2 Questions?????
Can I use the Greddy E-Manage on a Stillen Stgae III equipped 350Z and if so does it replace the OEM ECU and the stillen split-second piggyback?
Also, Can I use Nitrous on a S/C (Stillen) 350Z aside from the NX N-Tercooler? If so would I use a wet shot or a drt shot?
Thanks for the help. The search feature doesn't answer these questions very specifically.
The emanage is a piggyback. It doesn't replace the ecu. It would merely replace the split-second piggyback but you would also need a return fuel system and bigger injectors and delete the extra injectors. You could use a wet nitrous setup. It doesn't matter if you have a supercharger or not. How well your engine can take the two is another story.
there are quite a few people going the Stillen SC + N2o route. I was going to go that route as well but ended up going with the APS kit.
If you do the install correctly, have all the safety equipment you won't have any issues at all. Stillen as a daily driver add a 100 shot for the track...very good combo
