Bline Air Intake Manifold
Old Oct 28, 2005 | 02:17 PM
etrkilla's Avatar
etrkilla
Default Bline Air Intake Manifold
Anybody have any info about this product from Bline Motorsports? I saw this picture on thier website while looking at thier oil cooler kit. It
Old Oct 28, 2005 | 02:23 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Whoa what the hell is that? It almost looks like its made of copper or something. lol. Why is it so crudely made? Is it still in R&D?
Old Oct 28, 2005 | 06:52 PM
turbo-maxima's Avatar
turbo-maxima
website?
Old Oct 28, 2005 | 07:05 PM
g356gear's Avatar
g356gear
Originally Posted by turbo-maxima
website?
http://www.blinemotorsports.com/products.html
Old Oct 28, 2005 | 07:11 PM
Zexy's Avatar
Zexy
Thumbs down
That **** is ridiculously huge. Absolutly no power gain with the size of that thing and that throttle body. Doesn't even have space for piping. I'd rather use it for a party salad bowl.
Maybe for a serious FI set up with a huge snail and LOST of boost.
Old Oct 29, 2005 | 06:01 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
AhHA i have to agree with Zexy, but i'd use it as a chip bowl. Just look at those velocity stacks, perfect for dips. Kidding aside, it looks way to big, but i'd still like to know the gains.
Old Oct 29, 2005 | 06:33 AM
KwanZito's Avatar
KwanZito
That thing looks insane though, some dyno ##'s on that would definitely be interesting to see.
Old Oct 29, 2005 | 07:39 AM
g356gear's Avatar
g356gear
Don't be so quick to judge....a high volume plenum is ideal for F/I applications.
Old Oct 29, 2005 | 07:43 AM
etrkilla's Avatar
etrkilla
Agree. If the higher plenum, plenum spacer and the Kinetix SSV manifold increase Hp and airflow why wouldn't this manifold make power?
Old Oct 29, 2005 | 08:10 AM
phunk's Avatar
phunk
CJ Motorsports
IMHO its ugly as sin, but its not the worst design I have seen in the VQ35 world... it might actually work OK, but tons of room for improvement.
Old Oct 29, 2005 | 08:41 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
it may look ugly, but look at the air horns or velocity stacks inside, they come up into the middle of the chamber, so even though its huge, it may have some good air flow and charge properties, that may benefit the motor well. Only testing will prove it tho...
Old Oct 29, 2005 | 09:00 AM
mario60185's Avatar
mario60185
Chicago Realtor
what have u guys heard about those velocity stacks?
Old Oct 29, 2005 | 02:50 PM
overZealous1's Avatar
overZealous1
one thing i don't like about it is the fact that the velocity stacks are not at the same angle as the lower manifolds runners at that point. the lower manifolds runners are at a 45 degree angle right at that point, so having the velocity stacks pointing straight up makes for a sharp 45 degree turn and huge amounts of cavitation on the slow side of the runner. a couple after market intakes are this way. yes, a large plenum volume is great for f/i, giving each runner plenty of volume to draw from.
i am very interested to see what altered atmoshpere is going to do to the stock middle plenum as i believe that still will have the straightest runners and making the smoothest path possible to the valve pocket. might loose a little torque but should give good mid and top. https://my350z.com/forum/forced-induction/150184-little-sneak-peak-at-some-r-and-d-guess-what.html
Old Oct 29, 2005 | 03:39 PM
Zexy's Avatar
Zexy
Read my last sentence on my last post
Old Oct 29, 2005 | 03:41 PM
Zexy's Avatar
Zexy
Originally Posted by overZealous1
might loose a little torque but should give good mid and top. https://my350z.com/forum/showthread.php?t=150184
Yeah, benefit at 18000 RPM if the VQ35 ever revved that high There is absolutley no benefit for NA application. Look at the size of the throttle body as well.
So if a huge size plenum was really a benefit we should fabricate a plenum the size of Yankee Stadium?
Old Oct 29, 2005 | 07:56 PM
phunk's Avatar
phunk
CJ Motorsports
Actually its closer to a 30 degree angle, and the runners are not pointing parallel either.
The stock piece is a decent starting platform, but you will still never get perfection from it, as even IT does not quite properly match angles with the runner section. Close, but no cigar. However I bet you could make an affordable alternative out of it, thats for sure.
Just got home from the shop, we just finished construction of our 2nd prototype. Test fitting probably next weekend, and a lot more to do after that. Probably have something that I can show off in a month... but ours isnt gonna be quite so inexpensive, under $1500 tho :shrug:
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
