Supercharger or Turbo?
Old Jan 23, 2006 | 09:54 AM
prescience's Avatar
prescience
Originally Posted by chimmike
wait, what the hell are you talking about?
Since when is turbo $10k or more? Turbonetics single turbo kit can be had for LESS than the vortech SC kit brand new, with EVERYTHING needed to install and run.
Oh boy, another person spouting off when they don't know exactly what they're talking about.
This guy is here in the UK, as it happens if you put £ (GBP) in front of those figures, then they're about right for the options we currently have here (APS TT, HKS S/C and Vortech)
Old Jan 23, 2006 | 12:47 PM
DmanG281's Avatar
DmanG281
Um someone needs to actually look at the threads in this forum. Chimmike is not one of those. Ok look here
http://www.intensepower.com/tubabesituki.html
http://www.intensepower.com/atipr35cafor.html
If you guys know how to subtract I think you can figure this one out. It might be a little hard for some of you so I did it for you. A single turbo is 361.66 dollars cheaper than the ATI. For that money you can get 2 new filters and 2 oil changes and still have enough to buy some tampons.
Old Jan 23, 2006 | 12:52 PM
chimmike's Avatar
chimmike
ROFL!
Old Jan 23, 2006 | 12:56 PM
sentry65's Avatar
sentry65
the burninator
I got my vortech tuner kit for $3500
then got a return fuel system, bigger injectors and an EMS - none of which the turbonetics kit comes with and it was just a few hundred more than the turbonetics kit
by the time you pay for shipping the ECU over to turbonetics a few times to get a good A/F for your car, it's probably about even. Still, it won't run as safe as a car with an EMS, bigger injectors, and return fuel system
Old Jan 23, 2006 | 01:00 PM
chimmike's Avatar
chimmike
and you can do the same thing by purchasing the turbonetics tuner kit.........so, your point is?
Old Jan 23, 2006 | 02:31 PM
sentry65's Avatar
sentry65
the burninator
how much is the turbonetics tuner kit? $4800? where's a link? point is, it's like $1200 cheaper, that's enough to buy a return fuel system and maybe some used injectors
Z1 has it for $4950. I'm sure there's a better price for it though. I thought the TN kit just went up in price because it USED to be like $4200(?), but now it's more
http://www.z1auto.com/prodmore.asp?m...bo&prodid=1290
Old Jan 23, 2006 | 02:55 PM
chimmike's Avatar
chimmike
dude the regular kit can be bought for less than 4800
z1 is among the most expensive for the tn kit. Mossy has a few for less than 4500
Old Jan 23, 2006 | 02:56 PM
sentry65's Avatar
sentry65
the burninator
ah so the TN tuner kit is $500 more than the vortech tuner kit
http://www.mossyperformance.com/prod...49&model_id=16
not everyone wants a turbo for various reasons
Old Jan 23, 2006 | 03:16 PM
vivid's Avatar
vivid
Can someone explain the differance between a TUNER VORTECH and FULL KIT?
What parts are missing exactly?
Old Jan 23, 2006 | 03:31 PM
chimmike's Avatar
chimmike
tuner kits are minus fuel management, so that a "tuner" can choose his own setup to use for fuel control...injectors, management, fuel pump, etc.
Old Jan 23, 2006 | 11:02 PM
taurran's Avatar
taurran
Umm... I'd also like to hear why superchargers are "less maintenance" than turbos.
From what I've seen, supercharger owners spend more time dicking around with squeaking/frayed/slipping belts than I spend on the turbo...
Old Jan 24, 2006 | 01:13 PM
k3silk's Avatar
k3silk
+1^ superchargers have to change there belts after a few years of use also have to be check self contain oil for some like the ati charger. roots style blower would be the only type of supercharger i would get or twin screw witch they do not make for Zs yet? if going with vortech or ati you may as well get the single turbo set up. unless yor talking about the HKS which is overly priced but it all in what you want in the end any way.
Old Jan 24, 2006 | 03:08 PM
chimmike's Avatar
chimmike
the only roots style twin screw unit is the stillen, which I think uses an eaton blower. It's probably the least powerful FI kit out there for the Z
350Z_Al
Oct 29, 2020 07:44 PM
Calinismo350z
Sep 14, 2015 04:04 PM
