okay, last turbonetics question...for this week :P
Old Feb 1, 2006 | 11:56 AM
mine350z's Avatar
mine350z
Default okay, last turbonetics question...for this week :P
okay, i was on the freeway, boostin' normally. I decided to slow down so i left off the gas. while coasting down in 6th gear, i hear a few clanks...as if something popped off, and then a loud exhaust growl. So i knew one of the exhaust pipes popped off. took it to the shop and they told me that its such a tight fit, that one of the pipes is touching the chasis. they put the clamp and pipe back on and everything ran smoothly. i notice now there is a slight rattle. i tried to find where it came from. I noticed that its where the exhaust pipe "downpipe 1" (P/N 21185) meets "downpipe2" (P/N 21186). I guess its the V clamp that sittin right against the chasis which causes the rattle and I feel that popped off earlier on the freeway. okay, my question is, would there be a way to loosen that clamp and turn it so fat part of the v clamp isn't facing the chassis? currently, it looks as though the fat part of the v clamp is touching the chasis, but if i were to turn it, i think there would be enough clearance so under hard acceleration or shifting, the pipes won't touch the chassis. how would i go about approaching it? from underneath or up atop under the hood? sorrry, not really mechanically inclined. does anyone else have this problem? would my car being low (& scraping pipes over speed bumps) affect this problem also?
Old Feb 1, 2006 | 12:07 PM
RED HOT Z's Avatar
RED HOT Z
no scraping wouldnt matter.
But yes if some of the V-clamps arnt put on in the right direction they will touch other parts. What I would do is try to get it from up top by removing the intake pipe the one with the BOV. You should be able to remove the bolt from the V-clamp and open it up and just turn it around.
Old Feb 1, 2006 | 12:15 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thats hard to get to....You wont be able to hit it from the top very well, if anything you need to disconnect the exhaust, downpipe 2 from downpipe 3 and work your way up to that from underneath. If you position the clamps correctly you wont get rubbing, I never have had any rubbing/rattling with mine. Id take it back to the shop if I were you, I think its more than you want to mess with if your not mechanically inclined.
Old Feb 1, 2006 | 12:21 PM
MIAPLAYA's Avatar
MIAPLAYA
+1
Best way to fix this is loosen all the clamps and re-adjust the downpipe...
Old Feb 1, 2006 | 12:40 PM
mine350z's Avatar
mine350z
yeah, i was thinkin' of doing it myself 'cuz i'm tired of going to the shop (3rd time already)...but then again, its because of their install that makes me go back. i know its gonna pop off soon again. i should just wait til my day off (friday) to take it down..until then, i guess i gotta drive conservatively. thanks guys. just wanted to be sure that the clamp was able to move around...thought it had to be set in a certain position on the pipe.
Old Feb 1, 2006 | 12:43 PM
RED HOT Z's Avatar
RED HOT Z
I seem to get it easily from up top because I recently messed with it when I installed the overboost fix pipe
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
