Any benifit to vented hood on a FI
Old Jan 2, 2006 | 04:20 PM
phunk's Avatar
phunk
CJ Motorsports
vented hoods are a great idea for high performance cars.
when i am sitting at a stoplight i can see the heat radiating out of my vents. it probably hardly helps at all, but every little bit counts. My main reasons for getting a vented hood was weight (yes its still significantly lighter then my stock one) and for airflow. i do a lot of high speed racing around and by venting some of the engine bay air pressure out the top it will reduce pressure under the car.
my veilside v2 hood also gave me almost an inch of clearance in the plenum area which will allow a little bit more airflow around there
Old Jan 2, 2006 | 05:23 PM
Fairlady_z33's Avatar
Fairlady_z33
Originally Posted by Fairlady_z33
Hey guys i think if we had more air inlet like to say instead of one engine intake hole if we had two then cold air would go in by the holes and would leave by the vents on the hood.
Has anyone made a similar holeon the passenger side to the one on the drivers side.
I think this would help alot.
Anyone???????
Anyone now about this ????????????
Old Jan 2, 2006 | 06:49 PM
Z BOY's Avatar
Z BOY
my dyno guy has the same hood as mine, vis fusn, on his rx7. he told me it decreased engine bay temp by 30`F on his car.
Old Jan 2, 2006 | 07:34 PM
TheLastSpartan's Avatar
TheLastSpartan
Originally Posted by MoodDude
So I guess the next question is - what hood is the right design, won't rub, and will last. I know that you want a full carbon fiber hood (for the weight). One that I really like is the Top Secret full carbon fiber hood, but man is that a lot of money (yet, as usually - you get what you paid for).
http://store.yahoo.com/ntnsracing/topseho35.html
Any other high quality hoods I should be looking at?
the Vis terminator is very similar to this...at half the cost
they have it at performancenissanparts.com
Old Jan 31, 2006 | 03:33 AM
MoodDude's Avatar
MoodDude
I cut my stock hood last night - looks good. When I get my car washed I will take pictures. After I drove it, I could feel tons of heat venting out.
Old Jan 31, 2006 | 04:00 AM
taurran's Avatar
taurran
I've got the veilside v2 hood as well. It's 100% difference in underhood temps with the turbo mounted up there. Between it and the heat wrap/coated headers, there is no perceivable ambient heat increase under the hood.
Old Jan 31, 2006 | 04:29 AM
MoodDude's Avatar
MoodDude
Good info. I figured that this would be cheaper and easier to do than replacing the radiator to get extra cooling on the engine. Since my IC pretty makes it impossible to fit a larger radiator.
I also did it to releave some of the air from under the hood to lower the pressure on the bottom of the car. Should help the car stick to the road at speed.
Old Feb 1, 2006 | 03:06 AM
MoodDude's Avatar
MoodDude
I posted a pic of the cut hood in the Body, Interior, Exterior & Lighting forum if any of you are interested.
Old Feb 1, 2006 | 09:32 AM
BobaFettm's Avatar
BobaFettm
Gonna sound pretty noobish... but I know vented hoods on NA can be rough for waterlocking the engine...
in our Turbo'd cars... do we have to worry about the water being sucked in during heavy rain and killing our cars?
Old Feb 1, 2006 | 09:52 AM
taurran's Avatar
taurran
Falling or dripping rain won't water lock an engine, so a vented hood shouldn't be an issue. Also, a well designed vented hood should be forcing air OUT of the hood while you're driving, keeping the engine bay mostly water-free. It should also not have the intake area directly exposed to the elements.
Totally submerging your intake in water is never a good idea, regardless of weather you're NA or FI...
Old Feb 1, 2006 | 12:03 PM
BobaFettm's Avatar
BobaFettm
Thanks Taurran! that helps me decide that I'm going vented too
Old Feb 1, 2006 | 12:38 PM
rs350z's Avatar
rs350z
Taur is y our hood CF. IF so did the paint match up well?
Old Feb 1, 2006 | 05:44 PM
taurran's Avatar
taurran
No. Mine is a veilside fiberglass hood. I wouldn't recommend buying veilside, it was a NIGHTMARE to get it even on the car.
The paint match totally depends on who does your work.
Old Feb 2, 2006 | 03:22 AM
gringott's Avatar
gringott
I have the Seibon VT, it does decrease oil temps by a couple of degrees, not a big deal, but it also lowers the engine bay temps, by what amount, I don't know, but you can see the heat escaping.
Old Feb 2, 2006 | 08:16 AM
Chebosto's Avatar
Chebosto
any picts of your Aerocatch installed yet ?
Old Oct 23, 2006 | 12:57 PM
THE TECH's Avatar
THE TECH
+1
Old Oct 23, 2006 | 01:32 PM
sentry65's Avatar
sentry65
the burninator
old thread, but since it was raised, I haven't noticed any temp decrease on any of my gauges - oil temp, coolant temp (both stock and aftermarket), EGT, even the outside temp gauge
actually it miiiight have lowered oil temps by like i dunno 1-2 degrees F or something, but I have noticed the engine bay itself isn't as hot when you pop the hood
for reference, I have a vortech - which doesn't get as hot as turbos
Old Oct 23, 2006 | 01:48 PM
  #38
plumpzz's Avatar
plumpzz
The block itself doesn't have enough surface area to disipate heat so fast as over heat the space under the hood. Ive only noticed two hoods which would make a large impact on the temperature under the hood (which eventually mean lower intake temps). Those are the do luck hood and its replicas (via the cowl effect) and the TS hood via the bernouli effect. The TS hood would probably be far more effective because of the placement of the vent.
Old Oct 23, 2006 | 01:49 PM
  #39
ZU L8R's Avatar
ZU L8R
Viper Sellout
I can feel the heat coming out of mine when I turn off the car. Hopefully I'm getting some cooler air in there as well when I'm driving.
Old Oct 23, 2006 | 02:02 PM
  #40
Nismo350ZRT's Avatar
Nismo350ZRT
I have the Seibon VT hood and I haven't noticed any decrease in temps. I bought it mainly for cooling the engine bay after parking the car. You can feel the waves of heat coming out of the vents. With the stock hood, I'd always pop it open after parking the car at home but you can't do that when parking elsewhere.
