Nismo cat back with APS TT?
Old Feb 12, 2006 | 09:08 PM
rock350z's Avatar
rock350z
Default Nismo cat back with APS TT?
Hi everyone, gotta say this site kicks a$$ for the 350z!! purchased a base '05 in september and mothballed right now for the winter. I have purchased new rims and tires, Nismo suspensions and sways, and was wondering if the nismo exhaust will be OK with the APS TT system. I like the nismo exhaust and can get a good deal on it right now. I plan to install the APS system in the fall as there is now a APS distributor in our area( 4 hours away, lol).
is the nismo ok or should I wait and get the APS exhaust when i get the TT?
Any input would be greatly appreciated. Thanks
Old Feb 12, 2006 | 11:51 PM
georgec's Avatar
georgec
Originally Posted by rock350z
I plan to install the APS system in the fall as there is now a APS distributor in our area( 4 hours away, lol). is the nismo ok or should I wait and get the APS exhaust when i get the TT?
I think it would be wise to get the APS true dual exhaust, the TD 2.5 exhaust has awesome exhaust gas flow and is idealy suited to the APS twin turbo system.
Old Feb 13, 2006 | 12:26 AM
Dubai's Avatar
Dubai
Nismo will be very restrictive for turbo application. If you're going with APS TT stick with 2.5" or bigger exhaust. I personally suggest APS TD with their TT kit
Old Feb 13, 2006 | 06:17 AM
BrianLG35C's Avatar
BrianLG35C
I have the Nismo exhaust with APS TTs and I'm pretty happy with the performance. My tuner even commented on how well it flowed and good it sounded. At 9psi, he mentioned getting 442whp was excellent with this exhaust.
Old Feb 13, 2006 | 06:41 AM
rock350z's Avatar
rock350z
Thanks for all your info guys! i would be happy with 442 at 9 psi.! sounds like the APS 2.5 would also be a good bet. again thanks
Old Feb 13, 2006 | 06:44 AM
jmcmorante's Avatar
jmcmorante
Im in the same dilemna as you right now. Car should be back to day from turbo install (greddy) and i have the nismo exhaust and was also wondering if it would hurt too bad to have the nismo or not. Ill post my impressions to give you another view when i get it and dyno it later.
Old Feb 13, 2006 | 09:31 AM
barthelb's Avatar
barthelb
Master
The nismo exhaust looks like it would be restrictive but its definitely proving some people wrong. However, a better flowing exhaust would benefit. The Nismo is adequate to your needs. I have it with the APS TT and at 9.5psi i have 462/445. Im gonna mate the 3.5 APS Test pipes to the Nismo exhaust and see how that works.
Old Feb 13, 2006 | 09:44 AM
BrianLG35C's Avatar
BrianLG35C
Definitely post results asap! Also, how they sound.
Old Feb 13, 2006 | 04:07 PM
plumpzz's Avatar
plumpzz
Although you would benefit from a APS 2.5 TD exhaust, I think the nismo would work for your application. Free flowing is however always better, less heat, less resistance ect. They both sound great
Old Feb 13, 2006 | 06:59 PM
rock350z's Avatar
rock350z
Thanks again guys, great feedback. I was also thinking along the lines of Barthelb with the testpipes and the nismo exhaust. definately want to hear your impressions!
Old Feb 13, 2006 | 08:03 PM
georgec's Avatar
georgec
The nismo exhaust may be adequate and have sufficient gas flow for a high powered twin turbo engine. Imho it' better to be safe than sorry and get the APS TD 2.5 '' twin turbo exhaust system which is designed by APS for high powered twin turbo applications and also reduces a good deal of the high thermal load on the engine, good luck with your choice either way.
George
Old Feb 13, 2006 | 09:31 PM
Nitrouz's Avatar
Nitrouz
Back to Z
whatever you do, if you use the nismo exhaust, use an aftermarket Y-Pipe. If you don't, you'll get boost spikes at high rpms and you'll lose some power up top. Also you'll have slight detonation. This is why I dropped my JIC and went with a custom true dual.
Good luck. And you'll be the second guy in BC with an APS TT Z.
Old Feb 14, 2006 | 01:10 PM
bsp's Avatar
bsp
Brainstorm Performance
We have done an APS TT on a Z with a Nismo catback. Nismo makes a good exhaust, however it didn't mate very well with the twin setup. The numbers were significantly lower than other better flow exhaust. I believe the Nismo was at least 20hp lower...it may have been more though.
Old Feb 14, 2006 | 01:34 PM
rock350z's Avatar
rock350z
Thanks BSP, I was wondering about matching up the tt with the nismo exhaust. I think i'm going to make a call to my guys and see if they can get the new 3.5" H.F. cats with either the APS 2.5 or 3" set up. keep it all APS. again thanks guys.
Old Feb 14, 2006 | 03:22 PM
bsp's Avatar
bsp
sure thing. you should make some nice numbers with the setup you have in mind. please post the results whenever you do this
Old Feb 14, 2006 | 03:39 PM
barthelb's Avatar
barthelb
Master
If your only looking for performance then go with the APS True Dual. However the tone of the engine changes with that style muffler because there is no mid pipe to equalize the tone, so be sure you like the sound before you decide, I personally do not like the sound of their exhaust. Im not only performane minded, i like to keep the Z sounding like a Z and thats why I prefer the Nismo. Just thought I'd let you know since ive heard both.
Old Feb 14, 2006 | 05:44 PM
BrianLG35C's Avatar
BrianLG35C
Exactly, that's how I felt after hearing mine compare to a APS TT Z with the APS 2.5" exhaust. I want the best sound and performance.
Old Feb 14, 2006 | 08:54 PM
rock350z's Avatar
rock350z
Damn, changed my mind again!!lol, back to the nismo! Has to sound great. I've heard the nismo and loved it. i'm willing to sacrifice a little power for great sound as i'm not racing in any way, just a neighborhood killer!! just has to be safe and beat the neighbors new ride, chrysler 300 srt(?) i think.
anyone else?
Old Feb 15, 2006 | 04:14 AM
Madelinot's Avatar
Madelinot
How hard would it be to put transform the APS TD to an H pipe in the center section, somewhat like the Borla? Has anyone done that? Does it sound any different? Equalizing the pressure should be good, no?
Old Feb 16, 2006 | 09:20 AM
zman2's Avatar
zman2
Default 3.5" test pipes
I was going to try 3.5" test pipes with my APS 2.5" exhaust, but Peter (APS) didn't think it was a good idea. Good luck if you go this route.
