Turbosmart Wastegate Pics / Cure for TN Overboost
Old Jan 4, 2006 | 03:04 PM
  #81
MI 35th's Avatar
MI 35th
OGPremierMafia
what size is that how would this compare to a tial 38mm
Old Jan 4, 2006 | 03:16 PM
  #82
MIAPLAYA's Avatar
MIAPLAYA
The Turbonetics Evolution gate is a 36 mm valve so that and a Tial are basically the same. The Turbonetics NewGen gate is a 50 mm valve which is even bigger then the 48mm Turbosmart gate that Jetpilot used. By only 2mm of course so not a WHOLE lot different. But I think the Newgen is cheaper.
Old Jan 4, 2006 | 03:22 PM
  #83
RED HOT Z's Avatar
RED HOT Z
Hey Mia my tuner said he can safely tune my car for the boost spikes so I shouldnt be worried about it. Also that the map sensor that I got with the UTEC will know when I am boost spikig therefor sending a signal to my injectors to allow more fuel. Does this sound right?
He also said that he would never release an unsafe car because it would be his *** and not mine. They cover all the work they do.
Old Jan 4, 2006 | 04:14 PM
  #84
MIAPLAYA's Avatar
MIAPLAYA
Ok well TECHNICALLY yes with the UTEC reading pressure it should be altering your tune to compensate and that MAY be ok for now.
Old Jan 4, 2006 | 04:17 PM
  #85
35ounces's Avatar
35ounces
03 CS Track 6MT
... but you don't really want to be running 11-12psi on a stock motor do you?
I wouldn't
Old Jan 4, 2006 | 04:18 PM
  #86
MIAPLAYA's Avatar
MIAPLAYA
I wouldn't
Well thats the thing bro...theres NOTHING wrong with running 11-12 PSI on a stock motor. The TT guys have been doing it forever.... its a matter of having the right tuning to make that 11-12 PSI safe. If the Utec reads MAP and alters the curve when it sees 11-12 psi then sure you can run that all day.
Old Jan 4, 2006 | 04:26 PM
  #87
RED HOT Z's Avatar
RED HOT Z
Exactly ^^ well I'm going to run it like this for a bit just until TN comes up with a solution to fix it.
Old Jan 5, 2006 | 09:48 AM
  #88
Phatmitzu's Avatar
Phatmitzu
I have been having overboost problem also. My installer also suggested that the WG spring might be failing. I havent been driving my car much lately. I need to find a fix before I feel comfortable driving it again. Awaits for the TN fix.
Also, MIAPLAYA, you mentioned about a new TN down pipe for the O2 sensor code fix. Is it available now?
Old Jan 5, 2006 | 09:58 AM
  #89
MIAPLAYA's Avatar
MIAPLAYA
It is...Reggie can get it to you...what exhaust are you running? Also there was a recall for 04 ECUs for it throwing O2 codes when it shouldn't have. I think three guys have had the dealer reflash the ECU to fix it and then send thier ECU back to Turbonetics to get the tuning flash re-done...
Old Jan 5, 2006 | 10:22 AM
  #90
Phatmitzu's Avatar
Phatmitzu
I have the Amuse Ti-Extra. I have a 04'. Should I bring my car back to the dealer and have the ECU reflashed? Maybe I should PM Jason at Perf Nissan about this.
How would I get the new down pipe with the O2 spacers?
Old Jan 5, 2006 | 10:35 AM
  #91
MIAPLAYA's Avatar
MIAPLAYA
Reggie can get it for you...just call them and tell them you have the old downipe without the O2 spacers and they will overnight you the new one. As for the codes if they still show up after that you need to get the TSB done and have Turbonetics reflash the car again..
Old Aug 20, 2006 | 11:08 PM
  #92
mchapman's Avatar
mchapman
Nice wastegate.
Old Aug 21, 2006 | 06:12 AM
  #93
kcobean's Avatar
kcobean
Holy resurrected thread bat-man....
Old Oct 4, 2010 | 05:46 PM
  #94
twitch579's Avatar
twitch579
BRING BACK THE DEAD!
Im having this same issue and its driving me mad!!! Tried flipping the wastegate to dump to atmosphere and it did nothing to help. I still hit 10-10.5 Psi in higher gears (3rd+).
Im running a single 3inch straight exhaust with no resonators. Its pretty much wide open.
Old Oct 4, 2010 | 06:05 PM
  #95
zmedic16's Avatar
zmedic16
wastegate relocation kit, update piping/end thread.
Old Oct 4, 2010 | 07:29 PM
  #96
twitch579's Avatar
twitch579
Gonna call threadstone tomorrow and see if they still stock it.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
