Exhaust for Turbonetics
Old Nov 17, 2005 | 04:07 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by 35ounces
+1 fabricate a reverse-Y or an adapter so you can use the Stillen.
damn you Mia, you beat me to every post!
LOL.... you gotta be quick...
Old Nov 17, 2005 | 04:08 PM
Gumpdriver's Avatar
Gumpdriver
So keep the stillen exhaust ,get the reverse Y-pipe made and it should put down better numbers. I know TurboNetics says that the stock exhaust has more HP gains over aftermarket. So why do you think the Stillen would put down better numbers?
Old Nov 17, 2005 | 04:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Everyone that has posted before and after dynos has shown an increase in power somewhere with a aftermarket exhaust that is either dual modified or 3" back.
Old Nov 17, 2005 | 04:12 PM
DBZ33's Avatar
DBZ33
I don't understand why TN would say that the stock exhaust would be better. I understand why the stock manifolds are better for turbo lag but I don't see why stock exhaust would be better than a good 3" turbo exhaust.
Old Nov 17, 2005 | 04:18 PM
Gumpdriver's Avatar
Gumpdriver
OK, so keep the stillen how about back pressure , i thought it is better to have a little more back pressure. MIA what kind of Exhaust do you have?
Old Nov 17, 2005 | 04:20 PM
MIAPLAYA's Avatar
MIAPLAYA
I have the Apexi WS2 exhaust.
Old Nov 17, 2005 | 04:21 PM
mojo powered's Avatar
mojo powered
that's something I didn't understand either.. I bet they're talking about a Nismo style 3" with a dual tip canister...
I can see how that can create similar back pressure to stock whereas a straight through like the JIC Spartan would make more power from more free flow and no bends.
Old Nov 17, 2005 | 04:40 PM
Gumpdriver's Avatar
Gumpdriver
OK, so even though it is a true dual there should be enough back pressure to make good power with a reverse Y-pipe
Old Nov 17, 2005 | 04:49 PM
mojo powered
with a turbo car, you want the least back pressure possible..
back pressure is only good for NA cars for low end torque
with a turbo, if you could have no exhaust at all, you'd make the most whp. But of course, it'd be loud as hell.. so you want to most free flowing largest diameter possible exhaust with the least amount of bends.
MIAPLAYA's Avatar
MIAPLAYA
No there will be LESS backpressure. In a turbo car backpressure is the enemy. YOU DON'T WANT BACKPRESSURE It is the DEVIL
Old Nov 17, 2005 | 04:50 PM
MIAPLAYA's Avatar
MIAPLAYA
Dammit....you're fast...I see I have a challenger
Old Nov 17, 2005 | 04:53 PM
Gumpdriver's Avatar
Gumpdriver
So just stick with the Stillen TD bacause it was a lot less back pressure than the stock.
Old Nov 17, 2005 | 04:55 PM
MIAPLAYA's Avatar
MIAPLAYA
Right...
Old Nov 17, 2005 | 05:04 PM
Gumpdriver's Avatar
Gumpdriver
I do not know why i am even asking these question my brother has an RX-7 and he picked up 30HP when he went 3" pipe all the way back. But thanks for info i guess i will not be saling the stock exhaust now.
Old Nov 17, 2005 | 05:10 PM
Zues350ztt's Avatar
Zues350ztt
Go 3-1/2 custom single exhaust that way you have less back pressure. Turbo's should run single exhaust anyways.
Old Nov 17, 2005 | 05:25 PM
DBZ33's Avatar
DBZ33
I had a TT Rx7 before and also had a big change in HP with just a down pipe and exhaust. Almost .6 tents off the 1/4. It is because the Rx7 has a very restrictive down pipe and exhaust system. The 350z has a pretty good stock system.
Old Nov 17, 2005 | 05:27 PM
mojo powered
hell yes you do
you were the one saying you gotta be fast.. but forgot one thing: there is always someone even faster
haha
on serious note, you can look at the turbo drag or any type of race cars, you'll notice how the exhaust plumbing is the quiest, largest and straightest possible, mostly right out of the turbo to the fender or underneath the car.
The faster you get rid of the exhaust gas after the turbo, the quickest it will spool, the better it will hold boost and the most power it will make. Backpressure is your enemy, there is not ifs or buts about it. Normally aspirated is a totally different story though.
Old Nov 17, 2005 | 05:30 PM
  #38
mojo powered
true.. the largest and the less bends the better. It's just how much of exhaust noise can you get away with. You gotta worry about in cabin noise and of course your city's best!
Old Nov 17, 2005 | 05:39 PM
  #39
Bubble's Avatar
Bubble
-REPLICA ARMY-
oh damn, then i need to change my exhaust. More money. Yike
Old Nov 17, 2005 | 05:41 PM
  #40
MIAPLAYA's Avatar
MIAPLAYA
Not exactly...any true dual can be modified to work...
