AH-HA! Boost drop finally solved!
Old Feb 2, 2006 | 10:45 AM
PhxBlue's Avatar
PhxBlue
The boost tapering .75 psi instead of 3 to 5 psi like previous is a great improvement. That minimal boost taper at the top end is probably a mix of turbo qualities and a subpar wastegate design. I lose 5 psi after 4500 to redline with the exact same turbo and exhaust (with the resonator) setup as Tig.
Old Feb 2, 2006 | 11:20 AM
tig488's Avatar
tig488
Originally Posted by 35ounces
I thought way back you tried with NO exhaust and still had the boost taper issue???
In any case glad to hear that your car is running better.
a long time ago i did drop the exhaust and it dropped boost, but i found that i had other issues, like the exhaust flanges were loose.
recently i dropped the exhaust after i got everything else fixed, and it held boost perfectly.
before i did the tranny stuff, i would drop down to less than 4500 between shifts, and the boost would start to drop past 4500, now i guess with the new flywheel and clutch, when i shift it never drops past 5000, and the boost holds strong.
Old Feb 2, 2006 | 12:28 PM
dirtroad's Avatar
dirtroad
that is insane - at first i thought the pic showed smoked oil buildup?!? good catch.
Old Feb 2, 2006 | 04:48 PM
georgec's Avatar
georgec
Originally Posted by amolaver
i can't even believe i'm going to say this........
peter was right
ARRRRGHHHH!
ahm
I glad that you remebered what Peter said about high exhaust back pressure being the main issue with Tig's boost drop. I suspect that Tig had multiple problems at once and it can become very confusing as to what the real problem is. Tig also had a boost leak before the turbocharger (one loose turbo flange nut), once this was rectified any boost drop had to be caused by a restrictive exhaust, awesome to see that TIG is finally sorted for now.
Old Feb 2, 2006 | 04:52 PM
tig488's Avatar
tig488
true, peter was partially right, i admit it. kinda misleading tho when i called JIC and they said it was a 3" ID resonator. now i have to get the hole in the exhaust housing of the turbo fixed.
Old Feb 2, 2006 | 04:54 PM
Gumpdriver's Avatar
Gumpdriver
Tig i hate to say but that is funny as hell. Happy to see you have the boost problem fixed now.
Old Feb 2, 2006 | 05:16 PM
tig488's Avatar
tig488
yep, after all that, it in fact was the exhaust.
Old Feb 2, 2006 | 05:47 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Originally Posted by Alberto
Wow-good thing I ordered the non resonated version. You pansys ordering the quiet ones deserve less boost....
Is there really a non-resonated version???
Old Feb 2, 2006 | 07:48 PM
AmyCroft's Avatar
AmyCroft
Smile Hi GQ
Originally Posted by Sharif@Forged
tig, I almost fell out of my chair when I saw that pic. Unfuggenbelievable is all I have to say.
Sharif
Wow - New Word - CouldntFuggenBelieveIt !
Tig - Glad you found that one.. I wonder how many other's are out there?
Cheers Amy -
Old Feb 3, 2006 | 11:46 AM
amolaver's Avatar
amolaver
fair enough - obviously, that's not 3" ID.
how are you going to fix that hole? can you weld a blob in there and grind it smooth?
ahm
Old Feb 3, 2006 | 12:15 PM
tig488's Avatar
tig488
i dont know about the hole, its in the cast housing. im working on it.
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
