get rid of SC belt squeal?
Old Mar 3, 2006 | 03:15 PM
booger's Avatar
booger
Yes I can tighten the belt from up top . I dont have skinny arms either . I have since gotten a sleeve [ heat resistaint ] to put on my arm and I wear gloves also . So no more scratched up arms
Old Mar 3, 2006 | 03:30 PM
SungNamZ's Avatar
SungNamZ
Avoid the scratches and burns! Cut that 3" circular hole. Then a jack w/stand under the passenger side, 14mm to the TP nut, 12mm to the TP adjustment bolt, retighten the TP nut and you are done. If you have taken 10 minutes, you have taken too long.
Old Mar 3, 2006 | 03:38 PM
overZealous1's Avatar
overZealous1
yes booger and sungnam are correct. don't put belt dressing or talc powder on them. new belts will always stretch. you need to tighten them 2-3 times before they stop stretching and retain constant pressure. doesn't matter if it is the main 350Z belt, or the fan belt on a 75 vega! belt squeal is from the belt being loose, thats it.
Old Mar 3, 2006 | 05:18 PM
freezeg35's Avatar
freezeg35
Never thought to get some sort of arm protection, not a bad idea......
Acutally a great idea.
Old Aug 27, 2006 | 12:42 PM
DMK's Avatar
DMK
Originally Posted by Luscious Luke
If the belt is a new or "newer one" and good quality and you have made sure it is tight (but not too tight as to bind the bearings, you can get rid of the squeal with a touch of baby powder. Any fine, talc based, powder works well to pull any moisture from the belts and help eliminate your squeal. Give that a try, its a cheap fix, but make sure you check the previously stated issues before you start sprinkling magic pixie dust in your engine bay.
It worked for me.
Where would you put the baby powder? Put it in your hands and rub it on the underside of the belt?
Old Aug 27, 2006 | 12:52 PM
booger's Avatar
booger
Back from the dead ! Dont use baby powder or your belts dude ! Just tighten it up ! How many time is this going to be beaten to death , over and over .
IF YOUR BELT SQUEELS .....ITS LOOSE...TIGHTEN IT UP !!!!!!!!!
Old Aug 27, 2006 | 04:18 PM
MMC Racing's Avatar
MMC Racing
I've tightened it twice now only for it to come back. I'm also close to maxing out the range of the tensioner. Looks like I could use a 1/2" shorter belt.
-Mark
Old Aug 27, 2006 | 04:26 PM
booger's Avatar
booger
-Mark
If your still using the goodyear belt ? yes it seemed to kepp on stretching . When i switched to the NAPA or gates belt . I just had to tighten it up a couple of times
Old Aug 27, 2006 | 05:16 PM
MMC Racing's Avatar
MMC Racing
Yep, using the included belt. I switched from goodyear to Gates on my Lightning with great results. That is probably what I will do.
Old Aug 27, 2006 | 08:59 PM
DMK's Avatar
DMK
I know, I was just asking because it didnt make sense to me. When I tightened my belt it was a pain to remove the bottom skid plate, but I am thinking of doing what other people have suggested and cut a hole. Anyways, I was told to tighten it until I could not turn the longest part on the top of the belt more than 90's degrees vertically. Is this correct? I did this, but I could have tighted the tension bolt on the bottom at least 5 more turns.
Old Aug 27, 2006 | 09:02 PM
kevinapex's Avatar
kevinapex
Goofy question but, has anyone heard of any type of belt for hi-performance use, that has like a kevlar or something of that nature, that has better longevity, less stretch?
Or even a place where a custom belts could be built?
Old Aug 28, 2006 | 02:38 AM
MR RIZK's Avatar
MR RIZK
tighten the crank belt not the SC belt. Had the same issue on my HKS SC. About 3/4 - 1 turn got rid of it
Old Aug 28, 2006 | 04:24 AM
race4it's Avatar
race4it
I've got a Procharger and was having a lot of problems with belts breaking under higher boost. I switched to a wider (36mm vs 30mm) and stronger belt (Gates PolyChain vs PowerGrip). No problems anymore.
Old Sep 21, 2006 | 08:52 AM
World Famous Z's Avatar
World Famous Z
haha, i might as well chime on here.....
I've had off and on problems with strt up belt squealing from my stillen. I replaced the belts enough, and just changed the pulley/tensioner to their newest aluminum pulley/bearing for the main 4-rib SC belt. NO MATTER how tight the belt is, it squeals. If i overtighten it, it squeals, if i have it just right, the same tension as stillen's cars, it squeals less, but squeals. If i have it a little loose, it squeals more again. I cannot help it, so i'm gonna take it in to them. It's a minor annoyance, the car runs great still.
This is the main 4-rib SC belt i am talking about...
Has n e one else with a stillen cured this problem? And if so, which belt on your was actually squaeling? the main SC belt, or a lower 6-rib serpentine>??
Old Sep 21, 2006 | 09:18 AM
superchargedg's Avatar
superchargedg
Damn Noobs
the only belt i have ever had squeal was the power st belt,but now i need a new tensioner its making a metallic noise.i used to oil it a little and it would go away for a week ot to but not anymore.hey tony what did it cost for the newer version of the tensioner.
Old Sep 21, 2006 | 10:24 AM
cersoft's Avatar
cersoft
+1 when I had my Stillen the only belt that ever slipped was the power steering belt.
Old Oct 22, 2006 | 02:48 PM
boma's Avatar
boma
I know nothing about Vortech SC's on 350z's, but I used to have a Jackson Racing Supercharger on my Civic. That thing would squeal at least twice a year. I got tired of adjusting the belts as part of the maintenance, so I sold it that thing. Just from my exp, even though it may not apply to the 350Z.
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
z33z_nutz
Sep 23, 2015 07:22 PM
