stillen stage 3 pulley install help
Old Jan 30, 2006 | 06:58 PM
nateg35's Avatar
nateg35
Default stillen stage 3 pulley install help
currently running stage2...thinking of getting stage 3 pulley...
Sorry...I'm newbie here....Can someone instruct me how to change the pulley (pictures would be nice)...Thanks in advance
I did use the Search button ...but nuttin seems help
Old Jan 30, 2006 | 09:40 PM
nateg35's Avatar
nateg35
Anyone?
Old Jan 30, 2006 | 09:46 PM
AmyCroft's Avatar
AmyCroft
Smile There is a Stage 4 from Stillen - Call Them
The Stage 4 can be purchaced from Stillen approx: $850 USD
Cheers Amy -
It is a big change, and is not CARB Cert in California
Also voids any Stillen warantee
Old Jan 30, 2006 | 10:36 PM
nateg35's Avatar
nateg35
Cheers Amy -
I've heard about stage4 but not sure how reliable this kit will be...will wait for a while ...in mean time...I'm try to get help for stage3 pulley change
Old Jan 31, 2006 | 06:07 AM
superchargedg's Avatar
superchargedg
Damn Noobs
when you buy the pulley it will come with instructions,btw its not the pulley on the sc its the pulley in frt of the sc drive belt sorry no pics.
Old Jan 31, 2006 | 09:58 AM
nateg35's Avatar
nateg35
Thanks...do you also need to adjust the belt (tighten them up I assume since you go with small size?)
Old Jan 31, 2006 | 05:51 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Yes, you will need to re-adjust the tensioner, just a little bit, not by too much tho.
And stage 4 is well worth the $800, I love it
Old Feb 1, 2006 | 01:52 PM
nateg35's Avatar
nateg35
Adjust the pulley's tensioner? and/or sc tensioner?...thanks in advance
Old Feb 2, 2006 | 09:13 AM
superchargedg
Damn Noobs
you will have to tighten the belt because the pulley is smaller also the sc belt should have a spring loaded tensioner(mine does).
Old Feb 2, 2006 | 02:13 PM
Dr.G's Avatar
Dr.G
i am about to install stage 4 , i just got it , so far i had stage 3. Do you feel a real difference between stage 3 and 4?
Old Feb 2, 2006 | 02:25 PM
Tony@Performance
Yes, stage 4 is a considerable difference vs stage 3. you will also notice that the car wants to pull higher and harder in hte RPM range. You'll like it
Old Feb 3, 2006 | 09:56 AM
808_FairladyZ's Avatar
808_FairladyZ
What did you have to do to your motor in order to use the stage 4 pulley? Is it safe for a motor that stock? Does Stillen make a supercharger for the 300hp Track Model Z? Will i need to get some sort of ECU tuning to use the Stillen Supercharger with my intake, headers, and exhaust systems? Sorry about all the questions but thanx anyways.
Old Feb 3, 2006 | 10:14 AM
Tony@Performance
I have no internal mods on my car at all. The setup is set up to be safe, thus it runs considerably rich in it's tune. The only reason why Stillen recomends to stick with stock headers/cats etc... is due to the fact that this type of blower needs a certain amount of backpressure to sustain it's boost levels. If you free up too much of the exhaust, the SC will actually boost less. so you can run this kit with headers etc... but you will notice less boost than the same setup on a car with stock cats/headers.
There are people out there running the setup with headers etc... and they just upgrade to a stage 3, to compensate for the loss of boost, however jumping into a stage 4 realm, may require extra tuning to get everything to tie in properly.
Also, no, they have not come out with a kit for the 300hp rev-up engines yet. They are working on it, and should have it released by summer, or so we hope.
Old Feb 3, 2006 | 07:45 PM
808_FairladyZ
Thanx for the info, but if they don't make a supercharger for my car then i guess i'm SOL. I hate to have to put my stock headers back on cause the Alpha Werxs Headers was a pain to put on. Plus i'd rather get the stage 2 so that it's carb legal. I don't want more trouble then neccessary. I just want a little more horse power for myself.
Old Feb 3, 2006 | 08:39 PM
808_FairladyZ
Tony, I was just reading another post that stated: 287 hp for 2003 Track Model Z and not 300 hp like i thought. Is this true? If so, does that mean i can use a Stillen Supercharger?
Old Feb 4, 2006 | 12:40 PM
Dr.G's Avatar
Dr.G
Stillen supercharger is good for the 287hp model :03,04,and 05.
all you need with it is cat back exhaust , no headers , no race pipes otherwise you will loose some boost. i am now in stage 4, very sweet very smooth and lots of fun! it comes with a new control box and a new fuel pump and a larger injector so that the mixture stays rich and safe from detonation. stage 2 and 3 do not require the new fuel pump. but for all stage 2 people they can go directly to stage 4 its worth it!!
Old Feb 4, 2006 | 12:43 PM
Dr.G's Avatar
Dr.G
thanx Tony, i just installed mine , very nice .............i love it , feels much more powerful in 4th ,fifth and 6th gear at higher rpm , keeps pulling hard
Old Feb 4, 2006 | 08:58 PM
k3silk's Avatar
k3silk
watch those EGT temps in high gear pulls...
Old Feb 6, 2006 | 09:47 AM
superchargedg
Damn Noobs
according to stillen the stage 2 and 3 do need the new fuel pump.
Old Feb 6, 2006 | 02:17 PM
Dr.G's Avatar
Dr.G
when i had the stage 3 kit they did not send a pump and they said that no need for it. when i got stage 4 , they sent me the pump and a new control box. However they said that with this new conrol box and pump i can also run the stage 3 pulley.
