Turbonetics Owner Get Together....
Old Feb 12, 2006 | 01:26 PM
MIAPLAYA's Avatar
MIAPLAYA
Of course...Its a rally for Turbonetics owners but Sharif you are a Turbonetics vendor and certainly a VERY well respected and have contributed to the 350Z community to no end. I would be honored to have you on this trip... I am currently in talks with two sponsors to get us all tickets for the show and hopefully some walkway space for some of our cars.. Once I get off my lazy *** and finish the Turboentics Onwers Club server and page I'll have details and updates posted there.
Old Feb 12, 2006 | 01:35 PM
rs350z's Avatar
rs350z
...cant wait
Old Feb 26, 2006 | 06:48 PM
rs350z's Avatar
rs350z
...still cant wait =)
Old Feb 26, 2006 | 06:55 PM
maximumsportZ's Avatar
maximumsportZ
Come on guys... what about a APS TT?
Old Feb 27, 2006 | 05:04 PM
rs350z's Avatar
rs350z
meh...
Old Feb 27, 2006 | 05:18 PM
D350Z10's Avatar
D350Z10
Well new update guys, Thought I would shed some light on those looking into the stage two process!! Well they are going to build my t-60 into a t66 basically just switch out the wheel and machine. As for a wastegate I believe we are going with the New gen wastegate! Our power goal is going to be from 650whp to 700whp. I am going to be using RC 750cc Injectors with the UTEC ems. The entire shortblock will be built! No sleeves no fuel return.
Old Feb 27, 2006 | 05:30 PM
Alberto's Avatar
Alberto
Cranky FI Owner
700whp no sleeves or fuel return hmmm, Id do them for those power levels. Good luck.
Old Feb 27, 2006 | 05:41 PM
JETPILOT's Avatar
JETPILOT
Question:
1. How is that possible without a return fuel system?
2. What modifications will you do to the fuel system to reach those #'s?
3. What is the reason NOT to go without a return fuels system? You trying to save $1000?
4. Why no sleeves?
Respect
JET
Old Feb 27, 2006 | 05:52 PM
D350Z10's Avatar
D350Z10
well with sgp's input and my shop as well the stock walls can handle 750whp max I will pry settle with anything in the 600's. As for the fuel system, I have done alot of research and found from many shops and many pros who do not use it and are sucessful.
Old Feb 27, 2006 | 06:10 PM
disturbed2483's Avatar
disturbed2483
yeah but at those power levels why risk all your work and money on something so small as a fuel return system, i dont see the point. just my 2cents.
Old Feb 27, 2006 | 07:36 PM
JETPILOT's Avatar
JETPILOT
As for the fuel system..... So in other words you have no idea how it will work. Even after all the research? Is it a secret?
Again.... if you don't use a return how will you make 700whp without it. What mods will you make.
I have to raise the flag on this one....
Respect
JET
Old Feb 27, 2006 | 08:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Respect
JET
Let me preface my statement by saying that I 100% agree a fuel return system of some sort should be used. Maybe the fuel return setup Turbonetics is coming out with. Now that being said JWT has been running no return on all the VRT built cars just running a regulator in tank. It has worked for them so far but its not what I would do.
Old Feb 27, 2006 | 09:15 PM
taurran's Avatar
taurran
Respect
JET
I'd have to agree that a return line isn't a magic end-all fix to any fuel solution. There are many experienced tuners/engineers out there that will tell you that they don't believe a return line is REQUIRED to make power, and they'd be absolutely right that it's not. The reason for it is that it is easier to tune for more power with it. Most shops out there will tell you that you need one because it makes the job easier and they are more comfortable dealing with a traditional fuel system. But, again, it is by no means an absolute requirement.
This is one of the fallacies perpetuated by information circulated on these forums that isn't necessarily the truth. Raising the BS flag on something just because someone on the forums "said so" is a bit extreme.
Old Feb 27, 2006 | 10:16 PM
JETPILOT's Avatar
JETPILOT
Well.... the other solution here is to run obscene fuel pressures which will really f*ck with the injectors.
Hey.... you can also bang in nails with a hammer.
No one on a forum has to tell me anything. If one understands how the fuel system works as I do you would know this method is not prudent.
This is not the right way to do it.
Respect
JET
Old Feb 28, 2006 | 12:02 AM
taurran's Avatar
taurran
Respect
JET
How is that? He is upping the injectors and fuel pressure to compensate so it shouldn't be a problem. As long as you are careful to insure uniform pressure across both rails, and minimal [to no] pressure drop at the injector, then you should be fine.
That being said, would you care to explain how supercharged mustangs have been achieving 700+whp on returnless systems for years now? (I know the answer) I'm not trying to be facetious, I just would like to hear your take on it and how it isn't comparable to this application.
Oh, and I'm not saying that a full return fuel system isn't a good thing. If you're going to be building your motor and pushing for big power I also don't see the harm in putting down an extra $1,000 for a new fuel system...
Old Feb 28, 2006 | 10:32 AM
RED HOT Z's Avatar
RED HOT Z
Hey Robert I cant seem to get anything from TN I want the T66 because I already have a fully built longblock sitting in my garage and a fuel return kit.
I just cant seem to get any info from Reggie or any help.
Old Feb 28, 2006 | 11:12 AM
MIAPLAYA's Avatar
MIAPLAYA
They've been a little swamped over there lately. I'll see whats up when I talk to him today.
Old Feb 28, 2006 | 11:19 AM
  #38
D350Z10's Avatar
D350Z10
THANK YOU!!!! some one understand! Cars for many years have been runing without a return system. Plus did you see my injector size???? 750cc and running about 650whp is only at a 60-70 percent duty cycle.
Old Feb 28, 2006 | 01:08 PM
  #39
35ounces's Avatar
35ounces
03 CS Track 6MT
For the record, I think you are crazy for running that kind of HP (inb the 600's) without a fuel system (more importantly a rising rate FPR). You may be able to get it to work but as you start pushing things you need to become more precise. A rising rate FPR makes a lot of sense and the money is not huge considering what you will have put into the car with the other mods. It certainly will look cheap if you should run lean due to fuel issues.
The JWT TT setup does not use a fuel return because the return fuel line will prevent the system from passing the PZEV evaporative emissions test. But keep in mind that the JWT TT kit out of the box is making around 400hp NOT 600 or more. I think you'd be hard pressed to find anyone on this board making over 600whp without a more significant fuel return system.
Old Feb 28, 2006 | 01:27 PM
  #40
nissansource's Avatar
nissansource
Hey Robert what about my Stinger battery?!
oh yah also i have full hosting on 100mbps line that i own if we need space and or hosting i can give you your own Cpanel and gateway to config all your stuff and run.. Its running RH Enterprise
