What Tire setup are you guys running?
Old Nov 29, 2005 | 12:27 PM
WA2GOOD's Avatar
WA2GOOD
Originally Posted by barthelb
Seriously, cuz my 285's on my 9.5" rear are dead flush with a slight bulging starting to appear. Im curious how that would look or even fit on a 8.5. If a 315 fits fine on a 9.5 then I wonder if I could get a 305. That would be hot.
We need Pictures tho.
Here are pics (above) We also use (and love) the Hoosier 285/30/18 front and 305/30/18 rear combonation (cause they dont make a 315). One of my favorite tires and size combo.
sentry65's Avatar
sentry65
the burninator
what about when you track them and they get really hot and expand a little? Runs ok I take it?
GMADD's Avatar
GMADD
Originally Posted by WA2GOOD
Yes the Corsa's are a pretty good track/street tire. (just stay out of the rain with them) Here is a pic of a 18" Corsa (315/30/18) on a 18x9.5" Nissmo wheel (our rear track tire)
Thanks !
Looks good, I think I'll give them a try as my next set.
I'll be using the Direzionale in front and the Asimmetrico in the rear.
Old Nov 29, 2005 | 12:29 PM
WA2GOOD's Avatar
WA2GOOD
Runs great, all day long, no problems at all.
Old Nov 29, 2005 | 12:30 PM
WA2GOOD's Avatar
WA2GOOD
Smile
Originally Posted by GMADD
Thanks !
No problem glad to help
Old Nov 29, 2005 | 12:45 PM
sentry65's Avatar
sentry65
the burninator
ok cool I'm going to try 315's next time even if it gives me a little understeer for my setup and see what I can do to counter it
Old Nov 29, 2005 | 01:17 PM
WA2GOOD's Avatar
WA2GOOD
It realy shouldn't give you any noticable understeer, if you have 285/30 fronts with matching treadwear rating.
Old Nov 29, 2005 | 01:46 PM
barthelb's Avatar
barthelb
Master
Looks real good, Maybe I'll try 265FR and 305RR or 275FR next, but I don't know if I can clear those.
Old Nov 29, 2005 | 01:58 PM
KTaylor's Avatar
KTaylor
if i have a 19x10 wheel in te back on a z whats the best draag radial i could fit and get the most traction with. Thanks
Old Nov 30, 2005 | 11:38 AM
Jergens's Avatar
Jergens
That is pretty sweet that a 315 fits. I might try it or a 305 but I dunno... I am afraid of defying recommendations
~Josh
Old Dec 2, 2005 | 10:41 AM
sentry65's Avatar
sentry65
the burninator
WA2GOOD I'm looking into doing 285's up front now. Your 8.5" wheel is the standard nismo wheel right? Is that the 25 or 30mm offset one? I'm assuming they just barely fit in there? How much clearance is there? I'm slightly concerned about the tires getting hot and expanding slightly on track days, but maybe since they'd be 30's it'd be pretty minimal
Old Dec 2, 2005 | 11:35 AM
WA2GOOD's Avatar
WA2GOOD
Yes, these 285/30/18"'s are mounted on the standard 18x8.5 Nismo's. No rubbing or clearance problems. The tire will not expand anywhere near enough to create a problem on a track day, or anyday. Make sure your rear tire is always a little bit wider than the front and you should be fine.
Old Dec 2, 2005 | 12:01 PM
sentry65's Avatar
sentry65
the burninator
thanks WA2GOOD,
those are michelin PS2's or another michelin tire? I only ask because I can't find that michelin makes the PS2 in 285/30/18 size.
I see they make the 285/35/18 though
Is it the Pilot Sport Cup tire?
Old Dec 6, 2005 | 02:14 AM
Ep3's Avatar
Ep3
fender mod is required at what point in the rear? 295/35 305/30 315/30 or are these all ok stock with no cutting or rolling? ps i will be running on a 9.5 nismo rim too
Joe
Old Dec 6, 2005 | 08:58 AM
barthelb's Avatar
barthelb
Master
All i can say is it all depends. Depends on offset, ride height, camber and tire profile. I personally don't see how a 305 will fit on my 19x9.5" rim but Im gonna try it as im trying to get more grip, if it doesn't fit I'll send it back. As for the front i hope a 265 fits.
Joe
Old Dec 6, 2005 | 09:24 AM
DBZ33's Avatar
DBZ33
How do I find out what is the widest tire I can put on my 19" IForged. All I know is that it is a 10" wheel. I have no idea what the offset is. I have 275/35/19 SO3's right now. I need a wider tire.
Old Dec 6, 2005 | 11:51 AM
Ep3's Avatar
Ep3
i know tony from performance runs a 2665/35/18 on his front 9.5 nismo .. if that helps he has no issue
Old Dec 6, 2005 | 12:27 PM
  #38
barthelb's Avatar
barthelb
Master
Any info helps, however my situation is that i have 8.5" fr and 9.5" rear. I bet wheel manufacturers must test their wheels and see what size fits best. Or am i just wishing here.
Old Dec 6, 2005 | 01:32 PM
  #39
WA2GOOD's Avatar
WA2GOOD
A great tire for your 19x10"'s or a 19x10.5" are a 305/30/19. They work, fit, look, and feel great.
Old Dec 6, 2005 | 01:45 PM
  #40
WA2GOOD's Avatar
WA2GOOD
Like I said,....We run it all the time on our own and our customers cars (lowered) with no rubbing. IMO, The perfect wheel and tire combo for your Nismo LMGT4's (standard off-set) are;
18x8.5" front with a 285/30/18 or a 265 or 275/35/18
18x9.5" rear with a 315/30/18 or a 305/30/18
