In the process of doing a compression test
Old Oct 29, 2005 | 09:21 AM
Gman2004's Avatar
Gman2004
Default In the process of doing a compression test
I pulled one of my plugs and it was covered with oil. I don't know the cylinder number, but it is on the driver's side closest to the radiator. This is the best picture I could get with my camera phone. My digital camera got fuked up last week. Does this mean I blew some ringlands?
I'll post the compression test results when I complete them. Which is the fuel pump fuse? I know it is by the battery, but it is not labeled.
Attached Thumbnails In the process of doing a compression test-10-29-05_1310.jpg   In the process of doing a compression test-10-29-05_1311.jpg
Old Oct 29, 2005 | 09:55 AM
Gman2004's Avatar
Gman2004
Here is the spark plug that came out of the driver's side closest to the firewall. Look at how much oil is on it.....it is dripping of the plug.
Attached Thumbnails In the process of doing a compression test-10-29-05_1351.jpg
Old Oct 29, 2005 | 11:22 AM
booger's Avatar
booger
When I broke the ringland on my stock motor . The piece that broke off , got lodged in the valve and that cyl. wouldnt fire . No oil all over the plugs . Does the radiator have oil in it ?
Old Oct 29, 2005 | 11:37 AM
Gman2004's Avatar
Gman2004
no oil in radiator.
so far these are the compression test results.
1. 125
2. 115
3. 110
4. 125
5. 115
So far compression looks good. I am going back outside to do cylinder number 6.
I spoke to CPrace and they think the valve cover seal and oil rings might have gone and the oil is passing through causing that side of the motor not to fire.
Old Oct 29, 2005 | 11:41 AM
booger's Avatar
booger
With oil in all the cyl. , I wouldnt think it's a ringland . Shouldnt compression be higher...dont know
Old Oct 29, 2005 | 11:45 AM
Aquineas's Avatar
Aquineas
Probably not with lower compression pistons, which I'm assuming he has.. uh, right?
Old Oct 29, 2005 | 11:47 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Waiting for #6....
Old Oct 29, 2005 | 11:50 AM
TK2005's Avatar
TK2005
I am not sure what the compression is supposed to be with your set up but most of the VQs we have done CTs on were near 160.
Old Oct 29, 2005 | 11:55 AM
Sharif@Forged
Forged Performance
Stock compession VQ's are going to have compression test numbers in the 160-200 range. Less than 160 is considered bad, but most stock motors compress at 180 or greater.
Low compression motors (8.5:1) are going to pressure test at about 120-160. The important thing is the variance between the cylinders.
1-5 arent terrible....which is why I am waiting for the #6 cylinder. CT results can vary based on the amount of oil in the cylinder, and the temp of the cylinders.
Old Oct 29, 2005 | 11:57 AM
Gman2004's Avatar
Gman2004
dun dun dun.....#6 was 120.
Old Oct 29, 2005 | 12:04 PM
JETPILOT's Avatar
JETPILOT
Do you realize your kid wrote F*ck in street slang on the refrigerator door? You have worse problems than your motor if you kid is writing "***" on the refrigerator door!! I hope a little humor will lighten up your situation there. But seriously... talk to your child !!
Profanity On Refrigerator Door
Respect
JET
Old Oct 29, 2005 | 12:05 PM
G352NV's Avatar
G352NV
Wow looks like this might be a easy fix! DONT SELL IT! Maybe it was just something over looked.
Old Oct 29, 2005 | 12:09 PM
Gman2004's Avatar
Gman2004
Originally Posted by JETPILOT
Do you realize your kid wrote F*ck in street slang on the refrigerator door? You have worse problems than your motor if you kid is writing profanity on the refrigerator door!! I hope a little humor will lighten up your situation there. But seriously... talk to your child !!
Respect
JET
Thanks Jet. That definatley cheered me up a little. Here's the little devil.
Attached Thumbnails In the process of doing a compression test-jasmine-chuky.jpg
Old Oct 29, 2005 | 12:14 PM
tig488's Avatar
tig488
what symptoms are you experiencing with the car?
Old Oct 29, 2005 | 12:28 PM
Gman2004's Avatar
Gman2004
whitish/grey smoke blowing out of the driver's side tail pipe, backfiring, and runs like chit!
Old Oct 29, 2005 | 12:30 PM
G352NV's Avatar
G352NV
Hmmmm
Attached Thumbnails In the process of doing a compression test-sparkplugchart.jpg
failsafe306's Avatar
failsafe306
I was gonna mention the "***" on the fridge door too but Jetpilot beat me to it lol.
Old Oct 29, 2005 | 12:33 PM
Sharif@Forged
Forged Performance
Gman...honestly...I dont think you have a cracked ring land. In most cases, a cracked ring is going to show no compression or very little compression in the offending cylinder. Yours are relatavely steady accross the board. With a shot of oil, or a hotter motor, you numbers would be a bit higher.
Oil is getting to the cylinder from somewhere..maybe a leak valve stem seal? How did the intake tube to the throttle body look?
Old Oct 29, 2005 | 12:39 PM
Gman2004's Avatar
Gman2004
Originally Posted by G352NV
Hmmmm
Look under oil deposits. Those are my symptoms, but my compression is good so probably not the ringlands.
Sharif,
Not much in in the intake tube or throttle body. There was some crud in the intake tube around the blue rubber conectors....looked like white dirt. It was not oily, but like a fine dust. Nothing crazy though.
Old Oct 29, 2005 | 12:41 PM
Sharif@Forged
Forged Performance
Change all your plugs and gently drive the car...see how it runs.
The plugs may have gotten so fouled they were not even firing.
