My APS TT project....almost done!
Old Dec 29, 2005 | 04:35 PM
failsafe306's Avatar
failsafe306
Thumbs up My APS TT project....almost done!
Well guys, after over six months of more bullshit than you could ever imagine, (literally EVERYthing went wrong) my car is almost done! Here are the final specs on my car. I'm going for 550-575whp on 91 octane (for now ). The car should be completely finished within the next week or two.
APS Twin Turbo
Arias Extreme Duty pistons 9:1
Pauter rods
ARP head & main bolts/studs
JWT cams/springs
Ported/polished heads
12lb wastegate actuators
Crawford plenum
AAM fuel return system
RC 650cc injectors
Aquamist water injection
Samco hoses
Koyo radiator
Defi egt, boost gauges
AEM wideband
PLX-R500
ATS triple carbon clutch
SFT 3" dual exhaust w/ HKS Ti mufflers
Volk GT-V wheels
Michelin PS2 tires
Thanks to GRD, SGP, Forged Internals, and Injected Performance
Old Dec 29, 2005 | 04:36 PM
MIAPLAYA's Avatar
MIAPLAYA
Damn congrats..thats going to be a beast..
Old Dec 29, 2005 | 04:37 PM
tig488's Avatar
tig488
congrats man, when is the official crank date? thats gonna be a wicked ride.
Old Dec 29, 2005 | 04:38 PM
Gumpdriver's Avatar
Gumpdriver
Man that is going to be a F-ing beast.
Old Dec 29, 2005 | 04:46 PM
failsafe306
It's been up and running for over a week now, but it's been hard for them to put miles on it due to the snow. Tuan sent the ECU to TS to be reflashed for my injectors and some other things he wants to try out.
So far, it's been running great; no smoke or issues so far. I'm hoping I'll have her back by mid January if not sooner
Old Dec 29, 2005 | 05:04 PM
symalik's Avatar
symalik
weathers been pretty snow free lately in chicago so im sure its pretty soon for u!
Old Dec 29, 2005 | 05:17 PM
trebien's Avatar
trebien
No offense... but since you obviously went all-out with a built engine and such, why not spend a little extra on a more common ECU system that's more easily tuned? Especially if you don't live in a typical tuner-friendly area? I assume Oklahoma, since it's listed as your location.
Old Dec 29, 2005 | 07:38 PM
failsafe306
I will next year. The UTEC isn't readily available yet and the FCON is too expensive at this time. The Unichip will do just fine for the time being.
Old Dec 29, 2005 | 07:58 PM
Nismo350ZRT's Avatar
Nismo350ZRT
The reflash will allow the Unichip to utilize the bigger injectors? Zivman said he wasn't able to use bigger injectors with the Unichip. If the reflash fixes this problem, I'm going to be ecstatic!
Old Dec 29, 2005 | 08:14 PM
failsafe306
It will. How else could Bigbri and Marluci7 be running huge whp and large injectors on a Unichip? The reflash does the same as what the UTEC or EU or any other scalable piggyback would do.
Old Dec 29, 2005 | 09:15 PM
G3po's Avatar
G3po
The Unichip works fine with low SCR and 650cc injectors. You just need to tune it in MAP mode, since the MAf saturates much above 12psi of boost.
Old Dec 30, 2005 | 07:28 AM
Nismo350ZRT
Originally Posted by G3po
It will. How else could Bigbri and Marluci7 be running huge whp and large injectors on a Unichip? The reflash does the same as what the UTEC or EU or any other scalable piggyback would do..
That's exactly what I wanted to hear.
Old Dec 30, 2005 | 08:38 AM
Zivman's Avatar
Zivman
Yes, you can reflash the ECU for larger injectors. I just didn't want to spend 400-600 bucks on a reflash that simply modifies to a given injector. I think the money is better spent going towards a utec, map sensor, and boost solenoid (about 1200 bucks) and having more control.
The unichip is a fine solution for my current numbers -> 450 rwhp and 480 rwtq @ 14psi tapered to 11psi at redline. To go higher, I would want more control than the unichip provides - not that the unichip wouldn't be fine with a reflash of the ECU for larger injectors
Old Dec 30, 2005 | 08:42 AM
Zivman's Avatar
Zivman
The unichip clamps the MAF signal and uses a MAP sensor to modulate fuel delivery past the point where the MAF is overwhelmed. As those that run a reflash for their FI EMS should know, the MAF maxes out at around 8 psi.
Old Dec 30, 2005 | 09:14 AM
failsafe306
I normally wouldn't spend that much either just for inj scaling, but I also had it flashed for 1000 rpm idle and 7200 rpm rev limit.
Old Dec 30, 2005 | 09:18 AM
Zivman's Avatar
Zivman
And at the time you had this done, utec was vaporware. Heck, from what I know, unless you preordered, it is still a 2-3 wk wait for a utec.
Old Dec 30, 2005 | 10:13 AM
zman1910's Avatar
zman1910
Ebay has a UTEC for 700 bucks
Old Dec 30, 2005 | 10:32 AM
failsafe306
Yea, but do they REALLY have it? Doubtful.
Old Dec 30, 2005 | 11:14 AM
Sam405's Avatar
Sam405
hey where in oklahoma do you live?
Old Dec 30, 2005 | 11:26 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
No they don't. That guy posted a bunch for sale, but has none, and will likely never get any. There was another thread on it..search for "UTEC and EBAY:.
