Turbonetics AT w/ CAT by Danzio worth the wait!!!
Old Apr 6, 2006 | 08:05 AM
  #41
blackend's Avatar
blackend
i made 377whp with unichip but not with cat ver
Old Apr 6, 2006 | 08:06 AM
  #42
chimmike's Avatar
chimmike
on a dyno that extrapolates (aka guesses a bit)
Old Apr 12, 2006 | 07:52 PM
  #43
AmyCroft's Avatar
AmyCroft
Smile Plumbing Pictures
Originally Posted by jlimquest
No, this is the out of the box TN ST for the AT w/ cat. I have an Injen dual Angled SES exhaust with a custom reverse Y pipe, UR pulleys, 5/16 Motordyne plenum spacer & Jethot coated OEM headers. I took off my DC headers & Kinetix V4 plenum. I don't have a Mustang baseline dyno as the previous one was done on a Dynojet (248 HP & 234 TQ).
jimquest:
Do you have photo's of the TN Cat position, or the custom reverse Y pipe.
Those would be interesting.
I like the Idea of having a CAT in the loop with your TN ST 5AT. Please let us know how you fair on a "Sniffer Test". Most of the Catless TN ST's do smell bad. ( notice how I avoided the oprative word.. )
The amount of power (RWHP) is more than adequate for a "Freeway Flyer".
Enjoy,
Cheers Amy -
Please keep us posted.
Old Apr 13, 2006 | 05:12 AM
  #44
jlimquest's Avatar
jlimquest
Default Cat
Hi Amy,
I'll try to take some pictures next time the car is on the lift & will keep everyone posted. Yes, it's definitely fun to drive & the power is more than sufficient for my needs. Also, I was able to resolve rev. limiter issue on AT mode at WOT by having Technosquare raise it to 7100 rpm. So far so good, might not need the valve body upgrade after all. Best regards.
Thanks,
Jeff
Originally Posted by AmyCroft
jimquest:
Enjoy,
Cheers Amy -
Old Apr 13, 2006 | 12:27 PM
  #45
BluZee's Avatar
BluZee
Im confused. The TN flash is supposed to raise the limiter to 7100 but you had to have Technosquare raise it?
Old Apr 13, 2006 | 12:38 PM
  #46
MIAPLAYA's Avatar
MIAPLAYA
It does...perhaps they only raised it in manual mode? Jim could you confirm that? If they need to do it on both settings let me know and I will have them correct that ASAP.
Old Apr 13, 2006 | 12:59 PM
  #47
jlimquest's Avatar
jlimquest
Mia,
You may need to confirm w/ TN as my original ECU on manual mode was already reflashed to 7100 by Technosuare even before I even had my TN kit. I was hitting the rev. limiter at auto mode when I initially got the car after the TN install. So I went back to Technosquare to have my AF adjusted as well as have my rev. limit raised at auto mode to 7100. If TN does, it may be only at 6800 & not to 7100. I really did not try it anymore once it hit the rev. limiter.
Thanks,
Jeff
Old Apr 13, 2006 | 01:30 PM
  #48
MIAPLAYA's Avatar
MIAPLAYA
Mia,
Thanks,
Jeff
You did have Turbonetics flash the ECU though right? I'll follow up with them. I know they specifically said the ECU reflash for 5ATs set the rev limiter to 7100.
Old Apr 13, 2006 | 01:33 PM
  #49
jlimquest's Avatar
jlimquest
Yes, it was sent by Danzio.
Old Apr 13, 2006 | 01:36 PM
  #50
MIAPLAYA's Avatar
MIAPLAYA
OK. I'm checking with the design engineer over there right now. If its not set to 7100 in both modes it will be soon.
Old Apr 13, 2006 | 02:33 PM
  #51
BluZee's Avatar
BluZee
Thanks for clearing this up guys. It wouldnt make sense to have it flashed twice.
Old Apr 15, 2006 | 03:02 AM
  #52
Marvin's Avatar
Marvin
im seriously considering getting the TN kit for 5AT (i have an Auto) but im concerned about what exhaust to get right now. I want one thats as quiet at the Stillen or Borla but both are TD and apparently not fit for single turbo set-ups. any help appreciated.
Old Apr 15, 2006 | 04:42 AM
  #53
blackend's Avatar
blackend
THINK about cooling ur system befor you buy the kit...AT OIL COOLER,ENGINE OIL COOLER,VENT HOOD,BIG RAD,,INTERCOOLER WITH FANS,VB,TC,THEN YOU WILL HAVE SYSTEM
Old Apr 15, 2006 | 06:35 AM
  #54
jlimquest's Avatar
jlimquest
True duals will work with the TN by having a reverse Y pipe installed. I have an Injen angled exhaust & it worked. Here is the thread on it & a pic from Kelly's car of the Y pipe.
https://my350z.com/forum/showthread....0&page=1&pp=20
As far as the aftermarket exhaust choice, a lot of TN owners here have done it. You may just want to check around on which one will satisfy your needs.
Attached Thumbnails Turbonetics AT w/ CAT by Danzio worth the wait!!!-greddymod2.jpg
Old Jun 25, 2006 | 10:23 AM
  #55
vantage350z's Avatar
vantage350z
What is the difference between the manual and auto turbonetics kit? if i had to use the auto kit on my 6mt, what would i have to change?
Old Jun 25, 2006 | 12:44 PM
  #56
MIAPLAYA's Avatar
MIAPLAYA
Well the crossover pipe is different due to the difference in bell housings. Aside from that nothing but the flash...
Old Jun 26, 2006 | 12:41 PM
  #57
BobaFettm's Avatar
BobaFettm
Nice to see another AT Turbo'd Z! The AT with over 500+ is quite amazing because its extremely linear without having a clutch release of pressure... quite scary lol
Old Jul 13, 2007 | 03:03 PM
  #58
turtle503's Avatar
turtle503
any videos??
Old Jul 13, 2007 | 03:28 PM
  #59
Cannysage's Avatar
Cannysage
nice.. but I think a stock z can beat a boxter
Old Jul 13, 2007 | 07:04 PM
  #60
jlimquest's Avatar
jlimquest
That's true...how about a GTO 6.0?
http://www.350zmotoring.com/forums/s...ad.php?t=45455
Very happy w/ the TN though & it's sufficient power for a once in a while fun!!!
