which oil pan spacer will work with TN?ASAP PLS
Old Feb 6, 2006 | 08:39 PM
blackend's Avatar
blackend
Default which oil pan spacer will work with TN?ASAP PLS
and which site is selling them?
Old Feb 6, 2006 | 08:45 PM
MIAPLAYA's Avatar
MIAPLAYA
JWT or AAM... any vendor here should have one or the other...
Old Feb 6, 2006 | 11:42 PM
Dubai's Avatar
Dubai
since you bought your kit from AAM, I suggest you get their oil pan spacer as well
Old Feb 6, 2006 | 11:49 PM
blackend's Avatar
blackend
iam trying with them now to see how much they will give me the oil pan spacer.
Old Feb 7, 2006 | 05:53 AM
Noah@AAM's Avatar
Noah@AAM
Our oil pan spacer fits perfectly on the T-Netics kit. It retails for $149.99 for the spacer and $89.99 for the pre-terminated,pressure tested ready to bolt on your car, oil line.
Old Feb 7, 2006 | 06:00 AM
chimmike's Avatar
chimmike
i'll be running the JWT spacer. AFAIK there's no specific spacer for the TN kit, as you can drill/tap it anywhere you need/want.
Old Feb 7, 2006 | 07:10 AM
johnlotusboy's Avatar
johnlotusboy
Oil drain hoses are suppose to dump the oil above the oil level in the pan. If they don't you will have smoke/seal problems from the backed up oil and the foam in the returning oil is supposed to disipate before it goes into the oil pump pickup tube.
Old Feb 7, 2006 | 02:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
This is a touchy subject and like a$$holes everybody has one. Many reputable companies like HKS drain back into the stock oil pan bolt location, and into oil. I tapped my JWT spacer, many others have as well I havent had an issue. Due what you feel is best, but dont go around spreading fear. AFAIK Phunk (very knowledgable member-pushed stock block to 460whp+ over 1 year ago) runs his "under oil level" and also believes if the line is big enough, you wont have any problems, obviously I feel the same.
Old Feb 7, 2006 | 05:42 PM
johnlotusboy
I've never seen a factory return line below oil level. Maybe they just want to save money on the length of the hose.
I guess my friend that retired from Garrett is wrong.
By the way how much oil film/puddles do you have in your intake/plenum?
Old Feb 7, 2006 | 06:28 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Did I say from the factory? Quote where I said that...I said many reputable companies do that-learn to read before you go trying to be smart a$$-you do what you want, Ill do what I want, others will do what they want, lets agree to disagree<----like I started my original post before you got upset I disagreed with your buddy. BTW my NA Z had a slight oil film in the plenum when I swapped plenums/injectors, whats your point?
Old Feb 7, 2006 | 06:59 PM
johnlotusboy
I was pointing out that OEM engineers don't ever do it for some reason.
The aftermarket does what they do because it's cheaper, easier, and no do-it-yourselfer will acidentaly leave metal shaving in the tapped holes in the pan, along with the pan thickness that doesn't make tapping very good or strong.
Go read Hugh MacInnes's book on turbocharging, it explains exactly why.
I am not out to "scare" people , just inform.
Sorry, I wasted my breath, not again.
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
Shane86
Sep 17, 2015 05:33 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
