why so bad?
Old Dec 26, 2005 | 10:32 AM
TwoNosBottles's Avatar
TwoNosBottles
Default why so bad?
http://www.sportcompactcarweb.com/ro...03scc_jic350z/
check out the mods done to this car. wouldnt you think it would be running so phenom times. But it didnt.. check the #s at the bottom. Anyone know why the 1/4 mile time on this car was not so good?
Old Dec 26, 2005 | 10:37 AM
plumpzz's Avatar
plumpzz
Its probably set up for track racing not drag. From the 1.03 skidpad, its probable. The rear tires are probably at an angle like this: / \ so they can grip when turning.. drag racers have their tires like this | | so they get full traction when going straight
Old Dec 26, 2005 | 10:41 AM
Zilvia's Avatar
Zilvia
yeah its a drift car not a drag car
Old Dec 26, 2005 | 11:16 AM
booger's Avatar
booger
Thats the same times I was running on 7psi with my Vortech...2.0 60ft with a AT5 G35 . On a hot summer night
Old Dec 26, 2005 | 01:04 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thats the exact same time Im running on the same suspension with less negative camber (Im sure) with bolt-ons Even with a bad launch the car should of trapped higher. But like already mentioned Im sure the guy can drift his a$$ off, and isnt that great of a drag racer.
Old Dec 26, 2005 | 01:18 PM
JETPILOT's Avatar
JETPILOT
All that weight in vinyl stickers is added weight and causing massive wind resistance.
Respect
JET
Old Dec 26, 2005 | 01:29 PM
KTaylor's Avatar
KTaylor
if im not mistaken i think they swapped there ati procharger out for a PE TT now
Old Dec 26, 2005 | 02:32 PM
D350Z10's Avatar
D350Z10
You give me that same car... and I will easly run 12's... That was a magazine driver= crappy *** driver, plus they pry had cameras in the car and everything... All I am saying is dont listen to that and drive it yourself.
Old Dec 26, 2005 | 09:57 PM
booger's Avatar
booger
7psi....most get 340whp to 360whp ...high 12's to low 13's...not every one is Alberto
Old Dec 26, 2005 | 10:56 PM
BobaFettm's Avatar
BobaFettm
LOL Trent... not to be rude but just cuz your behind the wheel doesnt allow the car to go faster down the drag... its because its not meant to be a drag car Clearly the car isnt tuned for that... Most drifters do not want a car doing low 12's... they need something that will give them great accelerations only at certain speeds... too much power would just lead to insane oversteering and understeering in certain situations! Props to that car its beautiful and keeping the Z's name strong in drifting were it belongs! Not doing the straight line stuff like its little brother the 300
Old Dec 27, 2005 | 05:16 AM
Gumpdriver's Avatar
Gumpdriver
Thats the JIC drift car not set up for straight lines LOL
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
