Vortech inlet impeller question
Old Dec 11, 2005 | 05:50 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Originally Posted by kevinapex
OK....Intake filter K&N part# is a X-stream KNF RX-4140 $ 46.75 from AJ USA.com.
Vent filter KNF 62-1020 $ 15.74
All you will need from TurboHoses is the 3.5" od 90deg. stainless Item code pbss31290-312. $ 85.00
And like 12" of 3.5" silcone hose.. item code s3121r $ 68.00
Talk to Hover at TurboHose he will set you up.
Thanks!
Old Dec 11, 2005 | 06:00 PM
kevinapex's Avatar
kevinapex
Vent fltr. picts.
Attached Thumbnails Vortech inlet impeller question-nissan-picts.-093.jpg   Vortech inlet impeller question-nissan-picts.-094.jpg
Old Dec 11, 2005 | 06:10 PM
kevinapex's Avatar
kevinapex
I have two extra chunks of the silcone 3.5" 4" and 6"
Pm me.
Old Dec 12, 2005 | 05:28 AM
jpc350z's Avatar
jpc350z
When I ordered the new demension K&N filter I got a vent filter for the PCV vent.
http://www.martelbrothers.com/pages.php?pageid=20
What does the pcv vent filter do? What did you do with the air breather line that is installed into the back of the vortech supplied air filter ?
Old Dec 12, 2005 | 05:56 PM
kevinapex's Avatar
kevinapex
I took the fitting off of the hose that was attached to the stock Vortech filter and put a K&N filter part # 62-1020 on the vent hose. Above pictures.
Old Feb 21, 2006 | 05:49 PM
zachcrosen's Avatar
zachcrosen
I used silicone 3.5" it's real soft, It would never be able to loose its structure under boost I think you will be fine.
I got sick about how the stock Voctech filter is mounted so I did this with 3.5" silicone, 90 deg. sweep in stainless and new K&N filter.. look at picts!!
Kevin,
I was looking on Turbohoses' website and found a Vortech SC hose replacement kit for the Z. Is this by chance the filter relocation kit or something else? Do you know?
Thanks,
Zach
Old Feb 22, 2006 | 11:40 AM
kevinapex's Avatar
kevinapex
No, the Vortech kit only replaces all the silicone unions betwen the hard pipeing, I spoke with Hover from Turbohoses about it, about the only reason i guess you would do this if for cosmetic reasons. This kit does NOT relocate the filter.
Old Feb 22, 2006 | 11:53 AM
chris'smax's Avatar
chris'smax
are you guys seeing any boost gains when using the larger cfm filters? I know on maxima's when they switch to a CAI setup they see +1psi usually.
Old Feb 22, 2006 | 01:35 PM
LOU's Avatar
LOU
I just called turbohoses.com and ordered the 3.5" 90 degree SS tube and a 3.5" X 3" coupler (which I will try to use in place of the silicon hose kevinapex ordered because it is only $18 instead of $68)
They have two 3.5" 90 degree SS tubes left. The silicon hoses are in stock in black, blue and red. I will let you guys know how it turns out.
Old Feb 22, 2006 | 04:27 PM
kevinapex's Avatar
kevinapex
Good deal Lou, sorry my return pm was late, keep me up on how it works!
Kevin
Old Feb 22, 2006 | 05:08 PM
LOU's Avatar
LOU
PM sent
Old Feb 22, 2006 | 05:10 PM
zachcrosen's Avatar
zachcrosen
Why are we using SS instead of aluminum? Its lighter and should be cheaper. Has anyone bought the aluminum pipe and if so, whats the cost? I think Im going to go with the aluminum pipe instead of the SS one, if it's cheaper that is.
Old Feb 23, 2006 | 05:57 AM
dlt1cy's Avatar
dlt1cy
I was thinking the same thing.
Old Feb 23, 2006 | 10:03 AM
LOU's Avatar
LOU
I'm supposed to receive the parts today. I will post a DIY with photos when I'm done.
Old Feb 23, 2006 | 10:13 AM
teh215's Avatar
teh215
Keep us posted. I got the parts weeks ago and still have not gotten around to installing everything. Did you use the same parts that I PM'd you about?
Old Feb 23, 2006 | 11:42 AM
LOU's Avatar
LOU
I'm not sure of the part number on the pipe, but I believe it is the same one. 3.5" 90 degrees.
I am going to try a 3.5" coupler which is 3" in length (we will see when I get off of work if I need a longer piece)
The filter I bought is the same one kevinapex has on his car. I liked the fact that the top is not sealed off. (RX-4140)
Old Feb 23, 2006 | 01:37 PM
zachcrosen's Avatar
zachcrosen
Thanks for the input and help on this issue guys! I placed an order with Turbohoses today for the following:
1-90 deg. mild steel bent pipe
1-6" long X 3.5" ID blue silicon hose
2-hose clamps
I went with the mild steel because it is cheaper (1/2 the cost of SS) and I can coat it with something for much less! My total shipped cost was around $90. Hopefully this will be here early next week and I can get it installed and show some pix.
Thanks again guys!!!
Old Feb 23, 2006 | 06:41 PM
  #38
LOU's Avatar
LOU
VERY IMPORTANT!!! 3.5"x3" coupler is TOO SHORT. You need at least 5 inches of silicon hose to make it fit. I am going to go to turbohoses.com tomorrow since they are local and pick up a longer piece.
There is definitely some dremel work to be done. I will take some pictures and post them in a little bit.
Old Feb 23, 2006 | 06:58 PM
  #39
LOU's Avatar
LOU
In the first picture you can see where I had to dremel to get the pipe to fit. I still have some clean up work and smoothing out to do: http://pg.photos.yahoo.com/ph/omfgti...cd.jpg&.src=ph
In the second picture you can see that I came up short: http://pg.photos.yahoo.com/ph/omfgti...cd.jpg&.src=ph
Also, if you have an aftermarket radiator (I have Koyo) I had to bend part of the bracket. If anyone wants pictures of that, please let me know.
Old Feb 24, 2006 | 04:13 PM
  #40
LOU's Avatar
LOU
Finally finished this afternoon a after getting the 3.5"x6" silicon hose from turbohoses.com. I had to cut like a 1/2" off to get it to fit. Otherwise in runs into the radiator support.
For anyone with a Koyo radiator or any other radiator that is bigger than the stock one, it is a pain in the *** to work around.
Photos: http://pg.photos.yahoo.com/ph/omfgti...cd.jpg&.src=ph
I don't know if it makes a difference where the filter is placed. After finishing I can tell that kevinapex did a little more dremel work than I did.
