Revup Lower Plenum & Boost on 287 engine = teh Suck.
Old Mar 4, 2006 | 08:58 PM
Chebosto's Avatar
Chebosto
Default Revup Lower Plenum & Boost on 287 engine = teh Suck.
don't do it.
i wasted the entire afternoon yesterday experimenting with the Revup Lower plenum on my 03 287hp engine..
you'll notice a difference all right, crap *** torque loss at 3k and just a little bit more top end pull right before redline..
imho not worth it.. i like my low end grunt characteristics (good for powering out of turns and drifting) so maybe its not such a good idea..
ill have picts of the physical differences...
but yea.. it sucked... perhaps if i could rev up to 8k, maybe, but the top end gain wasnt worth my time... i swapped my 287 lower plenum back on....
Old Mar 4, 2006 | 11:16 PM
LOU's Avatar
LOU
Thanks for trying... it was something I have debated doing again and again.
Old Mar 4, 2006 | 11:22 PM
Z BOY's Avatar
Z BOY
nice to get this cleared up by a reliable source. thanx.
Old Mar 5, 2006 | 04:40 AM
captj3's Avatar
captj3
I guess we should just put on a plenum or spacer.
Old Mar 5, 2006 | 09:41 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
wrong
try it and retune.....the differences are there...at least on an NA setup
Old Mar 5, 2006 | 10:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I tired it as well this past week. I put it on and semi-tuned with a UTEC. I can say the power loss down low sucked, and oddly enough-the power fell off a lot faster after 6200rpm's, where as the 287 plenum didnt fall off much up top with the TN kit. Im gonna finish tuning it, and post before and after numbers. But from the looks of things it doesnt work well. I used to make 260whp @ 3800rpm's now I make it at 4200rpm's
Old Mar 5, 2006 | 10:07 AM
Z1 Performance
Former Sponsor
I should quantify my statement...I've only seen it done on an NA setup, not FI
this is NOT a mod for the FI guys (phyiscs tells you that), but for the NA guys, it can prove worthwhile if you have a means to tune
Old Mar 5, 2006 | 05:33 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Bump - anyone have a reason why the revup lower plenum could be causing the power to drop off quicker than with the stock plenum? The more I think about it, the more I want to swap back to stock before AAM finishes the tune on my car....I thought more volume+boost= more power, guess not.
Old Mar 5, 2006 | 07:05 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
damn, i woulda thought the 300hp lower would helped F/I guess I'm gonna sell mine. Thanks for saving me the time.
Old Mar 5, 2006 | 08:32 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I can tell you with 1000000% certainty that therev up plenum on both a rev up and regular "old" VQ35 does exactly what Cheston said. I knew this months ago, after attending ad helping out at a SZM plenum shootout.
The experiments ran where VERY strictly and consistently controlled. With the rev up plenum, you start gaining at about 6000 rpm though redline, peaking at 7hp gain (between the two curves). In the midrange, the difference between the two curves was inverse, but with FAR greater magnitude. At around 3000rpm, the difference was over 20 lb/ft, with gains staying at around 5-8 lb-ft on average through 4700 rpm or so (almost 5000).
So, keep the older plenum.
Old Mar 5, 2006 | 10:24 PM
Chebosto's Avatar
Chebosto
picts from friday:
287 Left, Revup right
again, 287 left, Rev up right
da holes on the REVup
again
the <3able 287 lower plenum..
