Maximum #'s seen from tnetics kit?
Old Nov 23, 2005 | 12:04 PM
DBZ33's Avatar
DBZ33
Originally Posted by MIAPLAYA
FYI: Heres a link to the dyno video:
http://clipshack.com/Clip.aspx?key=8400E40C6A84E35E
Does the Dynapack dyno show more or less than a Dyno Jet dyno? I always thought that the Dynapack showed less than the Dyno Jet.
Old Nov 23, 2005 | 12:18 PM
atar350's Avatar
atar350
Originally Posted by Mike@Altered
I've made 460rwhp and 530tq. with the standard Turbonectics kit, built motor, and our fuel system on a 350Z! To make more I'd suggest the 62-1 upgrade they offer.
Thats incredible power! Can you post a link to the dyno graphs, videos, pics? I always wanted the TNetics kit, and almost have this car paid off (reason I dont have it) but would love to go TNetics next year with a built motor and possibly 500+rwhp, appreciate any links.
Also, I used to have a VR4 and am a member at 3si.org, you guys have that orange stealth right? What are the plans for the ultimate VR4? If you can say
I am sure you have seen Ray's car with 830+AWHP right? Crazy stuff, I miss my VR4, lol....
Old Nov 23, 2005 | 12:28 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Dynapack always reads higher, it bolts right to the wheel hub, so it doesnt have to spin the weight of wheels/tires therefore higher numbers over a dynapack.
Stock I dyno'd 239whp on a dynojet A buddy of mine dyno'd 261whp stock on a dynapack...
Old Nov 23, 2005 | 12:35 PM
atar350's Avatar
atar350
That is alot of power lost thanks to the wheels and tires....
Old Nov 23, 2005 | 12:43 PM
MIAPLAYA's Avatar
MIAPLAYA
I've always heard the Dynapack was lower then then Dynojet because it is a load based dyno. I know it is considered one of the most accurate dynos due to its consistency and it being load based.
Old Nov 23, 2005 | 12:44 PM
MIAPLAYA's Avatar
MIAPLAYA
There will be all of this in the upcoming MOdified Magazine. It is their project car.
Old Nov 23, 2005 | 01:10 PM
turbo-maxima's Avatar
turbo-maxima
I think a BB t60-1 and even a t62 is too small. I am going to be running a T61 on my 3.0 liter max. You'll should be using GT40R's and BBT66 and 67's.
Old Nov 23, 2005 | 01:43 PM
MIAPLAYA's Avatar
MIAPLAYA
The 60-1 does well under 15 PSI and thats why Turbonetics used it for the stock internal kit. They are going to use a T61 or T66 depending on what kind of power they make on Stage II. The goal is 550 RWHP at ~15 PSI. Most likely going to be a T66 but they are going to start with a T61 first and see what happens. They already tried a 62-1 and didn't think there was enough power gain from it to be used on Stage II.
Old Nov 23, 2005 | 03:09 PM
Peking's Avatar
Peking
That seems to be the case for us, along with the article Import Tuner did... Or was it Turbo or Sport Compact car... Damn I can't remember... Anyway like said before... It varies to much on many factors. So what is the result for one does not mean the same for another.
Old Nov 23, 2005 | 04:44 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Im sure somebody like Sharif can correct me but I thought the load was adjustable on those dyno's. The operator can adjust load and affect the numbers. Something to do with ramp/load-up time I believe. Basically they can read higher, about the same, or lower than dynojets usually read. But yes, they are better for tuning than dynojets.
Old Nov 23, 2005 | 05:12 PM
MIAPLAYA's Avatar
MIAPLAYA
I thought you could only do that on the Mustang dynos. The Dynapacks as far as I know can't be adjsuted to fudge numbers like the Mustangs can...but I may be wrong.
Old Nov 24, 2005 | 12:17 AM
solidsnake's Avatar
solidsnake
I want 460rwhp and 530tq. Tell me how and how much. Minus the install.
Old Nov 24, 2005 | 06:17 AM
Peking's Avatar
Peking
Somebody tell me how to build a space ship
Old Nov 24, 2005 | 07:20 AM
MIAPLAYA's Avatar
MIAPLAYA
Arias 8.5:1 pistons: $750 http://www.forgedinternals.com/store...cat=248&page=1
Eagle or Pauter rods: $570 or $1170 http://www.forgedinternals.com/store...cat=249&page=1 or http://www.forgedinternals.com/store...cat=249&page=1
ARP head and main studs: $380 http://www.forgedinternals.com/store...cat=264&page=1
boost controller: $549 http://www.forgedinternals.com/store...cat=255&page=1
engine managment (EU, Utec, Unichip, etc): $529 http://www.forgedinternals.com/store...cat=256&page=1
14-15 PSI on the kit you have now.
Old Nov 24, 2005 | 08:01 AM
abyss's Avatar
abyss
Your my new hero. I'v been in a slump knowing what to order with the kit for good #'s. Now all I have to do is locate a shop in SW missouri, Kansas, or Oklahoma that can do good turbo installs.
Old Nov 24, 2005 | 08:10 AM
MIAPLAYA's Avatar
MIAPLAYA
Actually what you could do is send your block or buy a used block and send it to Forged Internals and ask them to install the above mentioned engine components. Then drive down to Texas or find a shop near you competent enough to swap blocks and install the above components. Of course in the end it may just be easier for you to make the drive out to NC and have Sharif do the work there.
Old Nov 24, 2005 | 09:05 AM
Peking's Avatar
Peking
What MIA posted generally is commonly known for FI folks.
Also agreed, better off driving to Sharif for a install done correctly.
Old Nov 24, 2005 | 11:09 AM
  #38
solidsnake's Avatar
solidsnake
Old Nov 24, 2005 | 02:37 PM
  #39
abyss's Avatar
abyss
That might be a better Idea. I don't know alot about engines and there aren't that many reputible shops around here. I'll talk to Shariff when I get everything settled and have him do my work if he can.
Old Nov 24, 2005 | 07:01 PM
  #40
Peking's Avatar
Peking
Questions that some of you guys post makes me shake my head... Almost seems some folks need someone else to tell them how to do something when you can search, read, and learn
