Kinetix SSV Install Problem
Old Feb 4, 2006 | 11:14 AM
amai21's Avatar
amai21
Default Kinetix SSV Install Problem
Could anybody help me out with which hoses will remain connected, and where they would connect to on the new intake manifold. I am switching over from the Crawford Z plenum. Also, I need to hook up the vacuum hose from the Split Second box. The instructions are just plain ****ty, and I have tried emailing them but no response. Somebody please help. Thanks.
Old Feb 4, 2006 | 11:23 AM
eckocomplexg's Avatar
eckocomplexg
give em a call... they help you out right away... when i installed the v4 plenum, i had a question.. they helped me out right away.
Old Feb 4, 2006 | 11:38 AM
amai21's Avatar
amai21
Unfortunately they are closed and I am sitting here with the upper and lower plenum off, and then I am suppose to be getting a dyno tune in bout 2 hrs.
Old Feb 4, 2006 | 11:59 AM
plumpzz's Avatar
plumpzz
Which ones don't you know how to put in? The 2 on the left, can go in either hole on the left of the plenum. Theres one big one on the driver side, that goes into your intake tube, and the 2 small ones on the right connect to each other via the connector they sent you. Make sure to put in the plug into the left side of the plenum. That 3rd hole is for boost or vacuum pressure.
Email me at plumpzz1337@gmail.com and when I get home I can send you a picture of everything installed.
Old Feb 4, 2006 | 12:15 PM
SungNamZ's Avatar
SungNamZ
Hope the phone conversation that you and I just had makes things happen. Glad to see in your post that you are getting a dyno / tune. If your tuner has knowledge of the SS Box / R4 Program he should be able to dial in your A/F. Good Luck!
Old Feb 4, 2006 | 06:06 PM
Peking's Avatar
Peking
Yep seems pretty straight forward, and there is a nice DIY over on the other Z site...
Also did you guys get a new gasket for the lower portion? I ordered my Kinetix SSV a couple of weeks ago (originally thinking the Crawford and got the upper gasket, though now changed my mind), last thing I am waiting on before getting some stuff done
Old Feb 4, 2006 | 07:57 PM
plumpzz's Avatar
plumpzz
stock comes w/ a cork gasket glued on. i used a motordyne isothermal as well.
Old Feb 5, 2006 | 07:08 AM
amai21's Avatar
amai21
Yeah it came with with cork gasket on at the throttle body and on the lower portion.
SungnamZ, thank you for all your help!!
Hopefully I can get it dynoed here in a little before Superbowl. I will post my results. Thank you everbody
Old Feb 5, 2006 | 01:31 PM
Peking's Avatar
Peking
Thanks guys, and good luck amai21 on your install
Old Feb 5, 2006 | 02:52 PM
G352NV's Avatar
G352NV
Is the cork better then the first one that came with it? I was one of the first ten to get one. Have they changed things?
Uriyo_
Sep 8, 2021 08:46 AM
