TN ECU re-flash or UTEC
Old Jan 8, 2006 | 01:06 AM
sa@lol's Avatar
sa@lol
Question TN ECU re-flash or UTEC
Hi guys,
I am getting my TN kit soon to be installed on a stock engine with an upgraded 560cc injectors, sued I go with the TN re-flash or a Turboxs UTEC.
If i get the UTEC starting the car for the first time after installation is it rely difficult to tune it.
Old Jan 8, 2006 | 01:19 AM
Peking's Avatar
Peking
How about a search
Old Jan 8, 2006 | 02:53 AM
Dubai's Avatar
Dubai
UTEC without thinking
Old Jan 8, 2006 | 04:08 AM
captj3's Avatar
captj3
Get the utec. Have a pro tune and install it. If you don't really know what your doing it can cost you an engine 5-6k.
Old Jan 8, 2006 | 04:59 AM
blackend's Avatar
blackend
Default go with EU
YOU CAN USE EU OR THE BLUE OR UNICHIP IF YOU HAVE THE DELAER TO TUNE IT.UTEC I DONT THINK IN KSA CAN TUNE IT BUT EU AND BLUE FOR SURE
Old Jan 8, 2006 | 07:22 AM
D350Z10's Avatar
D350Z10
HAha not ever a question... Utec
Old Jan 8, 2006 | 07:33 AM
Zilvia's Avatar
Zilvia
Utec
Old Jan 8, 2006 | 07:39 AM
Zivman's Avatar
Zivman
+10000000000000000000000000000000000000000000000000000
ECU flashed EMS for FI is just a time bomb
Old Jan 8, 2006 | 08:28 AM
D350Z10's Avatar
D350Z10
the re-flash doesnt adjust timing enough... it is way off in terms of timing.
Old Jan 8, 2006 | 01:00 PM
Gumpdriver's Avatar
Gumpdriver
BUt I call Turbonrtics the other day they say you should not have any problems. See i will have to drive my car CP in Charlette for the UTEC tune do you guys think everything is going to be ok?
Old Jan 8, 2006 | 01:05 PM
StarcraftBW's Avatar
StarcraftBW
you need both
Old Jan 8, 2006 | 01:54 PM
Gumpdriver's Avatar
Gumpdriver
Originally Posted by StarcraftBW
you need both
Yes you do need the one flashed by Turbonetics to run the car before the Utec kicks in with the oncoming of boost.
Old Jan 8, 2006 | 01:56 PM
D350Z10's Avatar
D350Z10
Not true... The car will start and drive with no flash... keep under 2500 rpms and it will drive but better off getting the flash because allows ecu to see boost and rasies idle to 1000 so wont stall with the injectors.
Old Jan 8, 2006 | 02:54 PM
JETPILOT's Avatar
JETPILOT
If your car is stock except for the TN kit and you plan not a single other mod then the reflash is fine. The TN kit was designed for a stock car. Any mods and you are experimenting.
Respect
JET
Old Jan 8, 2006 | 03:13 PM
Gumpdriver's Avatar
Gumpdriver
The only Mods i have are plenum spacer and exhaust will everythign be ok?
Old Jan 8, 2006 | 03:16 PM
Jason333's Avatar
Jason333
hi
After what i've read, i would probably do the UTEC if i altered anything at all.
Old Jan 8, 2006 | 03:29 PM
Gumpdriver's Avatar
Gumpdriver
I am starting to believe it also? I need all i can get to safe guard my car.
Old Jan 8, 2006 | 03:41 PM
JETPILOT's Avatar
JETPILOT
No one can promise anything once you have changed from stock configuration.
Which exhaust?
Respect
JET
Old Jan 8, 2006 | 03:42 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Go ahead and get the TN reflash for starters, and we can add and tune the UTEC later. But yes....get the UTEC for tuning.
Old Jan 8, 2006 | 03:48 PM
Havok_RLS2's Avatar
Havok_RLS2
Get Both and do it right the first time.
