I finally got it AWSOME!!!!!!!!!!
Old Dec 21, 2005 | 09:09 AM
002-M-P's Avatar
002-M-P
Yea, no rattle here with anything hitting the frame. The only thing I ever hear is my damn exhaust (passenger w/g-dp adapter) leak. Stupid squirrel.
Old Dec 21, 2005 | 09:10 AM
Zilvia's Avatar
Zilvia
Originally Posted by Fairlady_z33
Jun im in miami not a member of the sfzcc
Yep i have a greddy TT
roncfpz and 002-M-P do you get a rattle when you are dropping rpm's at around 2500k or 3000 rmp japtrix told me that its becouse when the motor is accelerated it goes to the side and the turbos hit the side panel is this true.
Also my check engine light just turned on the car still runs fine my a/f is still the same what do you guys think it could be.
i think the stillen engine damper will help stop this.................it prevents th motor from moving
Old Dec 21, 2005 | 09:13 AM
002-M-P's Avatar
002-M-P
Oh yeah, and about the check engine light...my car did this for a while because of the testpipes i believe (never really bothered me), then one day it all of a sudden didn't come on again. That was probably 6-9 months ago.
I did do alot of research on stuff you can do to fix the SES light coming on...of all the ways I think I like the 02 Simulator best. Basically a 555 timer with some other various wires and resistors that you wire into the ecu to trick the computer to thinking it is recieving a true 02 signal.
http://www.o2sim.com/24803.html
Old Dec 21, 2005 | 09:14 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
hehe...yes...I have hear your squirrel in person. Do you need me to call a rodent exterminator.
Old Dec 21, 2005 | 09:24 AM
002-M-P's Avatar
002-M-P
Haha, please do....I think I will have a remidy next week though.
Old Dec 21, 2005 | 10:57 AM
dynamic6er's Avatar
dynamic6er
but the ting is that ive never gotten that rattle with the test pipes alone so i dont think is that.
The extra heat from the TT may have casued it
Old Dec 21, 2005 | 11:17 AM
Jaki's Avatar
Jaki
Originally Posted by westpak
..the stillen dampener wont work...
Old Dec 21, 2005 | 11:27 AM
failsafe306's Avatar
failsafe306
^^haha
Old Dec 21, 2005 | 11:29 AM
Fairlady_z33's Avatar
Fairlady_z33
i was looking at the turbos and the one on my side is about 1/2 maybe 3/4 of an inch away from the side wall but the other side is about 1 inch to almost 2 inch maybe. If it was the turbos could you put a high temperature resisting rubber to atleast stop the metal to metal contact. Or is their anything else that it could be.
Old Dec 21, 2005 | 11:33 AM
failsafe306
I'd seriously doubt it's the turbos hitting the frame, unless your car has been wrecked previously or something.
Just a shot in the dark, but it could be that the point where your testpipes connect to the turbo downpipes is a little different now, and causing part of your exhaust to hit somewhere that it previously didn't, before the turbo install.
Old Dec 21, 2005 | 11:37 AM
Fairlady_z33
well what they have told me makes sense in a way becouse the engine moves to the side when you punch it but its weird becouse im the only one with this problem out of so many kits.
And im first owner of my car never wrecked to this day (knock on wood)
Old Dec 21, 2005 | 11:48 AM
002-M-P's Avatar
002-M-P
Our motors in out cars don't really move all that much, esp. compared to many other motors in some cars out there. It might move, but i highly doubt it will move an inch unless your motor mounts are toast somehow.
Old Dec 21, 2005 | 12:08 PM
Fairlady_z33
i have to check the best place would be in the dyno. let hope its just the test pipes
Old Dec 21, 2005 | 01:00 PM
westpak's Avatar
westpak
SFZCC
If the turbos are that far from the body then they are not it.
Old Dec 21, 2005 | 01:21 PM
Fairlady_z33
will see when i take the car up their gus. Thanks to everyone.
Old Dec 28, 2005 | 10:26 AM
pearlcoupeg35's Avatar
pearlcoupeg35
Fairlady z33,
Can you list ALL your mods that you have??? Your running 5.5 psi right? Stock clutch/flywheel?
Im very curious about the Greddy kit and you seem to be one of the most recent installls (i heard they are selling an updated version now)
Thanks
Old Dec 28, 2005 | 11:32 AM
Fairlady_z33
Well im automatic but some people upgrade when they higher boost.
Mod list
Greddy TT / FMIC
walbro fuel pump
Greddy type rs BOV/ with flange
autosport wiring
A/F gauge
Boost gauge
boost controller
turbo timer
J&S safegaurd
megan resonated test pipes
evrything else is stock
Old Dec 28, 2005 | 11:40 AM
  #38
pearlcoupeg35
Mod list
Greddy TT / FMIC
walbro fuel pump
autosport wiring
A/F gauge
Boost gauge
boost controller
turbo timer
J&S safegaurd
Thank you very much. What are your most recent power numbers? or what will they be after a good tune???
Old Dec 28, 2005 | 12:23 PM
  #39
t32gzz's Avatar
t32gzz
My Greddy EVO II exhaust rattled in a straight line and on decel like you are referring to. It looked like the exhaust cleared when on the lift, but it was jumping around and hitting one of the cross bars under the car. I had it bent to keep it off of there. Just in case it helps.
Old Dec 28, 2005 | 12:25 PM
  #40
Fairlady_z33
im going to go to 7psi with a 3 inch dual custom exhaust with 3 inch test pipes i think this will put me in the 375 + RWHP mark easily i think. Their is a guy making 424 RWHP on a fuel return system 3 inch custom exhaust and a plenum at around 7.5 to 8 pounds.
