Gauge orientation: Autometer A-pillar pod
Old May 27, 2006 | 11:12 AM
gatti-man's Avatar
gatti-man
Originally Posted by MIAPLAYA
If you check the AFR post install and its good (in the piping not the tailpipe) as long as you dont bolt on a basically staright pipe exhaust or install cams you should be fine. I'd rather have a cookie cutter flash that works for 95% of the customers then a James Bond smoke screen.
ZING!!!!!LOL
Old May 28, 2006 | 05:18 AM
gringott's Avatar
gringott
I bought a used A pillar off ebay, drilled holes in it for the wires, then used the push pins to mount the Autometer. It worked without the pushpins, but was a little loose.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
