E-Manage Ultimate ROCKS!
Old Feb 21, 2006 | 11:12 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Originally Posted by GurgenPB
pretty much sums it up. But thank goodness Tony and George were there, as I was ready to kill somebody. My luck is truly something
I remember you were stressing on the time you needed for the install and you were pressed for time...
Old Feb 22, 2006 | 04:52 AM
Gman2004's Avatar
Gman2004
Let me put your worries at ease. First of all, using good equipmen tlike the Innovate, and making sure it's wired correctly (common sense) makes failures extremely unlikely. Second, a wideband failure will not jsut occur in the middle of operaton. WB O2 sensors will fail, if they do (and this is more likely tp happen prematurely due to an incorrect sensor install), at startup. Third, you only need to use the auto-afr tune function during tuning, and not full time. While oyu are tuning, you'll be stairing at the datalogger screen, and it will obvious if your AFR is off (like, reading 7.6AFR, same as 0volts). If it is, just don't go into the predetermined range of 80%+ of throttle opening, and the AFR feedback is not even activated. There are MANY safeguards. The actual controller portion of the Innovate! LC-1 is all state-of-the art, solid state device, and is no more likely to fail than EU (or for that matter ANY EM device) itself; in fact, it's far less likely, as it's a significantly simpler device than an engine management solution.
Gurgen
That clears things up a little. I understood the auto a/f tune always be active and keep the car within a specified a/f range. I have two widebands. An AEM which I know is not as good as the Innovative and the PLX-R500 which is the one I have connected to the EU. I know that PLX-R500 is superior to the AEM so I guess I shouldn't worry. Thanks.
Old Feb 22, 2006 | 06:18 AM
atlsupdawg#2's Avatar
atlsupdawg#2
One other question: at what throttle position input % do you guys start the feedback?? Can you start all the way from idle??
Old Feb 22, 2006 | 07:10 AM
theking's Avatar
theking
No you can only datalog. It will not compensate for you to the target AF.
Originally Posted by Alberto
It does I believe if you buy TXS's WB to datalog with it...I just found this out. Innovate WB wont work with the UTEC.
Old Feb 22, 2006 | 07:12 AM
theking's Avatar
theking
We started at 80% but you can start at whatever you like.
Old Feb 22, 2006 | 08:12 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I start at 60% because the PE turbos spool up and go into boost VERY fast. I will be goind down to 50% soon.
Old Feb 22, 2006 | 08:28 AM
RedLeader's Avatar
RedLeader
GurgenPB-
What's the story on the warranty? Are they going to just replace it without any hassle? I'm interested in eventually moving away from my UniChip, but this is the second EU I've heard about that was defective. Sharif took care of the other one lickety-split!
Bruce
Old Feb 22, 2006 | 09:16 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by RedLeader
GurgenPB-
Bruce
Working on that now... will let you know what happens.
Old Feb 22, 2006 | 10:00 AM
Midnyte's Avatar
Midnyte
if you installed larger injectors and a return fuel system(for those of us with the TN kit), what else would you need to configure on this unit before dialing in your desired a/f...or does that matter to the EU?
Old Feb 22, 2006 | 10:31 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Just the base airflow adjustment map to scale to the larger injectors...that's all.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Depravity
Oct 1, 2015 04:49 PM
z33z_nutz
Sep 23, 2015 07:22 PM
torchkc
Sep 11, 2015 08:26 PM
