Need a list of all 350z's over 400whp on stock internals!!!
Old Jun 19, 2013 | 01:55 PM
  #41
NismoK's Avatar
NismoK
1. Roncfpz Greddy TT 401whp @ 8psi
2. BigBri APSTT 551whp 493wtq @ 15psi
3. Barthelb APSTT 462whp 445wtq @ 9.5psi
4. BamBam Greddy TT 425whp @ 9.5 psi
5. BriGuyMax APS TT 460whp @ 10psi
6. Peking Turbonetics ST 402 @ 9.5psi
7. Nitrouz APS TT 440rwhp / 418rwtq @ 8.5psi
8. D350Z Turbonetics ST 440rwhp/ 450rwtq @ 9.5 psi
9. Yancy Greddy TT 446rwhp/424rwtq @ 8.5psi
10. 002-M-P Greddy TT 424whp/392wtq @ 7.5psi
11. mcduck Vortech SC 451rwhp/368rwtq @ 9psi
12. BoOstEdz33TT Greddy 453hp/429wt@8.5psi 426hp/416@7.5psi
13. Backagain - Vortech w/3.12 pulley 400whp/342wtq@7.9 ps
14. mcderns-Greddy TT 450whp/428wtq @ 8.5-9psi
15. Vortec27 - -Vortech v2 3:12 pully 443 bhp @ the wheels 9.5psi
16. Psychoballistic- Greddy TT 430whp/ 390 wtq @ 8psi
17. OldManZ (TimRod) Vortech, 540whp/436wtq @ 16psi
18. Pete5150 - VSR Motorsports ST, 464whp @ 7psi
19. meanz- Vortech, 436/390 @11psi
20. NismoK - GTM TT 416/398 @ 9psi
Old Jun 19, 2013 | 07:14 PM
  #42
TopgunZ's Avatar
TopgunZ
So could one say the bearings on a short block built for 800whp are 2x better?
Originally Posted by djamps
Assuming a spot-on tune, wear on a stock block increases significantly above 400whp / 370wtq -- under 400whp / 350wtq is near stock wear levels. this I verified with multiple UOA's over the course of the past few years -- my race tune at 10psi + 100 octane at 420whp vs street tune at 380whp pump shows 3-4x bearing wear with zero knock on either. The tolerances just aren't optimal for higher power levels.
Hint: >400whp might not toss a rod, but it will wear the bearings and rings MUCH more quickly every time you hit full boost.
Old Jun 20, 2013 | 12:57 AM
  #43
unvmyg35's Avatar
unvmyg35
21. unvmyg - Vortech SI Trim, 454/389 @ 11psi
Old Jun 20, 2013 | 11:26 AM
  #44
Drako_MDx's Avatar
Drako_MDx
This list should include what type of Dyno was used for said "whp and wtq". This will somewhat help in determining the differences in numbers.
For example... there's a BIG difference in numbers between Mustang Dyno, Dyno Dynamics, DynoJet and DynaPacks.
My Ride:
2006 G35 Coupe 6MT
463whp/424wtq @ 9.83psi - DynoJet (Tuned by John @ Z1 Motorsports)
BP Kit - PT6266 | Stock Block | Stock Exhaust Manifold
Note: During my dyno tuning session @ Z1 Motorsports, the stock clutch was starting to slip so who knows what I'm actually getting now after my ACT Clutch install...
Old Jun 22, 2013 | 12:31 AM
  #45
gixx76's Avatar
gixx76
What a/r housing are you running? Only reason I ask is because my 6266e .81 failed amd blew the thrust bearing at 14 psi so Im looking for others with any similar issues, lots of blah blah online about precision having **** steel bearings instead of brass but would like some real time feedback.
My Ride:
2006 G35 Coupe 6MT
Old Jun 22, 2013 | 01:05 PM
  #46
Drako_MDx's Avatar
Drako_MDx
Same but journal bearing version with absolutely no issues.
Old Jun 22, 2013 | 01:35 PM
  #47
k6750gsxr's Avatar
k6750gsxr
22. k6750gsxr-GTM TT GT30's 450/440@10psi
Old Jun 22, 2013 | 06:46 PM
  #48
P&K350Z's Avatar
P&K350Z
23. P&K350Z- Vortech 2.87, 458/393 @ 11psi
Old Jun 23, 2013 | 02:21 PM
  #49
nizm350's Avatar
nizm350
24. nism350 momentum single 409/355 @ 9.5 psi
Old Jun 23, 2013 | 03:44 PM
  #50
Ztouring04's Avatar
Ztouring04
25. Ztouring04- greddy TT 422/407 @ 8.7psi
Old Jun 24, 2013 | 12:20 AM
  #51
nizm350's Avatar
nizm350
now im wondering how many miles these guys have on their motor with the said power and what kind of dyno was used to tune. I have almost 17k and tuned on a dynapak
Old Jun 24, 2013 | 05:58 AM
  #52
Cass007's Avatar
Cass007
THIS
Also doesn't account for shops doing hero pulls and then backing it down before you get the car for "safety".
Old Jun 25, 2013 | 03:51 AM
  #53
mknZ's Avatar
mknZ
Wow I love this thread. I'm at 390whp so I don't count but this makes me wanna push it a bit more to maybe 420whp. You gives give me hope lol
Old Jun 26, 2013 | 05:09 PM
  #54
NOLAGG's Avatar
NOLAGG
Howany miles do you have ? What kit are you using ?
Old Jun 26, 2013 | 10:32 PM
  #55
mknZ's Avatar
mknZ
I have 71k miles been boosted for 8k miles. TN kit with upgraded piping, intercooler, blow off valve and wastegate. Pro-Efi tuned at Sound Performance.
  #56
mknZ's Avatar
mknZ
^ @ 8 psi
Old Jun 27, 2013 | 08:09 AM
  #57
BigBlue's Avatar
BigBlue
Great #'s guys! I need to get my SC HR on a dyno; none around here, but I'll probably line it up for Vegas (120 mi. away). I'll do what I can to make the list!
Old Jul 6, 2013 | 01:12 PM
  #58
wizard's Avatar
wizard
26. Wizard - Vortech, 450whp/400wtq @ 13psi
Old Jul 6, 2013 | 04:08 PM
  #59
Resmarted's Avatar
Resmarted
Not directly.
The key to a high hp bearing is increased clearance; there is more oil moving more freely between the parts, allowing efficient lubrication at the higher load levels. The material is also important, and on some motors an aftermarket bearing is also wider than factory parts. There are different kinds of bearings, but as long as your engine builder knows what he is doing, they can set it up correctly. There are various multi layer bearings out there, and this whole discussion should be had with your engine builder imho.
Old Jul 6, 2013 | 05:20 PM
  #60
2004Black350z's Avatar
2004Black350z
Exhaust Whore
How about update of list plus mileage and who tuned
