Uncontrollable boost...Mystery of the ages
Originally Posted by theking
No it shouldn't. The O2 sensors don't meter the amount of air only the AF ratio in that air. So dumping to the atmosphere will be fine.
Thanks,
Jermaine@turboxs.com
Originally Posted by BlackTuner
I will have to say this is incorrect. The 02 sensor, senses how much unburnt oxygen is in the exhaust stream. Depending the the location of the sensor, it will be affected by the use of external dump if all of the Exhaust Gases are not being read by the sensor it self.
Thanks,
Thanks,
Originally Posted by 35ounces
Kelly any updates on YOUR boost trials?
When do you think you will be trying the next test?
Originally Posted by Mike@Altered
We did a custom larger w/g install on Larry's car today --> 6.5psi through redline!
If I have time I'll do a small writeup and post some pics tomorrow
Very interesting, indeed
So does he have the UTEC in her yet?
Thanks Mike. I am anxiously waiting for a write up on how you installed that TurboSmart WG. I may have to pick one up too. I assume it vents to atmosphere, how loud was it and how difficult was the install?
Did you install the TurboSmart gate in the same location as where the Evolution goes, or elsewhere? How did you work the dump?
And last....PICS?
I just wanted to add that an open exhaust is not as free as a good exhaust. Gas velocity is what we are dealing with and a closed system can be more free than open. There is scavaging that helps with velocity. And from what I read I think the theory of trying to drink from a fire hose is one of the most valid.
I'm glad to see that FI issues are a big deal over here. I should have my car back soon and I know that if I have some Gremlins that you guys will help me make them see the daylight.
As a retrofit for whoever needs it or what?
