Vortech Supercharger
Old Jan 21, 2003 | 03:35 PM
gfornal's Avatar
gfornal
Default Vortech Supercharger
I just got off the phone with James at Vortech. They currently have a G35 coupe in house to be looked at for a supercharger kit. James started it currently is 50/50 chance right now. It deppends if they can fit it in or not. They will have a 350z in house in two weeks. He said to check back in about a month.
here is contact info for vortech
805-247-0226
info@vortechsuperchargers.com
thanks,
Greg
Old Jan 21, 2003 | 07:26 PM
Mr Fairlady's Avatar
Mr Fairlady
hmmm,..not too sure about Vortech,..but they do seem to make alot more HP out of their Supercharger kits,..I'd like to see what comes of it,..its gonna be the price of a Turbo Kit NO DOUBT! BUt I think a little safer!!
can't wait,..keep us informed!
Old Jan 21, 2003 | 08:03 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
not expert on supercharger but....
can you run stock internals with Vortech Supercharger? how much boost does it usually have? I just checked their website, they have an app for S2000 with 108hp gain! is this with stock internals?
3yrs warranty and Carb certify will make this very attractive!
Old Jan 21, 2003 | 08:15 PM
Mr Fairlady
Most Superchargers are made to run w/ All stock internals and Bottom end,...then some offer boost Upgrade package(new fuel pump/pulleys,etc)but suggest that you upgrade bottom end,..!!
Now Vortech is a different kind of superchager w/ what they call and 'Aftercooler'--Vortech is making huge gains w/ theirs but are so expensive that most just buy a Turbo kit w/ INtercooler and injectors and are just as safe(MOST OF THE TIME?)
<-------Former JACKSON RACING SUpercharger Owner(00'GSR)
w/ upgraded 8lbs pulley to 12psi!! a NO,no on stock bottom end
-Smoked the **** out of a Z28 and blew bottom end(melted pistons,cracked the block)
Old Jan 21, 2003 | 09:11 PM
2k3silver350z's Avatar
2k3silver350z
vortech is a centrifugal supercharger correct? vs the normal mf90 eaton based blower that most people use.
Old Jan 21, 2003 | 11:39 PM
krinkov's Avatar
krinkov
yep, centrifugal. Typically these make more top end power but dont have quite low end response as roots type. Centrifugal are typically external and are mounted infront of the engine, not integral to the intake manifold, like the stillen one
Old Jan 21, 2003 | 11:45 PM
Phatmitzu's Avatar
Phatmitzu
no question that Vortech makes top-end quality superchargers. Since they have already built nice ones for some of the V6s out there(Honda Accord V6, Acura NSX...). I do believe that if they came out with a supercharger for the Z, its gonna rock.
Old Jan 22, 2003 | 04:11 AM
gfornal's Avatar
gfornal
I think the max price of the kit would not go over $5,000. Summit racing sells the Civic Si vortech kit for $2,999. Not bad at all.
the S2000 108 hp was witth stock internals.
thanks,
Greg
Old Jan 22, 2003 | 05:36 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Our engine bay should have enough space for the Vortech Supercharger.. We can remove the factory airbox and probably mount the supercharger there.. It would fill the space very nicely!
Old Jan 22, 2003 | 05:57 AM
12SecZ's Avatar
12SecZ
Default I was told by a wise man who experienced it
That if you add an after market SC to your setup you are well advised to reinforce your bottom end for the long haul, which insn't cheap either!
Old Jan 22, 2003 | 06:25 AM
2k3silver350z
Default Re: I was told by a wise man who experienced it
a low boost setup would be fine on our cars in the long haul. the engine is pretty strong. if anything a blockguard at max and we should be okay on a 5-7psi setting.
the good thing is with a centrifugal blower is that we wouldn't have to worry about hood clearance therefore we wouldn't need to waste money on a hood.
Old Jan 22, 2003 | 06:54 AM
2003z's Avatar
2003z
I don't know what your background with Nissan is, but in the past, Nissan's bottom ends have been bulletproof.
Old Jan 22, 2003 | 06:55 AM
12SecZ's Avatar
12SecZ
Default This was on an LS1
This is my first import.
Old Jan 24, 2003 | 04:58 PM
MardiGrasMax's Avatar
MardiGrasMax
I run a V1 blower and the stock VQ30 internals in my 98 Max will hold 13.5psi of non intercooled boost all day long with just a few degrees of ignition timing retard. I even saw 15psi the other morning when it was realy cold and the air was dense. I use a J&S Ultra Safeguard now that I am at "ludicrus" boost on stock internals. When I tuned the J&S in I discovered that ~10psi is where the detonation starts, I have it set up to pull ~1 degree of timing per lb of boost starting at 9psi. With this setting the knock retard function of the J&S rarely ever lights up the knock gauge and pulls any more timing. If I had a good Air to Water InterCooler it would require less ignition timing retard. I plan to add the AWIC eventually but I put safety first by getting the J&S unit. If you lucky VQ35 Z guys are going to boost up on stock internals I recomend looking into a J&S Ultra Safeguard, its allot cheeper than replacing head gaskets. As long as the AFR is tuned good and you can keep the detonation in check it will run all day. The knock sensor and ignition system on the VQ35 and VQ30 is identical so the Maxima Safeguard should work for all the VQ35 apps.
PS: I have a VQ35 short block and have turned over a rod, piston, rings, main bolt, head bolt to a reputable US based import shop who will in a few months have stronger units available to the public
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
