GOT CODE???? What is THIS???
Old Dec 14, 2005 | 02:36 PM
tecni's Avatar
tecni
Default GOT CODE???? What is THIS???
I have a greddy TT kit. What could cause the LIMP.
I have the codes and the sheet explaining them but what does it all mean?
Trouble Diagnosis Name: Sensor power supply circuit short.
DTC detecting condition: ECM detects a voltage of power source for sensor is excessively high or low.
Possible causes: Harness or connectors.
(APP sensor 1 circuit is shorted).
(PSP sensor circuit is shorted.)
(Refrigerant pressure sensor is shorted.)
(EVAP control system pressure sensor is shorted.)
Accelerator pdeal position sensor .
(APP sensor 1)
Power steering pressure sensor
refrigerant pressure sensor
EVAP control system pressure sensor.
Condition: ECM stops the electric throttle control actuator control, throttle valve is maintained at a fixed opening (approx 5 degrees ) by the return spring.
WHAT IS ALL THIS?
Old Feb 4, 2006 | 03:26 PM
mistaboosta's Avatar
mistaboosta
got the same problem and cant figure out what to do
Old Feb 4, 2006 | 05:01 PM
overZealous1's Avatar
overZealous1
from the explanation i assume you are going off of a generic explanation of that certain obd2 code. what is the actual code # and i will look it up in the service manual.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
