HELP with gauges
Old Dec 18, 2005 | 11:49 AM
RED HOT Z's Avatar
RED HOT Z
Default HELP with gauges
Hi my name is Gilbert and I just installed my AEM wideband, Boost, EGT
So my question is for some reason when I finished my install my VDC, gas, and temp dont seem to work. Would you happen to know why. Also just by reving the engine should I be able to see the boost?
Thanks
Old Dec 18, 2005 | 12:06 PM
MIAPLAYA's Avatar
MIAPLAYA
Thanks
Did you disconnect any facotry harnesses when you installed the gauges? Did you cut any wires to source for power? If so which ones?
Old Dec 18, 2005 | 12:09 PM
Will Pwr's Avatar
Will Pwr
You will not see boost, unless the engine is underload...e.g. moving....but the boost guage will move between 0 and -0.7 kg/mm2 if you rev at idle
Old Dec 18, 2005 | 12:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Will Pwr
You will not see boost, unless the engine is underload...e.g. moving....but the boost guage will move between 0 and -0.07 kg/mm2 if you rev at idle
Correct... you should have 20 hg of vacuum at idle and it will go towards postive manifold pressure by doing a free standing rev but you wont build boost till the car is moving.
Old Dec 18, 2005 | 12:12 PM
RED HOT Z's Avatar
RED HOT Z
Ok the gauges seem to be working fine but I didnt disconnect any plugs or cut them I used the blue clips to splice into them
Old Dec 18, 2005 | 12:13 PM
RED HOT Z's Avatar
RED HOT Z
I mean my gauges work but not my vdc, gas, and temp
Old Dec 18, 2005 | 12:16 PM
MIAPLAYA's Avatar
MIAPLAYA
Hmmm..so the aftermarket gauges work but the factory ones and VDC dont? Are you sure you didn't pop a fuse. What wires did you tap?
Old Dec 18, 2005 | 12:18 PM
RED HOT Z's Avatar
RED HOT Z
I could have when I was checking ground I went through the wire and touched metal and out came a spark. I know there are fuses in the front but where a re the rest so I can check
Old Dec 18, 2005 | 12:23 PM
MIAPLAYA's Avatar
MIAPLAYA
There is a set under the dash. Theres two sets under the hood in the battery compartment.
RED HOT Z's Avatar
RED HOT Z
Ill check them out I hope there lies the problem
Old Dec 18, 2005 | 12:42 PM
RED HOT Z's Avatar
RED HOT Z
Thanks Robert it was the fuse and everything works now.
Now my turbo timer install
Old Dec 18, 2005 | 12:53 PM
MIAPLAYA's Avatar
MIAPLAYA
Glad I could help...remember for the turbo timer you need to tap the black wire with the red stripe under the steering wheel. I did a write up on it...
Old Dec 18, 2005 | 12:54 PM
MIAPLAYA's Avatar
MIAPLAYA
Write up: https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/149789-turbo-timer-install-write-up.html
Old Dec 18, 2005 | 01:04 PM
RED HOT Z's Avatar
RED HOT Z
Hey Robert I am only finding the black wire with a pink stripe on it not red. In none of the three connectors down there is there a black wire with red stripe on it. There is a red wire with black on it.
So do I tap the black wire with pink stripe?
Old Dec 18, 2005 | 01:06 PM
MIAPLAYA's Avatar
MIAPLAYA
Are you sure...theres should be a harness DIRECTLY under the steering wheel on the steering column itself. Not the fuse panel area. Its hidden by the plastic panel that your turn signal goes into. There should be a white connector with SEVERAL white and other color wires and ONE black wire with a red stripe.
Old Dec 18, 2005 | 01:15 PM
RED HOT Z's Avatar
RED HOT Z
I took apart the plastic peice with the four bolts on it. There are three white connectors and one black one that goes to the ignition. Should it be there
Old Dec 18, 2005 | 01:16 PM
MIAPLAYA's Avatar
MIAPLAYA
Yup. It should be the one like directly in the center of the bottom of that column. Not on the key side and not on the other side but literally on the bottom in the middle.
Old Dec 18, 2005 | 01:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Its a thicker then normal wire...
Old Dec 18, 2005 | 01:24 PM
RED HOT Z's Avatar
RED HOT Z
On the other side there is a black connector that goes onto the ignition I oppened it up and I found 3 larger white wires and one black with a red line through it is this it?
Old Dec 18, 2005 | 01:27 PM
MIAPLAYA's Avatar
MIAPLAYA
Thats the wire but there should have been another harness it went into on the bottom center of the column. Regardless the larger black wire with the red stripe is the one. If you have a multimeter you can check the voltage. It should be 0v off and 12 volts when the key is in the on position. if you dont have a volt meter just tee tap that line in there. Start the car and set up the timer. When you pull the key if you set the timer up right it should keep the car on.
