CEL Codes
Old Mar 4, 2006 | 12:39 PM
JETPILOT's Avatar
JETPILOT
Default CEL Codes
Can someone run these CEL codes for me? Thanks
P1274
P1283
Respect
JET
Old Mar 4, 2006 | 01:01 PM
mrtomcat's Avatar
mrtomcat
1274 - Ignition Coil 4
1283 - Fuel Injector Output Stage
I got those of an Import DB, I believe the OBDII codes are the same across cars
good luck
Old Mar 4, 2006 | 01:58 PM
JETPILOT's Avatar
JETPILOT
Thanks for the help....
Can anyone interpret that info?
Respect
JET
Old Mar 4, 2006 | 03:42 PM
MIAPLAYA's Avatar
MIAPLAYA
1273 and 1284 are rear O2 sensor codes. Left and Right bank.
Old Mar 4, 2006 | 04:15 PM
mrtomcat's Avatar
mrtomcat
yeah but he asked for 1274 and 1283 not 1273 and 1284...
Old Mar 4, 2006 | 04:34 PM
westpak's Avatar
westpak
SFZCC
P1274 is for AF sensor bank 1 rich shift
P1283 is for AF sensor bank 2 lean shift
Old Mar 4, 2006 | 05:01 PM
JETPILOT's Avatar
JETPILOT
Layman's terms?
Something to worry about?
Respect
JET
Old Mar 4, 2006 | 06:57 PM
overZealous1's Avatar
overZealous1
it is saying your front 02 sensor on the right or passenger side was reading rich for an over extended period of time. 1283 is the opposite side front 02 reading lean. could have been a minor clitch in the cam timing.
i would just clear it and see if it comes back.
Old Mar 4, 2006 | 08:08 PM
Phatmitzu's Avatar
Phatmitzu
I have the exact same two codes, and I have yet to find out the way to perm. clear it.
Old Mar 4, 2006 | 09:46 PM
JoeDirtPharmD's Avatar
JoeDirtPharmD
I had that issue when I first installed the APS injector harness... Bank 1 was too lean, Bank 2 was too rich. flipped the injector harness and viola!
I understand this has NO applicability to your TN situation, but just wanted to share one reason/one outcome.
Old Mar 4, 2006 | 11:46 PM
lucidazn's Avatar
lucidazn
I keep getting these two codes day in day out. What could be the cause? I checked my O2 and they seem fine.
Old Mar 5, 2006 | 01:48 AM
overZealous1
did you check the voltage on them? are they giving a correct reading. there is quite a few different reasons for this. need more info
Old Mar 5, 2006 | 09:53 AM
MIAPLAYA's Avatar
MIAPLAYA
Do your downpipes have the O2 sensor extenders welded on? If not just replace the downpipe with a new one from Turbonetics. My car first got those codes. Turbonetics then redesigned the donwpipe to add the O2 extenders. I think very few kits shipped without them but its something to check.
Old Mar 5, 2006 | 11:37 AM
Zexy's Avatar
Zexy
Don't mean to jack your thread JETPILOT, but is 1273 for the left or right bank? I'm throwing two of these codes.
Old Mar 5, 2006 | 11:47 AM
overZealous1
a good way to remember is that bank 1 is the same side as cylinder 1. the paasenger side. 1273 is that side.
Old Mar 5, 2006 | 12:58 PM
lucidazn's Avatar
lucidazn
Yup, I have the downpipe with the extenders.
Yeah, I had this problem before. Bank 2 O2 was fine, and Bank 1 O2 was screwy. Voltages weren't constant, and had that replaecd. CEL code went away for about 500 miles and they are back. I don't think it could be the O2, they were just recently replaced and checked. What else could it be? I don't want to spend another $60 to get an ODB diag.
Old Mar 5, 2006 | 01:01 PM
MIAPLAYA's Avatar
MIAPLAYA
There was a TSB a while back from Nissan regarding the CEL being thrown by the O2. The only to fix it if you have the downpipe with the extensions is to take the car to Infiniti, apply the TSB, then send your ECU back to Turbonetics to be reflashed again.
Old Mar 5, 2006 | 01:03 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I keep hearing about this. I know I have the original pipes but what exactly is the difference.
I am hoping not to run into the problem AFTER I do my fuel system/injectors/tune (in a week or so) especially as I may coat the pipes. I have not seen those codes to date though...well not since it has got cool here that is.
Old Mar 5, 2006 | 01:09 PM
MIAPLAYA's Avatar
MIAPLAYA
If you have never thrown the codes then you probably have the correct pipes.
Old Mar 5, 2006 | 03:06 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Well the shop that installed the kit also installed Down-Shift's and they mentioned the difference. SO I assume I have the originals pipes...I got in on that original GB from AAM so it could have been one of the early kits.
What exactly is the difference? Any pics that show it?
