Turbonetics Tuner vs Full kit?
Old Dec 1, 2005 | 05:43 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Default Turbonetics Tuner vs Full kit?
What are the differences between the two kits?
Correct me if im wrong but the tuner kit with say a utec and fuel pump and return fuel system with injectors will be everything needed for the kit to work with my rev up motor... I am so impatient to go ST i doubt i could wait for the full release. This also allows me to get the ute and tune for everything i mod...
Old Dec 1, 2005 | 05:46 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes that would work. The Tuner kit is everything minus the fuel pump, injectors, and reflash. If you got the injectors and pump on your own you could use a piggyback to tune it sure.
Old Dec 1, 2005 | 06:24 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
so there is no major differences between how the kit should be designed as in descrepancies in the motor design...
and what would you recommend TXS utec or EU
Old Dec 1, 2005 | 08:00 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
what kind of injectors would i need, and does the aam return system or the sgp come with a fuel pump and or injectors?
Old Dec 1, 2005 | 08:28 PM
Peking's Avatar
Peking
Nope no difference in the design of the kit, also just go for the UTEC. Plug and play.
Also 440cc injectors works just fine, and with the AAM Fuel Return you need to also order like a Walboro 255 fuel pump.
Oh and a search would have been helpful
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
