there seems to be a large difference, what is the turnaround time as I may just send mine in.
Old Dec 1, 2005 | 01:55 PM
QuadCam's Avatar
QuadCam
the sc-trim is eseentially an s-trim impeller that they cut down. I think that is right. Overall, they both produce the same flow and boost levels, but they have different rpm ranges. The sc-trim can be spun a bit higher (makes sense if it is lighter and a cut-down s-trim).
A t-trim wheel has different dimension than the sc- or s-trim wheel, that is why it is so much more to upgrade.
Old Dec 1, 2005 | 02:16 PM
booger's Avatar
booger
The T-trim has a different housing too . It has a bigger air inlet...4 inches
